Quoting Jagflyer (Thread starter): 5. The air system starts again in the cabin as the APU and/or the started engine can handle it with enough pneumatics to supply the next engine's starter. 6. The other engine(s) are started off the APU bleed or engine bleed. Do I have this about right? I imagine the pilots are manually switching the bleed air switches and electric supply during the start-up sequence on the Boeing aircraft (Airbus is more automated I think). I've experienced a similar type of process on both 737s and 767s. [Edited 2015-09-18 17:37:12] |
Quoting Jagflyer (Thread starter): I imagine the pilots are manually switching the bleed air switches and electric supply during the start-up sequence on the Boeing aircraft (Airbus is more automated I think). I've experienced a similar type of process on both 737s and 767s. |
Quoting Jagflyer (Thread starter): 6. The other engine(s) are started off the APU bleed or engine bleed. |
Quoting Jagflyer (Thread starter): On aircraft which have pneumatic engine starters (which use high pressure bleed air from another engine, |
Quoting gcb5196 (Reply 1): Embraer has a different way for power transfer to avoid the hard transfer, I'll have to pay better attention to see if the lights flicker next time. |
Quoting mmo (Reply 4): Generally, if you start using the APU, other engines are also started using the APU. An engine at ground idle can not provide enough bleed air to allow a successful engine start. |
Quoting Whiteguy (Reply 3): |
Quoting 737tanker (Reply 11): Quoting Whiteguy (Reply 3): At WN when using the APU for an engine start we start the #2 first and after it is started we isolate the right side air conditioning then turn the #2 Pack so as to get air to the passengers, after that we start the #1 engine. If we are using external air for starting we reverse the procedure and start the #1 engine first. |
Quoting 737tanker (Reply 11): At WN when using the APU for an engine start we start the #2 first |
Quoting rjsampson (Reply 14): I'm guessing it's also possible to start the engines without turning of the PACS (which on hot days, I sometimes wish the pilots would -- I get warm very easily), presumably resulting in a longer spin-up time. Is this the case? Is it ever done? |
Quoting Western727 (Reply 15): As a frequent WN flier I've noticed this. Is my assumption correct that this is an effort to "equalize" the engine run times as much as reasonably possible between engines #1 & #2, given that WN jets seemingly universally park at gates with only #1 running? |
Quoting rjsampson (Reply 14): presumably resulting in a longer spin-up time. Is this the case? |
Quoting AAR90 (Reply 18): This is Boeing's procedure. Starting #2 allows isolation of the right pneumatic system providing uninterrupted cabin air conditioning (from right PACK) before and during #1 engine start. The downside of this procedure is the procedural requirement to shutdown the #2 engine IF there are any "late bags" to be loaded after engine start --relatively rare. Parking with #1 running is also a Boeing procedure. The preference here is that the ground crew will want to start moving cargo/bags ASAP after parking and they can't do that until the #2 engine has shutdown --saves a minute or so. At AA we used to alternate the starting of engines based upon flight number (odd = right, even = left), but that went away many years ago. Now our manuals are virtual duplications of the Boeing manuals and... our procedures are virtual duplications of Boeing procedures. |
Quoting Whiteguy (Reply 19): Unless it's an air start at the gate we are always on the push when engines are started anyway....your "late bags" scenario never happens.... |
Quoting Whiteguy (Reply 19): As for parking with one running....while we often shutdown #2 while approaching the gate, it has nothing to do with ground crews opening the pits and moving bags. It's fuel saving measure, that's all. Crews don't approach the aircraft with engines on or anti collision light on at any companies I've worked at. Saving a minute or two should not take priority over safety, just my opinion.... |
Quoting AAR90 (Reply 20): Crews don't approach the aircraft with engines on or anti collision light on at any companies I've worked at |
Quoting AAR90 (Reply 20): Upon gate arrival the ground crew is to connect ground electrical power before the engine(s) are secured unless the APU is in use --AA preference is to NOT use APU. |
Quoting gcb5196 (Reply 23): Quoting Whiteguy (Reply 19): Unless it's an air start at the gate we are always on the push when engines are started anyway....your "late bags" scenario never happens.... Never say never. I have watched bag runners pull up to a plane after pushback and load bags onto a plane many times, sometimes with an engine running. It was up to the crew whether or not they were loaded. |
Quoting flyDTW1992 (Reply 21): Quoting AAR90 (Reply 20): Crews don't approach the aircraft with engines on or anti collision light on at any companies I've worked at 'Cept the deicers. We're crazy like that. (half joking) |
Quoting tristarsteve (Reply 22): We also have airlines that do not start the APU. The ramp staff need to know which airline they are meeting and what rules to follow. |
Quoting TWAL1011727 (Reply 26): Delta used to leave the APU off and arrive at the gate w/one engine only somewhere in the last 10 yrs they changed that. |
