united319
New Style Door Frames
Sat Apr 23, 2011 3:34 pm
Can somebody explain why airlines are re-doing the paint outline on the bottom of door frames? I know this is a random question but it's been puzzling me. Please see the pictures below for examples of what I am talking about.
This:
vs. This:
OR...
This:
vs. This:
It's Time To Fly
codc10
RE: New Style Door Frames
Sat Apr 23, 2011 3:50 pm
FARs require a contrasting paint line around the visible part of any passenger exit door. The bottom 3" or so of the doors you illustrate are actually flaps that fold inward to allow the plug-type doors to slide out of the frame to open. When the door returns to the frame during the closing procedure, the flap folds back out so that the door is physically larger than the opening in the fuselage, preventing it from opening under any circumstances while the cabin is pressurized.
united319
Sat Apr 23, 2011 4:08 pm
Quoting CODC10 (Reply 1):
I thought so. What about on Airbuses though? My airline has them on their Airbus but A319/A320/A321 doors do not have plugs or flaps.
It's Time To Fly
474218
Sat Apr 23, 2011 5:13 pm
Do you mean the stainless steel sill plate at the bottom of the door. It is there to prevent damage to the door threshold when people enter and exit!
united319
Sat Apr 23, 2011 6:26 pm
No I know what that is for, I drive jetbridges every day. I meant the outline of the door itself. The paint used to encompass the whole door rim, now it cuts off before the bottom of the door. I know Boeing Planes have the little plugs at the bottom but Airbus do not.
It's Time To Fly
Viscount724
Sat Apr 23, 2011 7:18 pm
Quoting 474218 (Reply 3):
I've always assumed that isn't painted as it would quickly get chipped and scratched from boarding/deplaning passengers' shoes.
WNCrew
Sat Apr 23, 2011 8:40 pm
Quoting united319 (Reply 4):
This is PURELY a guess, but I'd say it's just something the painters did. Not a big deal, they know the regulations, but maybe whomever was painting said aircraft just decided to go above the flap vs below it like in some of your photos. At any rate they are still achieving compliance with the FAR. I too have seen it both ways.
alasizon
Sat Apr 23, 2011 8:41 pm
My guess might be that it shows the realistic outline of the inside of the door in terms of available space to walk in. Why on the other hand...
yeelep
Sat Apr 23, 2011 9:37 pm
Quoting united319 (Thread starter):
Boeing has been delivering planes that way for a few years. I don't know why they are doing it, but I imagine there must be a reason.
Quoting WNCrew (Reply 6):
Painters use detail drawings, they are not doing this randomly.
My best guess is the color of the outline paint does not contrast enough with the sill plate.
WNCrew
Sat Apr 23, 2011 9:51 pm
Quoting yeelep (Reply 8):
Good to know! Learn something everyday...
fr8mech
Sat Apr 23, 2011 9:54 pm
Painters
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
TZTriStar500
Sun Apr 24, 2011 1:24 am
This is exactly the reason why. I found this guidance in AC 25-17A that explains this alternate compliance with 14 CFR 25.811 for exit band markings.
The FAA has been asked if compliance with §§ 25.811(f)(1) and (2) can be
found with the lower section of a two-inch colored band located a few-inches above the base of
an exit. Metal door sills are often installed on the fuselage below floor-level exits to provide
protection from impacts with loading equipment. If the band is located on the bottom edge of an
exit, its color must be compared with the door sill color to determine compliance with
§ 25.811(f)(2). This requirement can result in a color scheme which is not desired by the
operator. Note that painting the door sill is not considered a viable option since impacts with
loading equipment cause the paint to scratch and wear away quickly. If the band is located a
few-inches above the base of the exit, its color is compared with the door color below the band
instead of the metal door sill. This results in more color options for operators to choose from in
determining a desired color scheme.
35 years of American Trans Air/ATA Airlines, 1973-2008. A great little airline that will not be soon forgotten.
Users browsing this forum: Baidu [Spider], Thrusty69 and 9 guests
