Quoting boeing71234567 (Thread starter): and if so, why do airlines use them as much as they do? |
Quoting oly720man (Reply 4): |
![]() Photo © Lars Söderström | ![]() Photo © S. M. Reeves |
Quoting PWM2TXLHopper (Reply 5): I'd think as far as emissions and gasses going into the air, the newer high bypass engines would produce more pollution, because the jet fuel is being more completely consumed or burned and put out as gas in those engine. |
Quoting PWM2TXLHopper (Reply 5): Heck, thirty years ago they said we were going into a global cooling stage. |
Quoting PWM2TXLHopper (Reply 5): If anything, I'd think as far as emissions and gasses going into the air, the newer high bypass engines would produce more pollution, because the jet fuel is being more completely consumed or burned and put out as gas in those engine. When you see the visible smoke, that's fuel that hasn't been completely combusted and vaporized into gasses. I don't have any real scientific knowlege backing this up, but that's just my opinion because I know that's what black smoke is. Fuel that hasn't been completely combusted. Then again, I don't completely buy into the global warming, carbon footprint hysteria, either Heck, thirty years ago they said we were going into a global cooling stage. |
Quoting DocLightning (Reply 8): The newer HBPR engines use the heat from combustion more efficiently, which decreases their CO2 output. But you are correct in saying that the CO2 output doesn't decrease quite as much as the fuel burn does. They also burn the fuel more completely, which decreases NOx and soot output. Soot is a pollutant and a very annoying one at that. Soot is why so many historic buildings need to be power-washed and wind up looking a completely different color once that's done. |
Quoting PWM2TXLHopper (Reply 9): Yeah, but whining, thunderously loud, and smokey engines are so much cooler. |
Quoting N685FE (Reply 6): cruised at mach 0.92 or better |
Quoting DocLightning (Reply 10): Yes and no. When you live under an approach and t/o path to a major airport, you are grateful to modern, quiet engines. Living in my part of SF would have sucked when there were 727's and DC-9's flying out here. |
Quoting PWM2TXLHopper (Reply 9): Before hushkits came around, I could here the 727's and 737-200's taking off ten miles away. |
Quoting N685FE (Reply 6): |
Quoting Access-Air (Reply 16): I regard today's cookie cutter airliners/engines to rap or hip hop music.....Sound all the same and as boring and annoying as hell... |
Quoting Northwest727 (Reply 17): How about a nice CV880 takeoff |
Quoting Access-Air (Reply 16): Sound all the same and as boring |
Quoting Access-Air (Reply 16): Thats why NIMBYs complained.... |
Quoting DocLightning (Reply 19): You can call them that, but when every three minutes your entire life goes on hold as a roaring noise fills your entire home, even though you live miles from the airport, that's a problem. |
Quoting Access-Air (Reply 16): Me I would have loved to have lived near and airport where there were loud jets all the time.....To me its music to my ears... |
Quoting B737-112 (Reply 21): I actually put up an HD video on YouTube taken from the end of the runway just to look at the effects of an MD-80 takeoff. I didn't follow the plane with the camera, I just kept recording the runway and you can see a faint brownish cloud coating it. Make sure to play it in HD |
