Quoting Flighty (Thread starter): Do you have enough reflex to "sweep" the instruments and the horizon without even thinking about it? |
Quoting Flighty (Thread starter): Can you do complex operations from memory? |
Quoting barney captain (Reply 2): The same can be said for driving. When you caught your mind wandering, I bet the highway wasn't covered in ice on a dark night |
Quoting Starlionblue (Reply 3): Hence the saying that the further back from the instrument panel you sit, the smarter you get. |
Quoting Flighty (Reply 4): Too bad pilots can't pace around the aircraft, or maybe they can... |
Quoting Flighty (Thread starter): Yet I was doing a good job of driving. |
Quoting Starlionblue (Reply 3): Sure. For example pre-flight cockpit setup and approach setup, as well as performing an approach include dozens of steps performed from memory. Many of these sequences are known as "flows". If someone woke me from a deep sleep I could recite every step involved in setting up and flying an approach (either as PF or PM) from memory.. |
Quoting jetblueguy22 (Reply 9): New students tend to focus on the screen and not outside. They sit there and tell you keep looking outside, keep looking outside. Then you hop into instrument training and it's like, stop looking outside! Inside, keep your instrument scan up. But over time you learn to manage it. I think learning instrument flying actually made me a better VFR pilot. Your total scan is completely different. You learn to process information more efficiently. I think it's made me a safer driver too. |
Quoting D328 (Reply 6): Landings were my favorite. Tried to get them as short as possible at my school. |
Quoting stealthz (Reply 8): Later when I upgraded to a car with cruise control I realised when having similar conversations I was still slowing down to 80-90... the emphasis I was, the car was still going 120 or so, that is pretty scary the first time it you realise it! |
Quoting Woodreau (Reply 5): It's called selecting the appropriate level of automation. |
