TWA772LR
Widebody Turboprop: Feasible? Possible?
Sun Feb 07, 2016 2:24 am
Turboprops have high rates of efficiency. Has there ever been a proposal or design for a twin aisle turboprop aircraft? For example, a 2-2-2 Q400 sized aircraft would have around 114 seats. The wider fuselage will allow for a real, pressurized cargo hold, and also an extended pax cabin, if said aircraft is developed from the ATR or Q400.
Also, would a 200 seat, widebody turbo prop with a 3500nmi range were to exist, would it be a viable alternative for airlines to operate across the Atlantic versus the 737 max and A321neo?
The only downfall I see for the larger aircraft is that it will require 4 engines instead of 2.
Thoughts?
intotheair
RE: Widebody Turboprop: Feasible? Possible?
Sun Feb 07, 2016 2:35 am
That sounds horrible! Think about how many more people would be bumped around even more severely during turbulence!
32andBelow
Sun Feb 07, 2016 2:37 am
Quoting intotheair (Reply 1):
Jets have turbulence too!
DiscoverCSG
Sun Feb 07, 2016 2:47 am
Quoting TWA772LR (Thread starter):
What would be the cruising speed? And what would that do to trip times?
flyzapper
Sun Feb 07, 2016 2:49 am
It sounds like a C-130 to me. With insulation and comforts of a modern airliner, a C-130 style and size aircraft fits your idea.
Max752
Sun Feb 07, 2016 2:55 am
Quoting flyzapper (Reply 4):
I totally agree. I was trying to envision what it would like and the C-130 looks about what I was thinking.
As a passenger, the flight times would be greater so, there's that. Cabin comfort? I don't see it being an issue. From an armchair CEO's standpoint, I don't really see the need but...okay I guess.
-Max
Wingtips56
Sun Feb 07, 2016 2:57 am
Trans-Atlantic has been done with the L-188 Electra, the Bristol Brittania and the Canadair CL-44. Left in the dust by the jets, nevermind some serious issues.
I can see a bigger turboprop but 3-3 seating with a single aisle is more likely; less airplane with the same passenger capacity. Heavier would probably negate any cost advantage.
Probably not for longhaul, but 1-2 hour stage lengths more likely unless the speed somehow gets up to jet speeds.
rj968
Sun Feb 07, 2016 3:39 am
C-130's make great airlines, and who needs aisles!
cschleic
Sun Feb 07, 2016 4:33 am
Didn't Lockheed pitch an airline passenger version of the C-130 in the past?
JetBuddy
Sun Feb 07, 2016 5:15 am
Quoting cschleic (Reply 8):
The L-100. It's still on the market as LM-100J, based on the C-130J Super Hercules I believe.
I was thinking more like a TU-144.
A 100 seat turboprop with 3+2 or 3+3 seating sounds like it could be plausible, made for shorter segments where cruise speed is not as important. Like others have mentioned, the L-188 Electra was one such aircraft.
I don't think we'll see a widebody turboprop made for TATL or general long haul. The lower cruise speeds matter more the further the flights are. That being said, there are some extremely fast turbprops. The Saab 2000 and Bombardier Q400 are pretty fast, the TU-95 Bear and it's derivative TU-144 is incredibly fast with 510 knots cruise speed which matches modern jet airliners. But I don't believe the fuel economy is that great.
[Edited 2016-02-06 21:17:21]
zanl188
Sun Feb 07, 2016 5:16 am
Yes, and sold a couple...
Photo © Petr Popelar Collection
NWADC9
Sun Feb 07, 2016 5:25 am
Quoting zanl188 (Reply 10):
Here's the inside:
S75752
Sun Feb 07, 2016 5:29 am
Quoting JetBuddy (Reply 9):
What on earth...
I had never heard of that thing before, nor that Lockheed still did anything for civilian aviation in the past decade or two.
mandala499
Sun Feb 07, 2016 5:54 am
2-2-2? Why not just have 3-3 and make it the size of the A320Fam cross section for containerized hold?
It'll make a lot more sense than 2-2-2, if baggage hold is your argument, then, well, screw the pax, just use a cargo prop!
