Quoting dimik747 (Thread starter): My question is do certain main landing gear structures allow this bouncing to happen more than others? |
Quoting dimik747 (Thread starter): do certain main landing gear structures allow this bouncing to happen more than others? |
Quoting 2H4 (Reply 4): |
Quoting dimik747 (Thread starter): My question is do certain main landing gear structures allow this bouncing to happen more than others? because i have noticed these bounces on some aircraft significantly more than other, or is that just a coincidence. |
Quoting tdscanuck (Reply 8): Bouncing isn't really related to gear design for large jets...they all use essentially the same oleo system and it's not nearly as much of a spring as it is a shock absorber. |
Quoting Phen (Reply 7): And of course this one is always fun to watch too: http://www.youtube.com/watch?v=OoK_d...LDfA0 |
Quoting tdscanuck (Reply 10): |
![]() Photo © Shary - Iranian Spotters | ![]() Photo © Radek Oneksiak |
![]() Photo © Bjorn Van Brussel | ![]() Photo © Bruce Leibowitz |
![]() Photo © Maciej Nowak (medMatthew) | ![]() Photo © Leor |
Quoting tdscanuck (Reply 8): Quoting dimik747 (Thread starter): My question is do certain main landing gear structures allow this bouncing to happen more than others? because i have noticed these bounces on some aircraft significantly more than other, or is that just a coincidence. Bouncing isn't really related to gear design for large jets...they all use essentially the same oleo system and it's not nearly as much of a spring as it is a shock absorber. Two big factors are geometry (how the angle of attack changes with touchdown and derotation) and the pitch dynamics. On a FBW aircraft, the transition from air to ground control laws can be tricky. |
Quoting kimberlyRJ (Reply 2): I have not really noticed that much of a bounce on landing on any of the Airbus A318/A319/A320A321 family... |
Quoting tdscanuck (Reply 8): Two big factors are geometry (how the angle of attack changes with touchdown and derotation) and the pitch dynamics. On a FBW aircraft, the transition from air to ground control laws can be tricky. |
Quoting 2H4 (Reply 9): I opine that trailing-link versus non-trailing-link designs have a greater impact (no pun intended) on what the pax feel. |
Quoting Viscount724 (Reply 13): After hundreds of flights on 727s and 737s of almost all models, I always found 727s much more prone to bouncing than 737s which seemed to stay on the ground even after quite firm landings. I've also read in many sources that 727s are notoriously difficult to land smoothly with any consistency. |
Quoting PGNCS (Reply 14): my FBW experience is limited to Airbus models, but I have found them very nicely behaved in the flare and at touchdown. |
Quoting PGNCS (Reply 14): Quoting tdscanuck (Reply 8): Two big factors are geometry (how the angle of attack changes with touchdown and derotation) and the pitch dynamics. On a FBW aircraft, the transition from air to ground control laws can be tricky. That's interesting, and I don't think I had ever thought about that. I have not flown the 777, so my FBW experience is limited to Airbus models, but I have found them very nicely behaved in the flare and at touchdown. |
Quoting tdscanuck (Reply 18): I should have been clearer...if the OEM has done their job right, it shouldn't be tricky at all for the pilot. What's tricky is how you design the control law transition so that it looks smooth to the pilot (and the passengers). |
Quoting 2H4 (Reply 15): Quoting PGNCS (Reply 14): my FBW experience is limited to Airbus models, but I have found them very nicely behaved in the flare and at touchdown. I do regularly notice one thing I notice as a pax in the A319 and A320...often, immediately after the tires touch down very smoothly, the aircraft then, for lack of a better term,"bounces" up and down a couple of times without the tires leaving the ground. Almost as if the spoilers dump the lift so instantly, the struts go through a couple complete cycles of travel before the "drop" is damped out. |
Quoting 474218 (Reply 16): Quoting PGNCS (Reply 14): I find the A-320 series the easiest airliner to consistently land other than the L-1011, which is just a delight to roll on. Hard to beat that DLC and flying stabilizer! |
Quoting tdscanuck (Reply 18): I should have been clearer...if the OEM has done their job right, it shouldn't be tricky at all for the pilot. What's tricky is how you design the control law transition so that it looks smooth to the pilot (and the passengers). Once it's done right by the flight control engineers, it should be very predictable and stable to the pilot. |
Quoting PGNCS (Reply 14): the 727 is definitely the hardest aircraft to land consistently that I have ever flown. |
Quoting Klaus (Reply 19): Does the 777 even have much of a control law transition there? |
Quoting Starlionblue (Reply 22): Here are some nice bouncers. Wind, wind and more wind. Love the QF 767 pitching down sharply at 0:35+. |
Quoting tdscanuck (Reply 23): There must be at least two...all FBW airliners that I'm aware of do some kind of pitch law modification to provide a realistic flare (C*-like control laws will render ground effect mostly invisible to the pilot without modification), and any yaw control law that looks at sideslip goes screwy on the ground (since you can't sideslip on the ground without skidding the wheels). |
Quoting Klaus (Reply 25): On an Airbus the G-force feedback loop gets broken at low speeds when elevators and ailerons simply lose too much of their control authority for normal law to function |
Quoting Klaus (Reply 25): Yeah, but the 777 is effectively in direct law all the time anyway, so the difference should be pretty minor by comparison. |
Quoting tb727 (Reply 21): Quoting PGNCS (Reply 14): the 727 is definitely the hardest aircraft to land consistently that I have ever flown. I've got a good streak going right now, like 8 of the last 10 have been pretty decent. That being said, it's over the next flight, here comes a bouncer lol. |
Quoting Klaus (Reply 25): Yeah, but the 777 is effectively in direct law all the time anyway |
Quoting PGNCS (Reply 26): Tom, is that correct that in the 777 there is a direct correlation between the yoke deflection and control surfaces like in a conventional aircraft (i.e. direct law exists at all times)? |
Quoting PGNCS (Reply 26): That is not correct. The Airbus flight controls have sufficient authority for all flight regimes in normal law. |
Quoting Klaus (Reply 28): It's been a while that I had learned about the transitions happening during takeoff and landing, but from a systems point of view the normal control loop would at low speed just lead to full control surface deflection on the slightest deflection of the stick which would not be useful. |
Quoting etherealsky (Reply 6): http://www.youtube.com/watch?v=NMmHYWjEmkY |
