Quoting rwessel (Reply 1): There’s nothing wrong with aluminum as electrical wiring. |
Quoting Dreadnought (Thread starter): So if aluminum wiring is considered a bad idea for houses, how is it a good idea in an airplane? |
Quoting Dreadnought (Thread starter): How many other planes have aluminum wiring? |
Quoting kalvado (Reply 9): As a matter of fact, internal chip wiring switched from aluminum to copper a few years ago. gold is only used as contact pad plating. |
Quoting 474218 (Reply 14): Copper cable is spliced on the ends of the aluminum cable just prior to the terminations. |
Quoting YokoTsuno (Reply 13): I am afraid that this is not the case. Aluminium, copper, as well as gold are/were used as bonding wire in microchips. It all depends on the price of the chip. The decision which metal to use is based on the same criteria. That's for instance the reason why aluminum is generally not used for high power semiconductors since the required thicker wire is hard to do within a limited space. |
Quoting YokoTsuno (Reply 8): - It has a considerable higher electrical specific resistance, which means that for the same current the wire diameter must be larger, to keep loss in check. |
Quoting YokoTsuno (Reply 8): - It immediately forms a protective alluminium oxide layer in contact with air. This layer is a bad conductor which is the cause of the connection problems. |
Quoting YokoTsuno (Reply 13): The aluminium connection problem is not an issue in microchips because the wire is welded onto the pin contrary to electrical wiring in buildings which is just fixed by a screw in a terminal. I don't know much about aircraft but I assume they use similar techniques to make a proper aluminium connections in the aviation industry. |
Quoting MD11Engineer (Reply 20): |
Quoting MD11Engineer (Reply 20): For aluminium/copper connections there exists special splices, which prevent dissimilar metal corrosion issues |
Quoting Baroque (Reply 22): 2) A380 is the first plane in the world to use that technology for smaller cables (e.i.: up to #22 contact with #24 cables) but we used aluminium/cooper cable with nickel plated, and not pure aluminium cable (e.i.: each wire is aluminium with 10µ of cooper around and 2µ of nickel deposit). |
Quoting Baroque (Reply 22): I had already answer few times about these questions on aluminium cable technology on A380, but I will do it again with pleasure. |
Quoting YokoTsuno (Reply 24): The poor guy has given up this time. |
Quoting YokoTsuno (Reply 24): This copper was plated with tin, I believe to prevent the chemicals in the rubber from reacting with the copper. |
Quoting 474218 (Reply 16): I am not sure, but since we are talking wires that are up to 1/4" in diameter I don't think they make crimp sleeves that large! |
Quoting litz (Reply 26): Go take a look at the battery cables in your car ... 1/4" or larger, and crimped connectors ... if you have an older car that's had cable repairs (due to acid damage), you probably even have some butt connector sleeves crimped on there, too, to restore proper wire length. |
Quoting 767eng (Reply 29): I have no doubt though using aluminium for the small gauge wires will turn into a maintenance nightmare in the later life of the A380 with all sorts of niggles caused by oxidisation at joints and connections. Time will tell. |
Quoting Baroque (Reply 30): Quoting 767eng (Reply 29): I have no doubt though using aluminium for the small gauge wires will turn into a maintenance nightmare in the later life of the A380 with all sorts of niggles caused by oxidisation at joints and connections. Time will tell. Time will tell, but how do you suppose the oxidation will get through the copper co-extrusion and the nickel plating? |
Quoting MD11Engineer (Reply 32): Cracks and damage to the plating, especially, where the insulation has been removed where the wire is being inserted into the crimped terminals. |