Quoting Wingtips56 (Reply 6):
I remember a 3 hour flight on an L-188... I'd trade that for a 2 hour flight on a jet anyday, even an old jet... I may have had blurred vision for an hour after that 3 hour Electra flight!
You mean Tu-114...   Fuel economy? I do wonder about the fuel consumption of the Tu-95/114/142... Oh hang on, if we publish them here, we might end up killing the future of these "large turboprop" threads
doug_or
Sun Feb 07, 2016 8:06 am
Quoting S75752 (Reply 12):
The pic is 26 years old, and the aircraft was delivered well before then.
Who flew the Electra trans-Atlantic? I thought the range was a bit short for that.
[Edited 2016-02-07 00:14:40]
Wingtips56
Sun Feb 07, 2016 8:47 am
Quoting doug_or (Reply 14):
Well you may have me on that one....I may have incorrectly assumed that KLM flew them T/A. Anybody have that info?
WIederling
Sun Feb 07, 2016 9:47 am
Quoting mandala499 (Reply 13):
Full power fuel use for a Bear should be in the range of 10t/hour. ( 4 times 11.000kW @ .219kg/kWh )
Now how much of full power do they use at cruise?
.219kg/kWh for the NK-12 isn't bad at all
TP400-D6 is either 167g/kWh or 213g/kWh ( first for shaft power takeoff )
the best stationary and large diesel engines go down to 162g/kWh.
The gain or loss ( whichever way you see it ) is in propulsive efficiency which is better for a (good) prop.
larshjort
Sun Feb 07, 2016 10:14 am
Most certainly. Everybody knows a modern designed turboprop aircraft cannot possible be better than the pinnacle of soviet engineering 60 years ago
I believe a twin turboprop with 120-140 pax, a range of 1000-1200Nm and a service ceiling of around 30k feet and a speed somewhere between the ATR and Q400 would have potential to sell a couple of thousand.
/Lars
Heinkel
Sun Feb 07, 2016 10:18 am
The most modern big turboprop is the Airbus A400M. And it comes (unlike the Hercules) with a valid type certification for civlian use.
Put some modern airline style seats inside and you have the aircraft you are looking for.
StTim
Sun Feb 07, 2016 10:23 am
Call them open rotor and whiz bang - they are the way to go
factsonly
Sun Feb 07, 2016 10:39 am
Quoting Wingtips56 (Reply 15):
Definitely not TATL.
KLM operated DC-7C and DC8-30/50 on TATL routes when the Lockheed Electra was in service.
The Lockheed Electra was a dedicated European/Mid-East/North and West Africa aircraft for KLM in the early 1960's. By late 1960's the aircraft had become an exclusive European short-range regional aircraft.
The furthest the KLM Electra operated in 1961 was multi-stop routes to the Middle East and West Africa, with destinations: Abadan, Amman, Basra, Baghdad, Benghazi, Beirut, Cairo, Jeddah, Dhahran, Tehran, Tripoli, and Casablanca, Monrovia, Conakry, Accra, Kano, Lagos and also Moscow.
KLM Electra in 1961:
http://www.timetableimages.com/ttimages/kl/kl6106/kl61-27.jpg
http://www.timetableimages.com/ttimages/kl/kl6106/kl61-11.jpg
http://www.timetableimages.com/ttimages/kl/kl6106/kl61-12.jpg
mjoelnir
Sun Feb 07, 2016 10:43 am
The thread opener talks about a twin isle turbo prop and than about 2+2+2 seating. A turboprop would be about cutting cost. A 6 a row configuration would be done single aisle 6+6. Twin aisle should start of with 3+2+3 or something similar.
The L-100 is a bad example, as military to civil conversion are usually expensive.
The minimum twin aisle I could imagine than would be an A310 sized body.
No such frame would be ever even thought about while the price of oil is low.
WIederling
Sun Feb 07, 2016 11:25 am
Quoting mjoelnir (Reply 21):
2 times TP400-D6 would give you a ~100t MTOW plane. ~A322 size
PatrickZ80
Sun Feb 07, 2016 12:29 pm
The Tu-114 was the largest turboprop ever built. Of course it's not economically profitable compared to modern aircraft, but in those days it was a safe and reliable aircraft.
