doulasc
Airlines Sealing The Back Stairs On 727s
Sun Jun 14, 2015 4:02 pm
This thread is based on cover of Life Magazine August 11 1972 shows a Braniff Boeing 727
airbourne with its rear stair door halfway open. Did Braniff and other airlines seal their
rear stairs on their 727 fleet by removing the handle.How many airlines had problems
with hijackers using the rear stairs while in flight?
ridgid727
RE: Airlines Sealing The Back Stairs On 727s
Sun Jun 14, 2015 4:07 pm
Didn't the FAA order all airlines to install the DB Cooper Vane on 727s and DC9s to prevent the airstairs from opening in flight, after the NW Hijacking?
Polot
Sun Jun 14, 2015 4:12 pm
Here is the cover for those interested:
[Edited 2015-06-14 09:12:44]
ridgid727
Sun Jun 14, 2015 4:29 pm
I don't think they sealed off any, as those were legitimate exits when the aircraft was on the ground.
The vanes were installed to keep them from opening inflight.
http://en.wikipedia.org/wiki/Cooper_vane
Dalmd88
Sun Jun 14, 2015 5:43 pm
The stairs also had to be down while loading and unloading. When down and locked they were a structural tail stand that prevented the nose from lifting off the ground in a tail heavy condition.
trnswrld
Sun Jun 14, 2015 5:54 pm
We're any DC9/MD80 or 727 aircraft ever built without these stairs? (Sorry if that's a stupid or obvious question).
MD80
Sun Jun 14, 2015 6:00 pm
Quoting trnswrld (Reply 5):
Some early-built DC-9-10s were delivered without the rear stair.
Dedicated to the MD-80, MD-90, MD-95, and DC-9: www.MD-80.com
Viscount724
Mon Jun 15, 2015 2:17 am
Quoting MD80 (Reply 6):
Many much later DC-9s, and not just DC-9-10s, were built without the rear airstairs. For example, all 50+ AC DC-9-32s lacked the rear stairs. They were optional on DC-9s. Standard on all 727s and MD-80/90s as far as I know.
[Edited 2015-06-14 19:19:05]
Max Q
Mon Jun 15, 2015 11:28 am
Did the 717 have rear stairs ?
GGg
badgervor
Mon Jun 15, 2015 1:09 pm
Quoting Max Q (Reply 8):
Not that I'm aware of. At least when I worked at YX they didn't have them.
1337Delta764
Mon Jun 15, 2015 1:33 pm
No, that feature was removed by McD to save weight to improve fuel economy.
Classa64
I would think removing them completely instead of sealing them would reduce weight, but are they required to work as an emergency exit ? In an evac test when the the plane was certified were the rear stairs working counted as an exit?
"Freedom is the miles i'm rolling on"
litz
Mon Jun 15, 2015 6:36 pm
Quoting Classa64 (Reply 11):
Exactly - and, in fact, in the recent DL MD-88 landing incident at LGA, that was how a bunch of people got off the airplane - right out the back end.
There is a pretty infamous picture of a fireman's ladder set up against the aft end of the plane (where the jettisoned tailcone would be) to allow access inside the plane to rescue workers.
Dalmd88
Mon Jun 15, 2015 8:15 pm
In the DC9 family the rear stairs are not an emergency exit. The catwalk above the stairs and the removable tailcone are the emergency exit. All DC9 family have this exit irregardless if they have ventral stairs installed. It is impossible to open the DC9 family stairs from inside the aircraft.
113312
Mon Jun 15, 2015 10:53 pm
You could not remove the aft airstairs on the B727 because they provided essential access to a whole lot of systems and plumbing that was installed on either side of the stairwell.
tb727
Mon Jun 15, 2015 11:45 pm
Quoting polot (Reply 2):
Ahh man, this thing is a pig, it's climbing like the airstairs are down!
BravoOne
Tue Jun 16, 2015 9:52 am
An interesting experiment was done by the US Army with CIA oversight where they removed the cabin to stairway door (AKA refrigerator door) and had jumpers launch of the stairway in flight. At about 140Kts, flaps 20 you could get about four guys on the stairway and it would float in an open position with enough stability to launch the guys safely or at least within the acceptable risk zone. The problem of course was when the stairway only had one or two guys on it the tendency for it to drift up became problematic. I saw this down with a ATA 727 and later saw good film footage done using a Pan Am 727-100 filmed from both inside and outside the aircraft.
The ATA flights were done down in Marana. Don't know where the Pan Am flights occurred or if this was ever put to use. Very risky business when involve airliners in military ops IMO.
[Edited 2015-06-16 02:57:12]
B777LRF
Tue Jun 16, 2015 1:49 pm
Quoting Dalmd88 (Reply 4):
The door is NOT a tailstand, and only the -100 was handled with the door down.The -200 had a separate tailstand and the door had to be up and locked. We are talking freighters here, as they present the biggest challenge.
Signature. You just read one.
Max Q
Wed Jun 17, 2015 6:05 am
Quoting B777LRF (Reply 17):
That's not the way we operated in the passenger world, one of my duties as Second Officer was to ensure the hydraulic arms on either side of the ventral stairs were locked over center before loading and we DID use it as a tailstand.
Nothing wrong with using a tailstand I guess but I disagree that the ventral stairs could not be used that way, that was our approved procedure.
GGg
Users browsing this forum: glen, ikolkyo and 20 guests
