Quoting infiniti329 (Reply 4): They know anytime there is armed law enforcement on aboard be it federal,state or local. |
Quoting Viscount724 (Reply 6): Are there no female Air Marshals? |
Quoting flymia (Reply 10): I presume there are some, but not many. But we have no demographic info on FAMs its top secret. No idea how many there are either. |
Quoting 737tdi (Reply 5): JMO but this is not something that should be discussed in depth on this "public" forum. |
Quoting Thaiflyer (Reply 8): don't be so dramatic, Nothing is said here which can't be found on Google. |
Quoting infiniti329 (Reply 13): They are allowed to (if their department policy allows) but they MUST get prior approval from DHS. |
Quoting Max Q (Reply 15): It really is best not to discuss this and give out information on the program. |
Quoting Cubsrule (Reply 16): I am all for keeping sensitive security information that ought not be public out of the public domain, but I'm not for suppressing information that, like the OP's question, is a matter of federal (regulatory) law and thus in the public domain already. |
Quoting Max Q (Reply 17): Except its not in the public domain |
Quoting Max Q (Reply 17): |
Quoting WNCrew (Reply 12): Then Google it... |
Quoting mmo (Reply 18): Well, for one, it's in the FARs. Here is another link if you can't find the FAR reference. www.tsa.gov/about-tsa/law-enforcement-officers-flying-armed I can't figure out what your objection is because clearly there are published procedures. |
Quoting DFWJIM1 (Thread starter): In regards to the United States Air Marshal program. do the pilots and cabin crew know when an Air Marshal(s) is on board their plane? Or is this a case of the fewer people knowing the better? |
Quoting Max Q (Reply 20): His last sentence says it best and he's right, that information is not made public. As I said, for good reason |
Quoting mmo (Reply 22): This is easy........ I suggest you might want to google a little and you will find this publication. "Plane clothes : lack of anonymity at the Federal Air Marshal Service ... By United States, Committee on the Judiciary, Congress, House Publishes May 25, 2006" If you are so worried about sensitive information, I suggest you contact the house committee. You might want to do a search of the ASR database. There is a plethora of information contained in there. I could continue but I think you get my point........ |
Quoting Max Q (Reply 23): And you completely miss it my friend. |
Quoting n6238p (Reply 25): At the bottom of every page theres a giant boxed warning that explicitly states "No part of this record may be disclosed to persons without a "need to know." |
Warning: This document contains sensitive security information that is controlled under the provisions of 49 CFR Part 1520. No part of this document may be released without the written permission of the Undersecretary of Transportation for Security, Washington, D.C. 20591. Unauthorized release may result in civil penalty or other action. |
Warning: This document contains sensitive security information that is controlled under 49 CFR Parts 15 and 1520. No part of this document may be disclosed to persons without a “need to know,” as defined in 49 CFR Parts 15 and 1520, except with the written permission of the Administrator of the Transportation Security Administration or the Secretary of Transportation. Unauthorized release may result in civil penalties or other action. |
Quoting n6238p (Reply 27): Yea, that. Sounds like we should probably not talk about the things on the pages that end with that box. |
Quoting mmo (Reply 24): Well, then perhaps you could enlighten us with just what your point is. Obviously, you think the information is "sensitive" and should not be discussed on this forum. |
Quoting n6238p (Reply 29): This publication is not for public eyes. Good luck going to the local library and renting a copy of my Ops Manual. You really want to know whats in there? Go get hired to fly for an airline. Until that happens this info isn't for you. Sorry? |
Quoting JHwk (Reply 30): If it is SSI, then a person briefed on the SSI cannot discuss it... even if it is obvious or public domain elsewhere. However, there are a whole lot of people in the aviation industry who are not formally briefed on specific policies and therefore do not need to treat it as SSI. This is a very broad interpretation and many specifics would be treated differently. |
Quoting Tugger (Reply 31): I don't think anyone expects people who can't discuss the issue to discuss the issue. But those that can and wish to should and should be able to. If there is information that should not be out then it should be made known so that changes can be made. If someone can find out something that they shouldn't know, that would give them an advantage then authorities need to be aware to prevent any harm. This is why a free press and freedom of speech is so very important. |
Quoting n6238p (Reply 25): |
Quoting Deltal1011man (Reply 32): If anyone, Air marshal or local cop, is flying armed they are to let the flight crew know and give the proper paper work. That answers the OP's question. |
Quoting DFWJIM1 (Thread starter): In regards to the United States Air Marshal program. do the pilots and cabin crew know when an Air Marshal(s) is on board their plane? Or is this a case of the fewer people knowing the better? Thanks |
Quoting flymia (Reply 38): Yea, I'm not a flight crew member of any airline. I knew the answer. Anyone could find the answer online and a lot more about FAMs. There is absolutely nothing being discussed here which is a big secret... |
Quoting 737tdi (Reply 39): Now that everyone knows then all they have to do is overcome an FA and either the Marshall identifies himself or the FA dies. Quit talking about this stuff. |
Quoting PhilBy (Reply 39): Ignoring the "Big Scary Secret" we could look at this logically: During a flight over US territory a crew member happens to spot that one of the passengers is carrying a firearm. Having no information on this passenger beyond what is on the boarding pass do they: A) Shrug their shoulders and ignore the issue as none of their business. After-all no-one would ever attempt to hijack an airliner for nefarious purposes! B) Approach the passenger and ask if they can borrow his toy while they explain something to that obnoxious passenger in 21C C) Inform the captain who contacts the security services and immediately diverts to the nearest airfield accompanied by two interceptors |
