Quoting N901WA (Reply 1): . If the starter was broken, there is no way to turn the eng to start it on the ground |
Quoting aklrno (Reply 6): I realize this suggestion borders on lunacy, but I wonder if it would work if you used one engine and a fast taxi to get the other going. Or if you had a 4 engine plane could you take off on 3 and start the fourth in the air? I certainly wouldn't expect this to happen in any commercial application, but if you had a slightly broken empty aircraft on the ground in a war zone, could you get it out of the area this way? |
Quoting lke2fly (Reply 5): |
Quoting aklrno (Reply 6): Or if you had a 4 engine plane could you take off on 3 and start the fourth in the air? |
Quoting thegeek (Reply 7): Problem would come with boarding the passengers: I'm not sure on the rules for that. You may need to board them on the side with the fully functional engine, shut down. |
Quoting aklrno (Reply 6): Maybe I'm just nostalgic about being able to push start cars in the old days. |
Quoting bj87 (Reply 9): I had to push my car down the hill to start it last month. The battery was dead and really needed to be replaced which fixed the problem. Gotta love stick shift cars and living on a hill Pushing a 2ton Saab down a flat road cannot be fun. Downhill on the other hand is hilarious. |
Quoting fr8mech (Reply 2): In order to manually start the engine, a 3/8" drive extension (24"+ long) on a 'T' handle is inserted into a hole in the cowl and into a receptacle in the start valve. The valve is opened by turning the wrench. |
Quoting sccutler (Reply 10): I had a car with an automatic transmission which could be push-started. Who, here, can tell me what kind of car, and which transmission, that was? |
Quoting lke2fly (Reply 5): What he did I have no clue but i could only guess he was jump starting the engine. |
Quoting lke2fly (Reply 5): It was scary because if the the engine needed to have the APU start it, I was hoping the engine would shut off in mid flight. |
Quoting aklrno (Reply 6): I realize this suggestion borders on lunacy, but I wonder if it would work if you used one engine and a fast taxi to get the other going. |
Quoting aklrno (Reply 6): I certainly wouldn't expect this to happen in any commercial application, but if you had a slightly broken empty aircraft on the ground in a war zone, could you get it out of the area this way? |
Quoting thegeek (Reply 7): I believe the quad jet suggestion could be done legally on a ferry flight with no passengers. Could be wrong though. |
Quoting sccutler (Reply 10): I had a car with an automatic transmission which could be push-started. |
Quoting aklrno (Reply 6): realize this suggestion borders on lunacy, but I wonder if it would work if you used one engine and a fast taxi to get the other going. |
Quoting aklrno (Reply 6): Or if you had a 4 engine plane could you take off on 3 and start the fourth in the air |
Quoting Kaiarahi (Reply 17): 1950-73 Chevy with the 2-speed Powerglide transmission? |
Quoting thegeek (Reply 7): I believe the quad jet suggestion could be done legally on a ferry flight with no passengers. |
Quoting lke2fly (Reply 5): It was scary because if the the engine needed to have the APU start it |
Quoting lke2fly (Reply 5): A similar thing happen to me on a AA MD-82 flight from Tennessee to DFW. The right engine started up but fine but the left engine did not. The capt. said that we needed assistance to start the left engine. As I looked out my window I saw the MTC guy drive an APU unit right next to the engine and run some sort of lines into the engine. What he did I have no clue but i could only guess he was jump starting the engine. It was scary because if the the engine needed to have the APU start it, I was hoping the engine would shut off in mid flight. The flight did land safely at DFW..but it was scary. |
Quoting wn700driver (Reply 19): believe the quad jet suggestion could be done legally on a ferry flight with no passengers. Not legally. Ferry flights require the amount of power plants the aircraft comes with to be operative at takeoff. |
Quoting stratosphere (Reply 24): Erich, Here in the US it is common to refer to air start as an external "huffer" engine start and not the ram air in flight start you describe. |
Quoting SAAFNAV (Reply 27): People talking about taxiing fast enough to Ram Air Start... Just had to put it out there. |
Quoting SAAFNAV (Reply 27): I sure wouldn't like to be 6in away from a massive prop spinning at ~700RPM. |
Quoting KELPkid (Reply 20): Looking at my Chilton's Truck repair manual that covers all trucks sold in the USA from 1955 to 1971, just about any Chevy or GMC light truck with an automatic fits the bill on this You have to get the vehicle going 20-30 MPH depending on the rear end gearing (with the transmission in drive), and turn the ignition on Wouldn't work on a modern vehicle, though (due to the federally mandated steering column lockout) |
Quoting FlyASAGuy2005 (Reply 33): Those little DAVCO huffers were pretty LOUD though. Seemed much louder than the newer units used on Delta's narrowbodys. |
Quoting HAWK21M (Reply 34): Sure can get screechy.Talking about The loudest noise would be using a Pneumatic Jet starter on a JT8D . |
Quoting okie (Reply 18): In 56 they changed the shift lever sequence to P-R-N-D-L the in the 55 and previous the sequence was P-N-D-L-R and the Turboglide retained the P-N-D-L-R until its demise in 60 or 61. |
Quoting mrskyguy (Reply 37): That was a first. More interesting to me was the baffled mind of the Captain and the sharper "willing-to-troubleshoot" attitude of the younger first officer. |
