highliner2
737 A/C Question
Thu Jul 14, 2011 10:26 pm
I have a question regarding the 737 window configuration.
I know on most 737NG's (I thought all), the A/C risers come up throught the fuselage just ahead of the wing. I stumbled upon a photo of a Miami Air 737 however.
https://www.airliners.net/photo/Miami...d=db89aa9bef4a6fbfe2c7337c08ac4856
Now on every other NG I've seen, the section where the risers come up through the fuselage, there is no window, not even a blanked out window panel like you see near the galley on some aircraft depending on their configuration.
It appears that there isn't even an opening in the fuselage for their to be a window.
On this aircraft, it appears that not only is there a window, there's some sort of grey window shade or something.
Anybody know what the deal is with this aircraft? Some sort of special configuration?
Thanks.
-lou
Go Cubs!
boeingfixer
RE: 737 A/C Question
Thu Jul 14, 2011 10:46 pm
Quoting highliner2 (Thread starter):
My guess is that they are painted on. Keeps the window line undisturbed visually.
John
Cheers, John YYC
Sat Jul 16, 2011 10:01 am
Looks like a paint job to cover the Metal blanks at the areas concerned.
IFixPlanes
Sat Jul 16, 2011 4:15 pm
I think that it is only painting. There are no window-frames at this positions.
never tell an engineer he is wrong ;-)
boeingfixer
Sun Jul 17, 2011 4:40 am
Is there an echo in here.... here.... here
Cheers, John YYC
IFixPlanes
Sun Jul 17, 2011 6:33 am
I only want to clear the point, that there are no Plugs.
longhauler
Mon Jul 18, 2011 1:29 pm
Swissair used to do the same thing. They would paint in windows to keep an aesthetically pleasing line.
Photo © Alastair T. Gardiner - WorldAirImages
Wed Jul 20, 2011 9:15 pm
Quoting IFixPlanes (Reply 5):
True.
AA737-823
Fri Jul 22, 2011 11:55 am
Notice that there are TWO odd looking (painted-on) windows on that Miami air jet.
They're coincidentally in the same place as the TWO risers that the -800/-900 series have on the left side...
I would NEVER have caught this- very good eye, there!
dandaire
Fri Jul 22, 2011 4:54 pm
Photo © Urs Hess
See here just forward of the wing there is even a oneworld (i believe it is) sticker actually over the false window.
Old age and treachery will triumph over youth and skill.
Tod
Mon Jul 25, 2011 8:02 pm
Quoting dandaire (Reply 9):
No false window at the frame bay with the sticker.
The next location aft is a functioning lav window.
dandaire
Mon Jul 25, 2011 10:14 pm
Quoting tod (Reply 10):
Look just aft of the second door where the sticker is over the window??
Tod
Tue Jul 26, 2011 12:44 am
Quoting dandaire (Reply 11):
DOH!
I was looking at door 1.
Aft of door 2 should be a set of J class lavs (no window) a little bit aft and a stowage or a galley unit right aft of the door. I know that I put plumbing provisions there, but QF is good about reconfiging between there and the start of the wingbox.
Users browsing this forum: Baidu [Spider], unimproved and 8 guests
