Quoting wilco737 (Reply 1): The 748 has LCD screens, it has another Puch to talk switch next to the window, the chronograph has been removed, a checklist curser switch is next to the thrust lever, |
Quoting BoeingGuy (Reply 2): LCDs have been on the 747-400 for years. |
Quoting BoeingGuy (Reply 2): 7) RAAS (Runway Advisory and Awareness System) in EGPWS is at least on LH's 747-8s (not sure about other customers) |
Quoting rendezvous (Reply 3): So the checklist cursor control is where the stabiliser trim indicator was. Is that trim indication now on the EICAS instead? I assume that's the case for the clock/timer? |
Quoting KAUSpilot (Reply 5): There is a ram air turbine switch on the top right side of overhead panel. |
Quoting KAUSpilot (Reply 5): There is a "center air data" selector on the top right side of the overhead panel. |
Quoting KAUSpilot (Reply 5): There are no autostart or ignition switches on the overhead panel. |
Quoting wilco737 (Reply 4): All our 744's have the RAAS as well, a system I like. |
Quoting BoeingGuy (Reply 7): I indirectly covered that when I mentioned the 3 ADIRUs. Actually, this is not new to the -8. Some 747-400s had a third ADC and this switch as a priced option. |
Quoting KAUSpilot (Reply 5): There is no aft cargo heat switch. |
Quoting KAUSpilot (Reply 5): There is no lower lobe cargo conditioned air flow rate selector for freighters, instead there is a lower lobe aft cargo heat selector on the overhead maintenance panel. |
Quoting KAUSpilot (Reply 5): There are no start valve lights in the engine start switches on the overhead panel. |
Quoting KAUSpilot (Reply 9): Quoting BoeingGuy (Reply 7): I indirectly covered that when I mentioned the 3 ADIRUs. Actually, this is not new to the -8. Some 747-400s had a third ADC and this switch as a priced option. True, several of the freighter and passenger -400's I fly do have the center ADC, however the dedicated switch on the overhead is a new addition in my experience; the -400's with the 3rd ADC that I've flown simply have an extra detent for the ADC selector on the "instrument source select switches" outboard of the clocks on the instrument panel. Do some -400's have the center ADC switch on the overhead? Thanks for the info! |
Quoting sevenheavy (Reply 8): I am somewhat surprised there isn't more "787" style technology |
Quoting BoeingGuy (Reply 18): |
Quoting wilco737 (Reply 1): The EFB at the LH airplane will be added from LH within the next weeks afaik. |
Quoting BoeingGuy (Reply 2): 2) Electronic Checklist (ECL) |
Quoting KAUSpilot (Reply 5): As mentioned, the display select panel with the system synoptic switches has been completely redesigned to allow the lower EICAS (now MFD) and each inboard display to be triple redundant and to accomodate the electronic checklist controls. There are electronic checklist cursor controls on the center control stand where the pitch trim indicators are located on the -400. |
Quoting smartt1982 (Reply 6): What sort of training would the pilots need to undertake, when changing over? |
Quoting CM (Reply 19): Thanks for that! Yes, the map is on the ND. I began that post intending to mention the improved ability of the WXR to distinguish high altitude weater formations. However, as Zeke pointed out, not all 747-8 functionalty has been delivered at this point. In the case of the WXR enhancements, it's also not something which was ever intended for EIS, just something new the airplane is capable of. |
Quoting CM (Reply 24): Actually, I was thinking of the upgradability of that system to add the capability to call out anvil tops, hail and other wether forms which are (today) not discretely identified in the way we display the radar returns. |
