Quoting rampart (Thread starter): How often is this done? And why would brakes still be hot after the aircraft spent time at the gate and then taking off? It was a morning flight, not too hot in the day yet, and it's not as if DEN has short runways requiring lots of braking. |
Quoting mmo (Reply 3): Let me guess, it was an Airbus 320 family aircraft! |
Quoting MD95sOverATL (Reply 2): The brakes are engaged after takeoff to stop the wheels before retracting the gear, hence why they get hot. |
Quoting tb727 (Reply 6): Landing in DEN and doing a fairly quick turn, autobrakes off, max reverse for landing and let it roll, did it just yesterday. LAS has portable brake fans but you could use them almost everywhere at some point in the summer. |
Quoting francoflier (Reply 7): Stopping the wheels after takeoff is not what heats the brakes up, it is simply the braking effort required during normal taxi. |
Quoting flyDTW1992 (Reply 8): Stupid question...Would a simple solution like a garden hose and a spray nozzle be an option to cool brakes quick at the gate? |
Quoting tb727 (Reply 10): o, I think that would be worse, I think it would cool them too quickly and cause some sort of damage/wear/warping. |
Quoting KC135Hydraulics (Reply 13): Is it possible to use reverse idle (like a turboprop would use beta range) during longer downhill taxi to attempt to slow the aircraft some, or is that completely ineffective? |
Quoting N353SK (Reply 16): I think most airlines ban the practice (for FOD as already mentioned) but I've seen quite a few biz jets with one or two buckets popped on taxi. |
Quoting flyDTW1992 (Reply 17): I also routinely see CR9s taxiing with 1 reverser deployed. Particularly when it's being taxied by mechanics. |
Quoting MD95sOverATL (Reply 2): Given that you had a deal of turbulence and wind noise, I'd submit that the pilot just left the gear down to cool. |
Quoting francoflier (Reply 7): Stopping the wheels after takeoff is not what heats the brakes up, it is simply the braking effort required during normal taxi. Brakes accumulate temperature, which peaks sometime after their use. Brakes being quite heavy, even in their carbon-ceramic form, and designers tend to try to keep them only as big as strictly necessary. |
Quoting OKCFlyer (Reply 20): Aircraft speed had to be pretty high at FL20 |
Quoting speedbird128 (Reply 21): Working in the tower, I have experienced this with many aircraft, right up to the 747SP. |
Quoting OKCFlyer (Reply 20): Aircraft speed had to be pretty high at FL20 ... Surprised extension is allowed at such higher speeds. |
Quoting OKCFlyer (Reply 20): |
Quoting DocLightning (Reply 24): I believe that the A320 family restricts gear movement above 250 KIAS. Not sure what IAS would be at 20,000 feet on a typical mission but I'm surprised it's not higher. |
Quoting mmo (Reply 22): UAE |
Quoting flyDTW1992 (Reply 8): garden hose and a spray nozzle be an option to cool brakes |
Quoting aeroflop (Reply 30): What's interesting is that the brakes were hot enough to warrant extending them during flight but not warm enough to delay the take off. |
Quoting aeroflop (Reply 32): Ahh that makes sense. Any idea why the 320 has a sealed gear bay? Probably more steamline than the open 737 style gear bay. |
Quoting mmo (Reply 3): Beats me why operators some operators did not order the brake fans..... |
Quoting HAWK21M (Reply 34): Is there any Aircraft type that permits the gear door opening in flight without extending the gear......anyone aware. |
Quoting Max Q (Reply 27): On the 727 if you placed the gear handle down in flight then immediately placed it to off as soon as the red in transit lights illuminate only the gear doors would open and the gear would stay up. This was our procedure for a wheel well fire |
Quoting CALTECH (Reply 38): Thought it was by either just lowering the gear, or lowering the gear with the gear handle in the down position, then move the gear handle momentarily to the up position which started the door opening sequence. Then place the handle in OFF when the gear door light came on. That will leave the doors open and the landing gear down to help with the fire. Thought that was the procedure for a wheel well fire. Didn't want that gear in the wheel well if the fire warning went off. Did those checks a lot during gear swings on the 27. Could be off a bit though, that was so long ago. |
Quoting KC135Hydraulics (Reply 37): As was the reading earlier, any aircraft whose aircraft has a landing gear OFF position will probably be able to open the doors without the gear coming down. You just need to beat the gear doors with the handle, IE select gear DOWN and quickly to OFF, or the gear will continue to receive hydraulic pressure and unlock/extend once the doors are fully open (sequence valve stuff). |
Quoting CALTECH (Reply 38): Thought it was by either just lowering the gear, or lowering the gear with the gear handle in the down position, then move the gear handle momentarily to the up position which started the door opening sequence. Then place the handle in OFF when the gear door light came on |
Quoting Max Q (Reply 41): This opens the gear doors and leaves the gear retracted. |
Quoting Max Q (Reply 43): So yes, the procedure details how to extend the gear and leave the gear doors open in an attempt to extinguish the fire, my memories not what it used to be. |
Quoting CALTECH (Reply 44): My memory is not what it used to be either. Forgetting things from long ago, until something stirs those unused neurons into firing. Cut my teeth on the 727-100/-200 and the DC-10-10/-30s. Miss that 727....... |
Quoting MD95sOverATL (Reply 2): The brakes are engaged after takeoff to stop the wheels before retracting the gear |
Quoting Airstud (Reply 46): What's the harm from just letting them spin till they stop? |
Quoting Airstud (Reply 46): Interesting... but why? What's the harm from just letting them spin till they stop? |
