Rexus
Cargo Compartment Dimensions
Wed Sep 10, 2014 3:29 pm
Hi guys,
I'm looking for data about the sizes, especially the heights of the cargo compartment on passenger aircraft.
What I've found by now:
B737NG: around 1.12m
A320: 1.19m
Does anybody know about the heights of the E190/E170 cargo compartment aswell as for the B757/767/777 or A330/A340 series?
hufftheweevil
RE: Cargo Compartment Dimensions
Wed Sep 10, 2014 5:45 pm
You can find all the Boeing tech specs here: http://www.boeing.com/boeing/commercial/airports/plan_manuals.page
But in general, all widebodies are about 64 inches (1.5m) to fit the standard containers.
Huff
Woodreau
Wed Sep 10, 2014 6:00 pm
I don't know about the E-170/190 cargo comparments personally, but I hear lots of antedotal conversations about how rampers hate the E-170/190 because there's isn't enough room to kneel AND throw/stack the bags.
The Embraer Airport Planning Manuals give the heights of the cargo compartments as 2ft 11 inches on the E170 and 3 ft on the E190.
http://www.embraercommercialaviation.com/AMPS/APM_170.pdf
http://www.embraercommercialaviation.com/AMPS/APM_190.pdf
And here are the links to the Airbus versions.
http://www.airbus.com/support/mainte...cal-data/aircraft-characteristics/
[Edited 2014-09-10 11:03:09]
[email protected]
Thu Sep 11, 2014 8:14 am
Don't know the specific height for each aircraft, but for widebody aircrafts is common that cargo max height is 1.60 m + the ULD itself and the cargo net
CrimsonNL
Thu Sep 11, 2014 12:34 pm
Quoting Rexus (Thread starter):
E190
For the E90/E95 it's 94cm in the fwd hold, and 92cm in the aft hold. Though from the aft cargo door to the tail the height decreases because of the shape of the fuselage. I think the E70/75 have similar dimensions
Martijn
PanHAM
Fri Sep 19, 2014 2:14 pm
In order to determin whether a bulk loaded piece of freight fits through the door you need all three dimensions. If no "up " marks are on the box, the width can be the height as well, or the lenght. The charts are available if you check the net or have the relevant books on hand.
Generally, wide body bellies allow ULDs loaded up to 160 cm height
Was Erlauben Erdogan!!!
FlyDeltaJets
Sun Sep 21, 2014 8:06 pm
E170 was designed by Bond villains, not only is the ceiling extremely low there are metal smoke detector and light grills that bulge out of the ceiling that I believe are placed strategically to bang your head on.
The only valid opinions are those based in facts
Users browsing this forum: SierraPacific and 62 guests
