propilot83
Slat Retraction On 747's
Tue Sep 30, 2014 7:01 am
I have a question regarding the slat retraction process during take off and climb on 747's. I've noticed that all three are extended to provide additional lift, and the outer slat retracts first, then the inboard two retract together about 8 minutes after take off, do the pilots manually retract it? or does the autopilot/computer automatically retract the slats a few moments after take off? Thanks.
mmo
RE: Slat Retraction On 747's
Tue Sep 30, 2014 7:20 am
There are 3 groups - Inner, mid and outer. With Flap 1, the inner (Krugers) extend. With flap 5, the other sections extend. The extension/retraction of the sections is controlled by the flap handle itself. All the retraction/extension is all handled by the PNF during flap retraction/extension.
wilco737
Tue Sep 30, 2014 7:37 am
The slats on the leading edge of the 747 are called flaps as well. They are so called krueger flaps.
http://en.wikipedia.org/wiki/Krueger_flap
Quoting mmo (Reply 1):
That is correct for the 747-400. On the new 747-8 all the groups of flaps extend with flaps 1. and retract when selecting flaps up.
Quoting propilot83 (Thread starter):
We pilots do it on our own. When we have reached a certain spead (safe speed for the flaps) we put the flap lever to the next position and the flaps retract.
wilco737
[Edited 2014-09-30 00:39:00]
747classic
Tue Sep 30, 2014 11:26 am
Quoting wilco737 (Reply 2):
This is only partly correct.
The slats are called Leading Edge (LE) flaps on the 747 , with actually two different types installed :
Between the fuselage and the inboard engines : krueger flaps.
Krueger flap (installed at Leading edge inboard of inboard engines at 747)
Between the engines and at the outboard wing : variable camber flaps.
Variable camber flaps
The 747- classic series (747-100/200/300/SP) has kreuger flaps inboard of the inboard engines, they help to ensure that in the event of a stall the inboard section of the wing will stall first. Outboard of the pylons 2 and 3 are variable camber leading edge flaps installed. All LE flap sections are controlled by the up, flaps 1 and five position of the (TE) flap lever.
Also during engine reverse (part) of the LE flaps retract to avoid heat/vibration damage.
747-400 : the only difference between the 747-100/200/300/SP (besides the flap programming) is that the -400 has 1 extra variable camber leading edge flap (per side!!!) on the outboard section due to the increased span.
The 747-8 series (new wing profile) are equipped with gapped krueger flaps inboard of the inboard engines, the rest are all variable camber flaps, operated by the flap 1 or up position of the (TE) flap lever.
Operating a twin over the ocean, you're always one engine failure from a total emergency.
wilco737
Tue Sep 30, 2014 11:40 am
Quoting 747classic (Reply 3):
Thanks for being more specific than me
Just wanted to point out that it is no slat.
Thanks.
wilco737
Buyantukhaa
Tue Sep 30, 2014 2:44 pm
Just wondered, doesn't the airflow get terribly disrupted during deployment/retraction of a Krueger flap? Is there a momentary loss of (some) lift?
I scratch my head, therefore I am.
propilot83
Tue Sep 30, 2014 5:53 pm
Wilco737 thanks for an easy answer. Now I know that its the pilots that retract the slats themselves and not the computer, thanks everyone for sharing, nice info.
Dalmd88
Tue Sep 30, 2014 11:00 pm
My question is why is the 747 so different than other Boeings? 727, 737, 757, 767 all only have Krueger on the inboard, if at all and slats outboard of the engines?
DocLightning
Tue Sep 30, 2014 11:33 pm
Quoting Buyantukhaa (Reply 5):
If the slats retracted into the upper surface of the wing, there would be a disruption because it would cause a pressure rise along the upper leading edge that would disrupt the acceleration of the airflow. However, on the underside of the wing, the air is already traveling into a region of increased pressure and is decelerating, so the effect is minimal. What it does cause is a transient increase in drag, but I think the momentum of the aircraft overcomes that.
Quoting propilot83 (Reply 6):
While on some new models (The A350) variable-camber flaps are computer-controlled in cruise, I am not aware of any model in which actual flap extension/retraction is on the autopilot.
-Doc Lightning-
-Carl Sagan
Wed Oct 01, 2014 5:56 am
Quoting Dalmd88 (Reply 7):
If hazy memory serves the design was chosen due to the narrow wing profile and lack of space at the leading edge. A slat solution would have required more space, while a variable camber flap folds into itself, so to speak.
