AlnessW
How Are Boarding Times Determined?
Tue Apr 10, 2012 1:13 am
The amount of time given for a flight to board seems to vary greatly. For a "typical" US domestic narrowbody flight, the standard seems to be 30 minutes. But my recent UA flights boarded 45 minutes prior to departure...
How are these and other times determined? Here are a few ways I can think of:
International flights and/or widebodies seem to board much earlier, as there are simply more people traveling. I assume that this is also because the gate agents need extra time to check passports, etc.
RJ flights seem to board with less time. Last year I was on a UA Express flight SFO-PDX (on the old UA) and they boarded 20 minutes prior to departure. This would make sense as there are simply fewer people to process. But just a few weeks ago I was on another UA Express flight PDX-SFO (on the new UA) and they were scheduled to board 35 minutes prior to departure! Why would a RJ need 35 minutes to board? (But of course, they didn't actually start boarding and didn't make any announcements whatsoever about SFO delays until 15 minutes before we were scheduled to leave...)
So... How are boarding times determined? I'm not really looking for personal stories here, but rather technical factors as to how a flight's scheduled boarding time is calculated. Thanks!
citationjet
RE: How Are Boarding Times Determined?
Tue Apr 10, 2012 4:48 pm
Quoting AlnessW (Thread starter):
When you say they were "scheduled" to board, are you referring to the time posted on the gate departure board, when the gate agent verbally announces when they will begin boarding, or the boarding time posted on your boarding pass?
I believe these are general guidelines, and in reality they usually start boarding after these posted times have passed, either due to late inbound flight, or the aircraft not being cleaned and is not ready for boarding passengers.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,73G,738,739;741,742,743,744,747SP;752,753;762,763;772,773,788.
chuchoteur
Tue Apr 10, 2012 5:01 pm
http://www.airbus.com/support/airport-operations/library/
Check out the airport compatibility manuals.
http://www.airbus.com/fileadmin/medi.../Airbus_AC_A320_20110501_Apr11.pdf
Page 157 of the A320 airport planning manual shows the boarding/deboarding rates that Airbus recommends (for example).
Those are (I believe) demonstrated values.
Boeing has equivalent documentation:
http://www.boeing.com/commercial/airports/plan_manuals.html
737:
http://www.boeing.com/commercial/airports/acaps/737sec5.pdf
CH 5.2.5 shows planing/deplaning flows
KELPkid
Tue Apr 10, 2012 6:28 pm
They might have allotted this flight more time because SFO-PDX on UA connects with lots of TransPac flights at SFO. I wouldn't be suprised if many of the passengers on your flight were actually making international connections in San Francisco. International passengers are allotted more baggage
Fabo
Wed Apr 11, 2012 12:21 pm
Airlines, especially those with some tradition, have a lot of empirical data to build on. They can base off the recommended typical times, as outlined for ex. in the Airbus manual, and build up on them depending on destination, day of the week, typical traveller, airport layout, time of the day etc.
As an example - flight to Hawaii will take longer to board because of all the vacation goers, baggage, pax being unfamilair etc. Same 767 doing London-Paris would be more or less business types, travelling light, knowing how to be orderly.
If the airplane is at a jetway gate, you have to assume pax are in the aircraft as soon as boarding is started. If in the fields, you have to make some time for them to get out, board the bus, take a scenic tour of the airport... in the extreme example, you know FR takes 25 minutes to turn around a 738. There are actually cases that boarding is readied when airplane is not even on final approach yet.
The passenger mix is different on wednesday mid-morning flight than it is on saturday early afternoon flight, etc...
Gate agents might also delay or move the boarding earlier if they see some specific groups in the mix - if you see that a children choir booked half the aircraft, you know you need to board sooner, because they will take their time...
The light at the end of tunnel turned out to be a lighted sing saying NO EXIT
SchorschNG
Wed Apr 11, 2012 4:38 pm
Data from the manufacturers is more a joke than any useful guidance. The time to board varies strongly with load factor, passenger population, luggage density. The type is less of a factor.
Most airlines use experience.
Any many airlines experience boarding as a huge burden as turnaround is the only time period where you can make time good on your schedule. Speeding with .81 instead of .78 on a 500nm trip doesn't win anything except a higher fuel bill.
From a structural standpoint, passengers are the worst possible payload. [Michael Chun-Yung Niu]
Pihero
Wed Apr 11, 2012 4:46 pm
Ground handling of an airplane is a fine art that involves a lot of people and quite a few services.
That's why most airlines have some standards laid out in the form of "Punctuality sheets", "Standards and chronology guidelines", the names vary but the principles are the same : everybody, every department participating in the turn-around are involved and have to follow some rather strict set of timings.
On these sheets, in which H-hour is the scheduled departure time (from the gate ) (example is for a long-haul widebody) :
- Cabin cleaning and catering uplift completed at H-45
- Passenger boarding call at that moment... First pax on-board at H-40... ... Doors closed at H-4 ... ... Cargo doors closed at H-3.
For a single-aisle aircraft, Boarding call is at H-30, with the first pax boarding 5 minutes later.
