TakeOff
777-200: Rolling After Take-Off
Fri Jun 10, 2011 11:36 am
I was recently on a CO flight from EWR to LHR (777-200) and experienced a very strange take-off. The second we were in the air, the plane started to lightly roll first to the left and then to the right. It did this a total of four times, with every roll being more pronounced than the last one. First thing that came to mind was wake turbulence (would it cause something like that?) or a sudden gust of wind even though it was dead calm that day. Can't say I didn't get a little nervous and from the few raised eyebrows around the cabin it seemed like other passengers felt the same way. Any idea what might have caused that? The rest of the flight was the way it should be: uneventful. Thanks in advance for any responses.
TakeOff
tdscanuck
RE: 777-200: Rolling After Take-Off
Fri Jun 10, 2011 12:46 pm
Quoting TakeOff (Thread starter):
Given that it was a dead calm day, it sounds like you may have flown through the wake of another aircraft that initiated a roll followed by a little bit of pilot-induced oscillation (PIO). But that's wild speculation...could be all manner of local weather effects alone.
Tom.
wilco737
Fri Jun 10, 2011 1:11 pm
Quoting tdscanuck (Reply 1):
That came to my mind as well. Wake turbulence can be pretty strong, but maybe that one was a little while ago when the precedding airplane departed so it wasn't that strong anymore. And then the pilot maybe overcontrolled, so rolled to the other side and back and forth until it was smooth again.
Nothing to worry about
wilco737
rcair1
Fri Jun 10, 2011 1:55 pm
I had a similar experience on an A320 out of SEA the other day. When we landed, I asked the pilot and he confirmed he thought it was wake turbulence from a heavy that had departed ahead of us (headed overseas).
rcair1
louA340
Fri Jun 10, 2011 4:51 pm
I'm not an expert on this, but don't pilots sometimes roll back and forth after takeoff as a way to wave off and say goodbye to ATC?
wilco737
Fri Jun 10, 2011 5:28 pm
Quoting louA340 (Reply 4):
I have never done that and I am not intending to. At low altitudes I keep the wings level and concentrate on the departure route...
wilco737
rcair1
Fri Jun 10, 2011 5:55 pm
Only if their girl (or boy) is in the tower...
rcair1
PGNCS
Fri Jun 10, 2011 6:48 pm
Not if they want to fly for the airlines very long.
Fri Jun 10, 2011 10:31 pm
That would just be plain stupid.
RussianJet
Fri Jun 10, 2011 11:36 pm
Yeah, followed by a couple of barrel rolls.
✈ Every strike of the hammer is a blow against the enemy. ✈
alasizon
Sat Jun 11, 2011 1:25 am
Quoting RussianJet (Reply 9):
More likely followed by a pink slip.
LTC8K6
Sat Jun 11, 2011 1:33 am
tdscanuck
Sat Jun 11, 2011 5:25 am
Quoting LTC8K6 (Reply 11):
The waving goodbye seems to be common at Boeing with delivery flights.
Yes, but:
1) They're delivery flights, not commercial flights.
2) They wait until established in a stable climb and the gear is coming up before doing the roll. The OP's example started right at liftoff.
Tom.
Mir
Sat Jun 11, 2011 6:45 am
That's what the radio is for.
-Mir
LTC8K6
Sat Jun 11, 2011 10:16 pm
Quoting tdscanuck (Reply 12):
Yes, but:
Tom.
Yes, that's why I said they were delivery flights...I assumed A.netters knew what one was.
How would the OP really know "the second" they were off the ground?
alasizon
Sat Jun 11, 2011 10:19 pm
Quoting LTC8K6 (Reply 14):
Well, usually it tends to be accompanied by a gain of altitude.
LTC8K6
Sun Jun 12, 2011 1:24 am
Quoting Alasizon (Reply 15):
Yes, but what does that have to do with the comparison question I asked tds? Both situations are accompanied by a gain of altitude, I hope.
tdscanuck
Sun Jun 12, 2011 6:43 am
It depends a great deal on how in tune the OP was with the aircraft but, once you know what you're looking for, the feeling of the MLG coming free of the runway surface is quite distinctive. There is a pulse from the oleos bottoming out and a change in the aircraft motion as the center of rotation moves from the MLG pivot to the aircraft CG. Even on an aircraft the size of a 777 it's quite easy to pick out.
Tom.
ShyFlyer
Mon Jun 13, 2011 12:08 am
Never heard of that, but rocking of the wings is a way for one aircraft to signal to another that they have been intercepted. The intercepted aircraft will also rock their wings to acknowledge the intercept.
https://www.faasafety.gov/files/gslac/courses/content/24/293/Interception%20Procedures.pdf
But the OP's 777 wasn't being intercepted.
cvg2lga
Mon Jun 13, 2011 12:27 am
Rocking the wings: That's how we said goodbye to Seattle onboard N624US on the retirement party's flight back to MSP. FWIW.
Tchau
DA-
They don't call em' emergencies anymore. They call em' Patronies.
Woof
Wed Jun 15, 2011 9:18 pm
PIC holding the column between his legs while trying to light a fag (cigarette for you US folk   ) ?
Deleted
MrFord
Thu Jun 16, 2011 8:59 pm
Maybe a long shot, but could it be related to MARINER2 SID?
On departure from the 22s, there's a slight left, then right turn right after takeoff
"For radar identification throw your jumpseat rider out the window."
wilco737
Thu Jun 16, 2011 9:05 pm
Quoting MrFord (Reply 21):
4 times is a little much for that departure. But could've been.
wilco737
MrFord
Fri Jun 17, 2011 3:48 pm
Quoting wilco737 (Reply 22):
That was my thought too, but at least the first 2 would fit the bill, if they departed south.
star_world
Fri Jun 17, 2011 6:31 pm
Having flown out of EWR hundreds of times (most of them from 22R) I am certain that this is what the OP experienced. The turn can be at a dramatically low altitude on a widebody a/c, and there are frequently further turns required due to vectoring by ATC or due to weather.
The OP could always check liveatc.net or flightaware.com to hear the ATC comms during the departure, or see the route taken.
Users browsing this forum: aerotech777 and 15 guests
