MountainFlyer
What Are These Doors?
Fri Apr 13, 2012 9:28 pm
Does anyone know what the doors are on the front of the JT-3Ds on the 707-320B? In these pictures, they appear to be open during takeoff, and closed during decent. What is their function?
My shot in the dark guess is something having to do with diverting bypass air into the engine core during high power settings.
Photo © Sam Chui
Photo © Shahram Sharifi - Iranian Spotters
SA-227; B1900; Q200; Q400; CRJ-2,7,9; 717; 727-2; 737-3,4,5,7,8,9; 747-2; 757-2,3; 767-3,4; MD-90; A319, 320; DC-9; DC-1
Fabo
RE: What Are These Doors?
Fri Apr 13, 2012 9:36 pm
they allow additional air into the engine, bypassing the inlet, when air demand is high (at high power setting)
The light at the end of tunnel turned out to be a lighted sing saying NO EXIT
larshjort
Fri Apr 13, 2012 9:38 pm
They provide extra air to the engine at high power settings. They are actuated by the low presserue in the inlet, when it is low enough they will open.
/Lars
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
KELPkid
Fri Apr 13, 2012 11:57 pm
They are called "Blow-in doors", and they make the engines scream when they blow in   Boeing had them on early 737's and 747's, too...
Viscount724
JT9Ds on early-model 747-100s also had them. You can see them open in the following photos. The engines were later modified and the blow-in doors removed.
Photo © Bill Sheridan
Photo © S. M. Reeves
Photo © Art Brett - Photovation Images
Photo © Mick West
akiss20
Sat Apr 14, 2012 1:23 am
Did they do this because the flow went sonic at the face of the inlet but they didn't want to increase the inlet area because they didn't need the diameter in the fan?
Change will not come if we wait for some other person or some other time. We are the ones we've been waiting for. We are
Accidentally
Sat Apr 14, 2012 1:45 am
Why were they ultimately deemed unnecessary and removed?
Indianapolis, IN
tdscanuck
Sat Apr 14, 2012 4:26 am
Quoting akiss20 (Reply 5):
The flow can never get sonic at the fan face (aerodynamics won't allow it). The problem was getting enough air into the inlet at high power and low speed without separation around the inlet leading edges and acceptable pressure loss.
Tom.
Fabo
Sat Apr 14, 2012 4:48 pm
Quoting Accidentally (Reply 6):
They made the engines too noisy. Inlet diameter and shape was tweaked instead.
Sat Apr 14, 2012 7:44 pm
The Inlet cowl Blow in doors were common on the early JT8D-7s too.....
DL_Mech
Sat Apr 14, 2012 9:39 pm
Here's a good video of the "sucker doors" in operation:
http://www.youtube.com/watch?v=Sf3mo3QROC8
This plane is built to withstand anything... except a bad pilot.
Viscount724
Sun Apr 15, 2012 12:31 am
Quoting HAWK21M (Reply 9):
Some early 737-200s with the blow-in doors visible. I don't think they existed on the 727.
Photo © Mel Lawrence
Photo © Jan Olav Martinsen
Photo © Bob Leask
Photo © Alex Christie
Why did those doors only seem to be used on Boeing types? I can't recall a similar feature on other types that used the same engines (e.g. JT3D on DC-8, JT8D on DC-9)?
AirframeAS
Sun Apr 15, 2012 1:49 am
Quoting DL_Mech (Reply 10):
I take it that video was filmed at KIWA!!! Awesome video!
Sun Apr 15, 2012 8:39 am
Quoting Viscount724 (Reply 11):
The later JT8Ds beyond the -7 did not utilize the blow in doors on the Inlet cowl on the B732.
strfyr51
Wed Apr 18, 2012 9:19 pm
fan inlet doors for supplimental air to be available for the turbofan at takeoff thrust, later found not to be needed as better inlet cowls were built
Users browsing this forum: MDGLongBeach and 24 guests