Of course a different sheet will be used for an aircraft away from a contact gate and the ramp coordinator is supposed to work his chronology from the travel time taken by the coaches from the terminal to the apron..
Nothing should be left to chance or personal improvisation.
[Edited 2012-04-11 10:43:09]
Contrail designer
AlnessW
Wed Apr 11, 2012 5:24 pm
Quoting CitationJet (Reply 1):
I was referring to the time printed on the boarding pass. Sorry I didn't specify there.
That seems to be the case, for me anyways...
Quoting chuchoteur (Reply 2):
Thank you for sharing those links. Interesting info!
Quoting KELPkid (Reply 3):
I'm not sure about that. We were scheduled to arrive at 9:33 at night. (Though didn't actually arrive until 10:30 thanks to the usual SFO delays.   ) Do you know what SFO connections are like around that time of day on a Saturday?
Quoting Fabo (Reply 4):
We can't assume that though. I mean, I understand that airlines need SOMETHING to go off of, but to make a gross assumption like the one above is simply wrong. Just because there are families traveling together doesn't necessarily mean that they are "inexperienced."
See my comments above. "Business" does not always equal "Orderly." I have seen plenty, PLENTY of business travelers being disorderly, ignoring the order of boarding, ignoring carry-on limits, pushing and shoving, etc. They are my second-to-least favorite type of person to travel with. School/youth groups are worse, though.
Good point. You are definitely correct there.
 Wow! Wow!
You've got that right.
Quoting SchorschNG (Reply 5):
Interesting to know.
I am not sure what this means but I think you are talking about time on the ground.
chuchoteur
Wed Apr 11, 2012 8:00 pm
...is that so?
So evacuation times are also incorrect as that would depend on passenger population etc?
Of course, the items you quote should be taken into account by an airline when calculating turn around times.
Data from manufacturers are of course subject to the assumptions used (and if you check those links they are listed, particularly in the Boeing manuals that reference different sets of assumptions).
The type can very much be a factor, if you look at the manuals for A vs B, the 737 has a slower boarding/deboarding rate (in effect, due to the slightly narrower door). The overall turn around time achievable (20 minutes listed in the Boeing 737-800 manual) compensates for this in other areas (vs. an indicative 22 minutes unthe A320 manual).
The low cost carriers flying A320 family aircraft would also not have chosen the slightly wider aisle if they didn't understand the benefits in terms of pax flow rate through the cabin.
The major factor (in my opinion) is the airline/airport set-up.
Consider Air France trying to go down to 40 minute turns on domestic "La Navette" flights (A320 family a/c) vs. SAS achieving 20 minute turns (domestic) and 30 minute turns (international), also using A320 family a/c (and 737 a/c in Norway).
Airbus claimed that the A380 could be turned around in 60 minutes (as per what Emirates wished) and this was actually demonstrated in DXB (using Emirates ground staff). So your statement on manufacturer data being a joke is totally incorrect. However, you are free to disagree with the assumptions used!
KELPkid
Wed Apr 11, 2012 8:37 pm
Quoting AlnessW (Reply 7):
Well, for starters, SQ1 departs around 1:20 AM daily...lots of other TransPac flights depart around the same time
Pihero
Wed Apr 11, 2012 8:59 pm
Quoting chuchoteur (Reply 8):
strange statement when that has been done - and bettered -for years and considering that it is just 5 minutes shorter than the "normal" medium-haul turn around on 319s (add 5 mins for a 321 ).
I'd like to see the kind of uplift and service SAS do on their domestic flights.
Best and quickest turn-around ? See the Koreans in the Gulf : 15 mins on a320 is usual ops.... and contracted, too.
Contrail designer
chuchoteur
Wed Apr 11, 2012 9:17 pm
Quoting Pihero (Reply 10):
Quoting chuchoteur (Reply 8):Consider Air France trying to go down to 40 minute turns on domestic "La Navette"
Pihero, you are right. They're trying to go down to 30 minutes, my fingers slipped
I actually had the opportunity to spend a lot of time with SAS both at their Oslo & Stockholm hubs.
The catering etc is pretty much similar to other european mainline carriers (they now serve complimentary hot drinks free of charge, and they have pretty lively onboard sales - snacks mainly, quite a few of their sectors are over 2h).
Cleaning and servicing is pretty standard.
The big thing they have going for them is pretty organised airports (both in Oslo and Stockholm, they are easy to navigate as well). They've also invested heavily in their infrastructure and communications systems to control how their aircraft are brought in and turned around - they actually sell it to other airlines.
They have a pretty smart "press to talk" mobile phone system. The flight crew log in a duty cell phone and right the way through they use it to talk to ground ops, regardless of what airport they are at (the system logs and routes the calls automatically) so they don't waste too much time if something is required.
At Oslo they have 3 controllers overseeing 40+ aircraft simultaneously, so it works pretty well.
Some flights require quite a lot of catering, they still have a nice route that hops along the coast stopping at all the regional airports along the way...
Well worth checking out if you happen to go over there, they are aways happy to show how they are set up.
AlnessW
Thu Apr 12, 2012 5:11 am
That would make sense.