747classic
Wed Oct 01, 2014 8:03 am
During development of the 747 it was essential that the low speed performance was the same as the much smaller 707 and DC8 aircraft.
See FAA stall speeds of the 747-100/200/300 with different flap settings, note :
largest speed reduction is obtained with flaps 1 and 5 selection, extending the LE flaps.
747-100/200/300 stall speeds
Because the Variable camber krueger flaps were at that moment in time the best solution (lowest approach speed), this kind of Leading Edge device was choosen for the 747, despite the increased complexity* and costs.
See for a technical comparisson of High lift systems on Commercial Subsonic aircraft (1996) :
http://www.southampton.ac.uk/~jps7/A...h%20lift/high%20lift%20systems.pdf
* In daily operation the 747 LE system showed to be fairly reliable. (compared to the DC10 slat system). More problems were encountered with the triple slotted TE flap system on the 747.
[Edited 2014-10-01 01:50:56]
Buyantukhaa
Wed Oct 01, 2014 10:01 am
Quoting DocLightning (Reply 8):
That makes sense, thanks for the explanation!
DocLightning
Wed Oct 01, 2014 5:25 pm
Quoting 747classic (Reply 10):
Thanks for this post. Can you elaborate for me a bit more on the reasons why this would be the case? The two other widebodies being developed at the time (DC-10 and L-1011) had traditional leading edge slats. Also, didn't the 707 have Kruegers?
-Doc Lightning-
-Carl Sagan
Viscount724
Thu Oct 02, 2014 3:05 am
As a sidenote, the first fatal 747 crash, a LH 747-130 just after takeoff from NBO en route to JNB on November 20, 1974 with 59 fatalities of the 157 aboard, was caused by the crew taking off with the leading edge flaps retracted.
http://aviation-safety.net/database/record.php?id=19741120-0
PROBABLE CAUSE: "The accident was caused by the crew initiating a take-off with the leading edge flaps retracted because the pneumatic system which operates them had not been switched on. This resulted in the aircraft becoming airborne in a partially stalled condition which the pilots did not identify in the short time available to them for recovery. Major contributory factors were the lack of warning of a critical condition of leading edge flap position and the failure of the crew to complete satisfactorily their checklist items."
OldAeroGuy
Fri Oct 03, 2014 3:36 pm
Please note that for Boeing airrplanes, the 707, 727, 737 and 747 have inboard Kruegers. The 757, 767, 777 and 787 all have inboard slats.
DocLightning
Fri Oct 03, 2014 10:29 pm
Quoting OldAeroGuy (Reply 14):
However, the 767, 777, and 787 (IIRC) all have a tiny krueger just inboard of the engine pylon. I always wondered why that was.
-Doc Lightning-
-Carl Sagan
OldAeroGuy
Sat Oct 04, 2014 3:14 pm
Quoting DocLightning (Reply 15):
It fills in the rather large leading edge gap between the deployed slat and the nacelle pylon, benefiting CLmax and takeoff L/D.
The 757 has less leading edge sweep than the 767, 777, and 787 so careful shaping of the slat end and the pylon eliminated the potential gap and the need for a seal Krueger.
DocLightning
Sat Oct 04, 2014 8:22 pm
Quoting OldAeroGuy (Reply 16):
Ahh. It always struck me as a very odd and complicated little device, and I know that Boeing wouldn't have put it there without a very good reason.
Why doesn't Airbus use this?
-Doc Lightning-
-Carl Sagan
OldAeroGuy
Sun Oct 05, 2014 4:49 am
Quoting DocLightning (Reply 17):
Well, they did something similar on the A310, bout on the inboard end of the inboard slat
https://www.airliners.net/photo/Turki...d=42044e4803a4f733960b19faa16c16d3
This photo also shows a difference between Airbus and Boeing design practice on twin aisle airplanes. Airbus mounts engines lower on the wing than Boeing. The result is less interference between the slats and the nacelle/strut.
On the A310, the slat was continuous over the strut, with a small cutout to allow the slat to seal on the strut when fully extended.
On the A330 and A340, the low engine position allows tailoring of the strut and slat to have a good slat-to-strut seal.
https://www.airliners.net/photo/China...d=3c1b6827aed59d4be79cd7a85f032f46
https://www.airliners.net/photo/Swiss...d=d36b9d6162490211df6038ee1f4b58e5
Jetlagged
Mon Oct 13, 2014 9:34 pm
The 747 isn't that different. The 727 and 737 also had similar staged extension and retraction of the LE devices.
