WestJetForLife
Takeoff Thrust Application/abort: Your Company SOP
Mon May 16, 2011 4:15 am
Hello, everyone. Nik here again with yet ANOTHER question in regards to airline ops.
I have been watching various YouTube videos of takeoff operations from the flight deck of numerous airlines, from the Dash 8 to the Boeing 747-400. Watching these videos has piqued my curiosity.
Now, we all know that the pilot-in-command has the final say as to whether or not an aircraft's takeoff is aborted before V1. However, I have noticed that, in numerous videos, while the First Officer is in control of the aircraft, the Captain applies takeoff thrust and keeps his/her hand on the throttle levers until V1. In other cases, the First Officer (flying) has control of both the control column AND the throttle levers. In some cases even, I've seen the Captain set the thrust, take his hand off the throttle levers and let the First Officer hold onto the throttle levers until V1.
Here is what I would like to ask my 121/135/etc. pilots on the forum: what are YOUR company procedures in regards to setting of takeoff thrust or aborting the takeoff? Does the Captain ALWAYS set takeoff thrust, does the pilot flying set takeoff thrust, or is it a combination of both (First Officer is flying, Captain sets thrust, First Officer takes control of the throttle levers)?
Also, if your company SOPs state the F/O has throttle control on takeoff, does he retard the thrust levers if an abort is issued, or does the Captain take over and retard them for the F/O?
Thanks for your (hopeful) replies.
Nik
I need a drink.
Maverick623
RE: Takeoff Thrust Application/abort: Your Company SOP
Mon May 16, 2011 5:01 am
Quoting WestJetForLife (Thread starter):
This is SOP at my airline (a 121 carrier), although since the majority of our aircraft are Airbus, setting takeoff thrust simply involves moving the throttles to either the FLEX or TOGA setting.
I think this is the procedure at every airline in the US, but I'm not 100% sure on that.
Not true at all. The pilot flying will make the call to abort. The specifics of what to abort for at what speeds are in the FOM and are discussed specifically in the departure briefing.
I don't know of any airline that does this. It increases the amount of time (and therefore distance) it takes to stop the aircraft. Whoever controls the throttles, controls the throttles the whole way.
"PHX is Phoenix, PDX is the other city" -777Way
WestJetForLife
Mon May 16, 2011 5:10 am
Quoting Maverick623 (Reply 1):
Interesting. I thought it was the PIC who made the go/no-go decision to abort?
Nik
I need a drink.
wilco737
Mon May 16, 2011 5:12 am
At my airline the Captain is the only guy having the hands on the thrust levers during take off and is the only one who decides about the rejected take off. Of course I can suggest to abort it. but there is no time to discuss this decision.
wilco737
barney captain
Mon May 16, 2011 6:17 am
Ours does.
Specifically; "The Captain will be the only one to abort the take-off".
PF - advances thrust levers and presses TOGA
PM - confirms/sets take-off thrust set
Captain - places hands on thrust levers until V1
Southeast Of Disorder
WestJetForLife
Mon May 16, 2011 6:33 am
Quoting wilco737 (Reply 3):
I know LH does because of that 747-400 video on YouTube that has over 1 million views. I'd imagine most EU and English companies would stipulate the same, no?
Nik
I need a drink.
barney captain
Mon May 16, 2011 6:57 am
Quoting WestJetForLife (Reply 5):
Yes.
XFSUgimpLB41X
Mon May 16, 2011 6:59 am
at DL the PF sets power and the Captain assumes control of the throttles until V1.
If there is an abnormality that the FO notices, they call it out and it is the Captains call on the decision to abort. We have very specific high and low speed abort criteria making the judgement fairly simple.
Chicks dig winglets.
B747FE
Mon May 16, 2011 8:43 am
PF set thrust - Captain control throttles until V1.
Whoever notices anything abnormal makes the call - Captain decides. Only.
Quoting XFSUgimpLB41X (Reply 7):
B747FE.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
Mon May 16, 2011 9:41 am
Ok so here's a hypothetical situation: If the F/O (PF or not) shouts "abort" (or whatever code word you use), and you're just seconds from V1, and the Captain doesn't see why, what is the correct decision? Or do we assume the Captain always sees what the F/O sees.
tdscanuck
Mon May 16, 2011 12:14 pm
PF sets thrust and backs the throttles until V1.
PNF monitors.
Abort criteria are covered in the pre-takeoff briefing, either pilot could call it but only the PF will pull the throttles (because his/her hands are the ones on the throttles).
In our case, the correct decision would be to abort. But we always fly with two captains so the duties are a PF/PNF thing, not a rank thing.
Tom.
PGNCS
Mon May 16, 2011 3:41 pm
The FO never does that in our (or most) procedures. He states the problem and the captain decides. That's why the captain has his hand on the thrust levers.
CosmicCruiser
Mon May 16, 2011 3:59 pm
Quoting WestJetForLife (Reply 2):
Same for us. Guys
PGNCS
Mon May 16, 2011 4:33 pm
Quoting CosmicCruiser (Reply 12):
Same for us. Guys
And if my earlier post didn't make it clear, same for us, too.
David L
Mon May 16, 2011 6:46 pm
I see what you're getting at. Is the FO is supposed to call something more specific, such as "Fire!" or "Traffic!" or "Forgot the coffee!" rather than a general "Abort!"? That would still allow the PIC to decide instead of "obeying a command" from the FO.
PGNCS
Mon May 16, 2011 6:51 pm
Quoting David L (Reply 14):
Different airline procedures vary substantially, but typically, yes. The FO would call out the failure (e.g. "engine failure" or "engine fire") and the Captain would make the decision to abort or not. Most operators would not let an FO call for an abort, though there are exceptions to that generalization.
FlyMKG
Mon May 16, 2011 7:57 pm
At my airline the PF advances the throttles and call for the power to be set. Then the flight engineer reaches up to set the power. Once the engineer calls power set the Captain places his hands on the throttles until V1. All crew members monitor the takeoff and can call abnormalities but it is the Captains decision to abort or not.
FlyMKG
Essential Power, Operating Generator.
PGNCS
Mon May 16, 2011 8:43 pm
Quoting FlyMKG (Reply 16):
FlyMKG has succinctly outlined how most three-person cockpits are run. It's a good description, and I have nothing to add other than wishing my L-1011 was back!
sandrozrh
Mon May 16, 2011 10:59 pm
ditto.
Users browsing this forum: No registered users and 41 guests
