vikkyvik
Kai Tak Approach Lights
Wed Mar 27, 2013 4:35 am
This has been puzzling me for years now. In various shots of Kai Tak, the approach lights are sometimes red:
Photo © Lawrence Chiu
Photo © Alan Tsui
...and sometimes white:
Photo © Samuel Lo
Photo © Olaf Juergensmeier
Did they actually change the color at some point? Were they changed to let an approaching aircraft know whether to continue the approach or not? Or a departing aircraft whether to depart / enter the runway or something? Why haven't I asked this question in the ~8 years I've been wondering about it?
Thanks for any insight.
RE: Kai Tak Approach Lights
Wed Mar 27, 2013 4:42 am
Discounting the Emirates one because it is taken from the runway outward, while the other three are from outwards towards the runway.
In the BA and QF pics they are the same color (white + white/green for the threshold). In the CX pic the threshold lights are white/green, just like in the BA and QF pics. However as you say in the CX pic the two rows behind the threshold lights are red, while they are white in the BA and QF pics.
The obvious difference is that the CX plane is lined up to take off, while the QF and BA planes are approaching.
Interesting...
[Edited 2013-03-26 21:44:29]
vikkyvik
Wed Mar 27, 2013 5:15 am
Quoting Starlionblue (Reply 1):
Not sure I understand - the runway threshold and approach lights are visible in that image above the two aircraft. The first roll bar of the approach lights is visible on either side of the light pole.
Indeed. That's why I wondered whether they could be switched to warn approaching aircraft not to land (maybe because the offset approach makes checking runway clearance more difficult?).
Wed Mar 27, 2013 6:14 am
Quoting vikkyvik (Reply 2):
Maybe, but you could certainly see the runway on approach, perhaps even better since given the angle you could more easily see how far along the runway other aircraft were. And wouldn't the tower know?
Heh. I see it now. I thought that picture showed the southeastern end of the runway. Now that I think about it, it shows the northwestern end as you say.
CCA
Wed Mar 27, 2013 7:55 am
It's the angle of the approach if you're too low (dangerously low) they're RED so everything from ground level is red a normal approach is white so the elevated pics are white as they should be. The PAPI would be all red before the approach lights were seen as red.
[Edited 2013-03-27 01:04:24]
Enthusiast
Wed Mar 27, 2013 8:40 am
Quoting CCA (Reply 4):
If you were that low at Kai Tak you were probably in some old Chinese granny's living room.
FlyASAGuy2005
Wed Mar 27, 2013 12:19 pm
That would be the PAPI lights guys.
What gets measured gets done.
Wed Mar 27, 2013 12:42 pm
Quoting FlyASAGuy2005 (Reply 6):
The lights mentioned are on the runway surface before the threshold. The PAPI lights are visible on both sides of the runway.
Pihero
Wed Mar 27, 2013 2:45 pm
An interesdting set of pictures which bring back fond memories of Kai Tak:
The airport had some non-standard approach lights because of the RWY 13 geometry.
- Directional white lights were used for low visibility conditions.
- On the same pylons, one would have omni-directional red lights to remind aircrews of the displaced touch-down zone for good visibility conditions. The first picture shows very accurately the twin-bulb set-up of the approach lights.
- The two red bars - in front and behind of the departing airpalne on the first picture - were also used by the Tower control as **stop** bars, switched to white with one's takeoff clearance.
There is a puzzling feature in this picture : there used to be a 4-light PAPI but apparenhtly we only see 3 lights . I don't remember the PAPI being downgraded before the closure of the airport.
Contrail designer
intsim
Wed Mar 27, 2013 4:53 pm
Quoting Pihero (Reply 8):
It looks like the fourth light is behind the CX 744 vertical stabilizer. There is red light to the left of the tail that doesn't look like it could come from the three visible lights. I think the fourth light on the left set is just cut out of the picture.
Pihero
Wed Mar 27, 2013 6:34 pm
Quoting intsim (Reply 9):
You are right : one can see the glare of that light.
Many thanks for clearing it up !
Regards.
Contrail designer
Users browsing this forum: DCA350 and 20 guests