You make a valid point there.
Quoting KELPkid (Reply 9):
Good to know. Thanks!
SchorschNG
Fri Apr 13, 2012 12:59 pm
The manufacturers numbers can be achieved, but they are generally "best case" data. Airbus assumes a boarding rate of 14-18 passengers per minute using a single door for their A319/320/321. People familiar with that matter will tell you, that those rates are possible, but 10 people per minute are more likely.
Calculate yourself next time: when did boarding start, when did it finish. How many people in how many minutes. I am quite confident that more than 10 people per minute are a rare occurance.
SAS uses stairs, and probably two of them. Then boarding isn't such a problem.
You think Delta will start to use stairs in Atlanta?
The Airbus ACAP quotes similar times for turnaround for A319 and A320, and simply increases the passenger boarding rate. Boeing numbers are more reliable. The door is not an issue in the single aisle, it is the aisle.
Next time you fly check where you start queueing: it starts in the aisle, continues through the door into the passenger bridge. Wider doors for faster boarding is like a wider ramps to prevent traffic jam on the Autobahn.
Wider aisle is a factor, however, the effect is hard to analyze. Again, passenger behavior is key. Low costers do not assign seats for exactly that reason. They encourage people to press for their desired seat, and a wider aisle gives the passenger the tool for it. No need on a regular domestic flight: you don't need to press to your seat when it is assigned.
That is one reason (beside many others) deboarding is much faster than boarding: people want to get out, because 5 seconds earlier means 5 seconds lifetime saved. 5 seconds earlier on your (assigned) seat at boarding means ... nothing.
Fabo
Fri Apr 13, 2012 2:06 pm
Indeed neither of those are ALWAYS the case. If it were... what would you do if the businessman and his businessman wife take their businessman child to Hawaii?
However, in general, families with children, and especially vacationgoers, DO take longer time than business crowd.
Yes of course there are families that fly each winter to Carribean, each summer to Medditerranean, and twice a year to Grandmas, and those can be, and indeed often are, faster than some of the businessmen, but they are far from the norm (although I will admit I do not know much about tourism in the US - so maybe Hawaii was a bad example?)
chuchoteur
Fri Apr 13, 2012 6:08 pm
Quoting SchorschNG (Reply 13):
Interesting points.
SAS normally use two sets of stairs, and it certainly makes things quicker/easier.
- except in OSL where only the jetbridge is used.
Assigned seating, standard aisle (vs. wider aisle). and having spent two weeks with their airport ops, the choke point on the 737 starts initially at the door (as people fold/collapse telescoping bag handles) then moves into the cabin.
Where they shine is in their organisation on the ground. Which comes back to the airport/airline set-up being the key to a good turn around time...
AlnessW
Fri Apr 20, 2012 5:07 am
Quoting Fabo (Reply 14):
What's this mean? I think you are getting a bit off-topic here. I am not trying to start an argument about who boards the fastest or slowest.
That's why families with children are usually given the option to pre-board. See my comment above.
Quoting chuchoteur (Reply 15):
Interesting to know, thanks.
CONTACREW
Wed Apr 25, 2012 10:40 pm
Boarding times at UA :
747/777/767 50 minutes prior to departure
757 - 45 minutes prior to departure
737/A319/A320 - 35 minutes prior to departure
Flight Attendants prepare doors for departure, cross check verify straps standby for all call
AlnessW
Sun Apr 29, 2012 12:11 am
Quoting CONTACREW (Reply 17):
Thanks for clarifying!    Exactly what I was looking for. Now, I assume that these are the times for the "new" UA. Becuase when I would fly the "old" UA, they boarded seemingly all narrowbody flights 30 minutes prior to departure. Except for RJs, which were 20 minutes prior to departure.
And 35 minutes for RJs, right?
CONTACREW
Mon Apr 30, 2012 7:35 am
Quoting AlnessW (Reply 18):
Yes 35 min for RJs as well, but it also depends on when the previous flight arrives so let's say your flight is going idk EWRBDL on the EMB145, scheduled departure time is 9:10p with a
Yes those are new boarding times which are actually boarding times from the sCO side of the airline. For RJ flights the boarding times are advertised as 35 minutes prior to departure, however due to other circumstances i.e. late arriving aircraft or crew, the boarding will get pushed back a bit. For instance I just flew on an EMB145, and the inbound was supposed to arrive at 1:30 with a departure time of 2:20, boarding at 1:45p, however the aircraft didnt arrive till 1:45, boarding at 2:00 and only left a few minutes behind scheduled at 2:25.
AlnessW
Fri May 04, 2012 3:46 pm
Quoting CONTACREW (Reply 19):
With a what?
Ah, I see.
I experienced that, too. I few months ago I was flying PDX-SFO on a UA Express/OO flight on a CRJ200. Scheduled departure time of 19:40, with boarding at 19:05. For some reason, boarding didn't actually start until 19:25, and we pushed back a few minutes late.
CONTACREW
Sat May 05, 2012 7:01 am
Quoting AlnessW (Reply 20):
With a what?
lol sorry about that it was supposed to say with a boarding time of 8:35p
