larshjort
RE: A Future With No Thrust Reversers?
Thu Dec 10, 2015 6:46 pm
Quoting Starlionblue (Reply 47):
As well known by Steve Dumas... http://www.youtube.com/watch?v=yz3AC93DvDo
So in a demonstration on why to lockout hydraulic equipment the demonstrator goes into the path of the reverser several times with the unlocked reverser and hydraulics on
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
yeelep
Thu Dec 10, 2015 11:27 pm
He never went into the path of the reverser with hydraulics on. You may being mistaking the sound of the equipment cooling fan for the hydraulic pump.
Max Q
Fri Dec 11, 2015 9:42 am
Quoting OldAeroGuy (Reply 49):
I think that most airlines will go for the reverse option since it helps to keep their airplanes on the runway in adverse conditions. There is a considerable economic benefit for doing that.
Guns and the love of them by a loud minority are a malignant and deadly cancer inflicted on American society
DashTrash
Sun Dec 13, 2015 3:52 am
Quoting Max Q (Reply 21):
You can have the best braking system made but they are useless if your tires are hydroplaning and / or can't get a grip on the runway.
Absolutely. I have blown both mains on one side and needed differential reverse to keep the airplane on the runway. I will not bid an aircraft with no reversers.
Max Q
Sun Dec 13, 2015 9:59 pm
Quoting DashTrash (Reply 53):
Well said DT and best wishes.
BravoOne
Mon Dec 14, 2015 6:51 pm
Maybe someone else has posted this but I think it should be an excellent summation regarding this subject.
http://www.ifalpa.org/downloads/Leve...0data%20on%20Boeing%20aircraft.pdf
I have an 85 page Power Point on the subject but there little new to say beyond the Briefing leaflet.
Jetlagged
Sun Dec 27, 2015 6:49 pm
Quoting A320FlyGuy (Reply 15):
the BAe-146 didn't have thrust reversers, so it's not like this is a revolutionary concept.
They have a manually selectable ground idle setting which reduces forward thrust (it makes a noticeable difference to deceleration rate). Also large and powerful speedbrakes.
Quoting BravoOne (Reply 16):
Yes we get your point. Also the Folker 100 did not have TR's either as I recall. Just means it was an airplane built around compromise and not what worked best
The Fokker 100 has reverse thrust. It was the F.28 that didn't have it. Maybe the higher landing weight of the Fokker 100 meant a thrust reverser was necessary?
Max Q
Sun Dec 27, 2015 10:04 pm
Quoting BravoOne (Reply 55):
That is very well written, should be required reading for all those who doubt the importance of reverse thrust.
Okie
Sun Dec 27, 2015 10:39 pm
Don't forget - the A380 only has 2 thrust reversers due to the capacity and engineering of the aircrarft brake system. Also, the BAe-146 didn't have thrust reversers, so it's not like this is a revolutionary concept.
There were quite a few of the EMB145's delivered without thrust reversers.
Okie
flight152
Sun Dec 27, 2015 10:50 pm
Quoting Okie (Reply 58):
Ask Trans states how well that worked out for them in Ottawa.
Okie
Mon Dec 28, 2015 12:05 am
Quoting flight152 (Reply 59):
Twice I believe.
The driving force behind not ordering those EMB's without T/R's was saving the maintenance cost of the T/R's.
One has to wonder if the insurance rates increased for operating that model of airframe without T/R's to the point that no money was saved?
Okie
BravoOne
Mon Dec 28, 2015 2:55 pm
Quoting Jetlagged (Reply 56):
Thanks I always get those Fokkers confused.
Max Q
Mon Dec 28, 2015 8:14 pm
Quoting BravoOne (Reply 61):
That Fokker was a Messerschmitt
Users browsing this forum: MoKa777, VTOL147 and 19 guests
