Northwest727
RE: Efficiency Of A330 Vs. DC-10
Sun Dec 19, 2010 4:22 pm
Quoting 411A (Reply 49):
Don't think FedEx (etc) would agree, as it makes a dandy freighter.
I understand, but that was not MCDD's intent with the MD-11. The MD-11 needed lots of improvements in order to fulfill MCDD's promises to their customers.
411A
Mon Dec 20, 2010 2:21 am
Quoting Northwest727 (Reply 50):
So will, I expect...the 787.
For example, electrical junction boxes that don't burst into flames every once in awhile.
Also, lets have a look at some of the airplanes that I personally have flown that had 'problems' with initial operation.
L1011...RB.211-22B engines (later engines, no problems).
DC-7...poor engine reliability
DC-6...fuselage fires that led to grounding of the type for about two months.
Lockheed Electra...wings falling off.
B707... failure to gain UKCAA certification until the rudder boost system was revised, this was a huge problem for the type.
Lockheed Constellation...engine and hydraulic primary control surfaces boost initial problems.
Boeing Stratocruiser. Electrical, propeller, and engine problems.
NO airplane is perfect, and some have more problems that others.
[Edited 2010-12-19 18:29:56]
Mon Dec 20, 2010 11:24 am
Adding to 411A's list of teething problems could be:
- 747. Initially unreliable engines meant delays in delivery.
- A380. Granted this one has demonstrated to be a success or a failure yet. Electrical harness issues. Engines that blow up over Indonesia.
I'm sure the list could be made very long.
simonriat
Sat Dec 25, 2010 3:42 pm
In terms of beauty however, I would take a DC10 over a A300 any day. What a stunner.
Just wish I had a chance to fly on either of them.
I have also heard it said that the DC10 was an absolute joy to fly a real pilots aircraft, in fact I have heard on a number of occasions they were better to fly than a 747. Again I cant comment I'm not a pilot.
And as they say beauty is in the eye of the beholder.
VC-10
Sun Dec 26, 2010 5:27 am
Quoting 411A (Reply 10):
In addition, the original A300 was not an extended range approved airplane....only two engines and not enough fuel capacity.
I once knew a Laker Airways DC-10 FE who told of a time he operated a DC-10 flight from MAN to Las Palmas. On the same day at around the same time a Laker A300 was operating the same route. The A300 burned 500 kgs more fuel than the '10 due to structural limitions preventing it cruising at the same alt as the '10
Transpac787
Sun Dec 26, 2010 5:33 am
Quoting simonriat (Reply 53):
Not to vicariously quote someone since I've never flown either but my dad flew both DC10 and 747-400 and really did not like the DC10 but *loved* the 744 - flew it for 11 years.
Sun Dec 26, 2010 8:49 am
Quoting VC-10 (Reply 54):
Not possible, they have the same engines, the DC-10 has one more.
Besides, structural limits on cruise altitudes ? someone is pulling your leg.
“Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.” E. Hamilton Lee, 1949
thegeek
Sun Dec 26, 2010 9:42 am
Quoting zeke (Reply 56):
Not for a normal flight. Perhaps the DC10 was doing a (perhaps two engine) ferry flight while empty but the A300 had a full payload.
VC-10
Sun Dec 26, 2010 8:22 pm
Higher cruising altitude = lower fuel burn
Structural limits - heard of Max Cabin Differential Pressure?
Another factor would be Crz Alt vs Wt
[Edited 2010-12-26 12:27:13]
gabep
Sun Dec 26, 2010 11:24 pm
Quoting thegeek (Reply 9):
s that a mistake in the drafting of the rules?
Pilot's certainly felt that way.
Quoting timz (Reply 29):
1977-78 Jane's says
Be careful with "Jane's says."
As to the original poster questions:
Quoting tsugambler (Thread starter):
A330 is 38% more efficient than the DC-10. Are the efficiency gains of the A330 over the DC-10 primarily due to having one less engine?
No, but it does save a lot in terms of fuel, weight, and maintenance.
Could the DC-10 have been made as efficient if it had one less engine?
Yes, but larger engines would have been required. Size to efficiency just didn't exist at the time.
Mon Dec 27, 2010 4:05 am
Quoting thegeek (Reply 57):
OEI on a trijet would burn more fuel than all engines in a twin, they altitude capability is not the same. Like one engine out on a twin cannot maintain the same the same altitude as all engines.
The empty weight of the DC-10 is around 35,000 kg heavier than the A300, maximum payload on the A300 is around 35,000 kg. So an A300 loaded with maximum payload (nil fuel) has about the same weight as an empty DC-10 (nil fuel).
No way in the world is a DC-10 then loaded with 35,000 kg going to burn the same as a DC-10 that is empty, nor is a DC-10 on 2 engines going to burn fuel less than an A300.
Quoting VC-10 (Reply 58):
Going higher does not automatically mean lower fuel burns, if you fly above optimum level, fuel burn increases.
Yes I have, but what you have described above would require the A300 on two engines to burn more fuel than a three engine aircraft. The cabin pressure diff you would be taking about would be huge, and it would be a widespread known issue with the airframe. As far as I am aware all the Airbus series tend to have their safety relief valves at -1 and 8.85 psi, that would cover the airframe nicely for all normal cruising levels. The sort of difference you are talking about would mean the A300 would have to do the sector at around FL180 while the DC-10 is at FL360.
Someone is pulling your leg if you think the A300 has a structural limit of FL180. Being a licenced mechanic, one would think you should know better.
That should be in favour of the A300, it has the better wing (aerodynamically) out of the two aircraft. Besides the DC-10 empty weight is around 35,000 kg heavier than the A300.
thegeek
Tue Dec 28, 2010 9:47 am
Quoting zeke (Reply 60):
Sounds pretty unequivocal then.
Pihero
Tue Dec 28, 2010 1:33 pm
Pilots can be quite partial with their aircraft.
The -Ten a pilot's aircraft ?... suffice it to say that it was flown most of the time on CWS -control wheel steering - i.e through the autopilot, which is an absolute hoot when I hear people bashing the 'Bus for being all the time on A/P !
On the other hand, the 744 is probably the most secure-feeling airplane I gad the pleasure to hand-fly...after the 'Bus, of course !
Do you know how we recognize a former -Ten pilot ? He violently pushes the stick forward at wheel touch-down ( because on the -Ten, the spoiler deployment causes a rather violent pitch-up moment)... joy to fly, indeed !
[Edited 2010-12-28 05:34:57]
Contrail designer
Users browsing this forum: chop69, jspams20 and 18 guests
