Tangowhisky
Airport Landing Fees And Navigation Charges
Sat Jun 13, 2015 1:59 am
I was wondering if anyone knows where US fees are published for airport and navigational charges. I will appreciate any helpful information .
Only the paranoid survive
alasizon
RE: Airport Landing Fees And Navigation Charges
Sat Jun 13, 2015 3:00 am
For airport fees, these are generally published by most US airports with rates for everything from landing to sq ft leases.
Viscount724
Sat Jun 13, 2015 3:04 am
Quoting Tangowhisky (Thread starter):
Navigation charges for flights that overfly the US are here.
http://www.faa.gov/air_traffic/international_aviation/overflight_fees/
There are no air navigation charges in the U.S. for aircraft that land and take off there, only for overflights.
Landing fees and other airport-related charges are up to each airport and are probably found in many airport websites. Not sure if there's a single comprehensive source of that information.
NBGSkyGod
Sat Jun 13, 2015 9:57 pm
Your best bet to find out fees at an airport is to call the FBO. Often there are discounts and fee wavers if you buy a certain amount of fuel from the FBO. But the US does not charge for ATC services directly (it comes from taxes on the fuel).
Pilots are idiots, who at any given moment will attempt to kill themselves or others.
Okcflyer
Sat Jun 13, 2015 11:08 pm
Take off AND land is no charge? What if you're flying in from another country but landing in the USA. Are those navigational charges waived?
Viscount724
Sat Jun 13, 2015 11:16 pm
Quoting OKCFlyer (Reply 4):
Landing fees and other airport charges are assessed by the airport. As previously mentioned, the FAA only assesses air navigation charges for ATC services for flights that overfly the U.S. without landing. If they land in or take off from the U.S., regardless how much U.S. airspace they use, there are no air navigation charges.
Matt6461
Sun Jun 14, 2015 6:00 am
Quoting Viscount724 (Reply 2):
http://www.faa.gov/air_traffic/inter...fees/
Thanks! How do these compare to other countries' fees? And it seems like these fees don't vary by aircraft size, no?
Viscount724
Mon Jun 15, 2015 2:37 am
Quoting Matt6461 (Reply 6):
Every country is different. For example, the PDF document in the link on the last line of this page explains the charges in Canada which apply for all flights passing through Canadian airspace, whether they land there or not. See the "Customer Guide" link on the right for the details and charges, including some examples.
http://www.navcanada.ca/EN/products-...ervices/Pages/service-charges.aspx
U.S. overflight fees appear to be the same for all aircraft. Can't see anything to the contrary in FAA info.
Users browsing this forum: ITMercure, leader1, unimproved and 32 guests