On the 727:
At Flap 2 LE slat sections 2,3 and 6,7 extended. At flap 5 LE slat 1,4 and 5,8 and LE flap 1,2,3 and 4,5,6 extended. The reverse sequence on retraction.
On the 737:
At Flap 1 all LE flaps extend and the LE slats extend to an intermediate position. At Flap 10 the slats extend fully.
As with the 747 Classic, there is an array of amber and green lights to show the various sections in transit and extended. On the 727 it's by the F/E station, on the 737 it's on the overhead.
Quoting Viscount724 (Reply 13):
Boeing were required to include LE flap positions in the TO config warning system as a result of this accident. Why the F/E closed the pylon bleed valves after engine start has always puzzled me. I can only assume they were doing a no bleed takeoff (it was at Nairobi) and rather than switch the packs off he closed the bleeds.
AA737-823
Tue Oct 14, 2014 3:33 am
Does anyone know if there are EXCEPTIONS to the L/E flap retraction sequence logic?
I ask, because on my very first 747-400 flight, back in 2008, I observed the OUTBOARD section to remain extended for a really surprising amount of time. We're talking in the neighborhood of FL200. Long after I could see that the mid and inboard sections were retracted.
This was a KLM 747-400M, PH-BFC (the volcano victim).
It really surprised me, as I was a 747 line tech at the time, and had never observed the leading edges behave in that sequence.
RetiredWeasel
Tue Oct 14, 2014 3:44 am
Quoting Jetlagged (Reply 19):
Not sure about other airlines, but we always did no-pack takeoffs in our 40 or so classics back in the days. However after engine start, we would normally turn the packs on for PAX comfort until taking the runway just prior to T/O where we turned them back off. The SO flow pattern turned the packs on before the CPT called for flaps at start of taxi.
Possibly, instead of turning the packs on just after engine start, the FE may have mistakenly turned the bleeds off (even thought the position is 90 degrees out. As you well know, the knobs are right below the pack knobs and are identical. Then when taking the runway, either they didn't turn packs off (their procedure?) or he just said "Oops I forgot to turn the packs on for taxi" and still didn't notice the bleeds were turned off.
Just a thought.
[Edited 2014-10-13 20:46:58]
RetiredWeasel
Tue Oct 14, 2014 4:09 am
Quoting AA737-823 (Reply 20):
Leaving any flaps or L/E devices down or out until FL200 would be highly unusual normally.
Highly speculative, but it's possible the pneumatic motor on that section of LEDs broke and the crew went into the checklist to start the backup procedure. Meanwhile they kept flying their cleared route, were able to retract the offending LEDs electrically and decided just to continue to their destination....with a little aticipation that they may have to extend them manually again with backup electrical motors.
747classic
Tue Oct 14, 2014 11:53 am
The original design of the 747 engine bleed air valve was that the engine could be started with the bleedair vlv switch (F/E panel) closed. (return flow function).
After engine start you had to open all 4 valves by their switches (after starting checklist) to allow bleed delivery.
After the NBO accident (F/E failed to switch open the vlv's - no bleed manifold pressure - no L/E flap extension)) the bleed air switching logic was changed : engine start was only possible with the bleed air switch (F/E panel) in the open position, no bleed air switching necessary in the normal "packs on" T/O configuration.
Also the LE flap positions were added to the T/O warning system logic.
[Edited 2014-10-14 04:57:19]
Jetlagged
Tue Oct 14, 2014 2:13 pm
Quoting 747classic (Reply 23):
That explains it. I didn't know the logic worked like that originally. Many thanks.
BoeingGuy
Tue Oct 14, 2014 7:38 pm
No Boeing airplanes ever have a system automatically change flap or slat position (except for the Autoslat enable function during a stall), raise or lower landing gear, or select reverse thrust. It's all done manually. That is by design.
On the 737:
On the 757, 767, 777 and 787 the slats extend into the sealed position at Flaps 1-20. The go into the gapped position at Flaps 25-30.
Jetlagged
Wed Oct 15, 2014 2:50 pm
Quoting BoeingGuy (Reply 25):
Not quite true. Several Boeing types have flap load relief, which reduces TE flap position if speed is excessive.
Airbus philosophy is very similar.
BoeingGuy
Wed Oct 15, 2014 8:07 pm
Quoting Jetlagged (Reply 26):
You got me on that one. I'm fully aware of the function, but I forgot about it when I was writing the post. 767 only does load relief for Flaps 25-30. 777 and 787 do it for all flap settings (although I forget about Flaps 1).
Users browsing this forum: ArdWar and 39 guests