Also the Bristol Britannia deserves to be mentioned as well as the Boeing 377 Stratocruiser. Both of them has a pretty long range (the Stratocruiser was even designed for intercontinental use) and were pretty large aircraft compared to others back then.
Right now a large turboprop aircraft wouldn't make sense since on long haul jets are still cheaper than turboprops.
mandala499
Sun Feb 07, 2016 12:30 pm
Quoting WIederling (Reply 16):
Isn't the TP400-D6 supposed to be at 238g/kWh ?
But then, the NK-12 is about a ton heavier than the TP400 and D-27
The question is how will that efficiency be at high subsonic cruise?
I think there are still hurdles for large turboprops to go up against jets... passenger perception is one... We can go on the Q400 vs CRJ700 and see what's more efficient... and see what's sold more... it's promising for the turboprop... but then we go to the fact that the Atr72 has sold more... and wonder...
Quoting Heinkel (Reply 18):
And do we have orders for passenger versions of the A400? I didn't hear any...
Quoting larshjort (Reply 17):
Just on the SFC alone, the old NK-12 still makes me shake my head...
I think if a widebody prop can carry 200-300 passengers on medium haul cheaper than let's say the 767 and A310, for the same block times as those 2 jets, and the same if not better total and direct operating costs than those 2 jets plus say the A332 and 787... then it might happen... otherwise... forget it.
roseflyer
Sun Feb 07, 2016 12:51 pm
I will challenge that this efficiency difference is dropping with more modern engines. If PW or any other manufacturer can get a large geared turbofan to work, then the propeller won't improve efficiency much. Fans and bypass ratios are getting so big that their efficiency is improving. A huge fan if they can keep much of the blades subsonic is getting close to turboprop efficiency. For that reason I see fewer turboprops in the future, not more.
WIederling
Sun Feb 07, 2016 1:05 pm
Quoting mandala499 (Reply 24):
ref:
http://www.fzt.haw-hamburg.de/pers/S...es_PUB_AST-CD-Version_13-04-23.pdf
a bit burried it is either 167g/kWh shaft power take off or 219g/kWh for propulsion use.
IMU the 238g data point is bogus. and does not fit the picture ( current, historic )
Russians couldn't wipe their ass without help   ( here Germans ) _but_ they invariably siphoned off the inherent knowledgebase and then continued on their own from there. They also have a very good scientific/theoretical base
which makes the difference being good in innovations while the US handyman approach excels in fine tuning and industrialisation.
zanl188
Sun Feb 07, 2016 1:16 pm
New LM-100Js are on offer...
http://www.lockheedmartin.com/us/products/LM-100J.html
Southern Air also operated L-100 Combis complete with FA & booze... Real PITA for us to load cargo due to the requirement for fire blankets on all pallets.
http://www.flightglobal.com/news/art...hern-to-develop-l-100-combi-21893/
Aquila3
Sun Feb 07, 2016 1:31 pm
Why 4 props?
While all the jets are going 2-engines, why a prop should have 4?
Something as the C27J should do.
see: http://www.finmeccanica.com/-/c-27j-fwsar
It is a fine aircraft, and I have seen with my eyes it has incredible capabilities on short and diffcult runways. I think a 100 - 130 seater derivative could be done with great performances, especially for those countries over there in the far North (or South, of course). WB? Ido not think so. 3+3 would be fine IMO.
[Edited 2016-02-07 05:35:37]
WIederling
Sun Feb 07, 2016 1:32 pm
Quoting Aquila3 (Reply 28):
you could resurrect the Transall with new engines
mandala499
Sun Feb 07, 2016 2:32 pm
Quoting WIederling (Reply 29):
Oh that would sell well on the cargo market !
Get rid off those old engines!
incitatus
Sun Feb 07, 2016 2:52 pm
Exactly! The fixation of a.net with aisles is starting to drive me crazy. 2-2-2 is detached from air transportation economics. Any reasonably written senior thesis would kill it. It is like a 6-wheel car!
NoTime
Sun Feb 07, 2016 3:14 pm
Agree that the C-130, A400 and C-27 all come to mind when thinking about this.
I don't see how TATL routes would ever work. But, could something like this work on a short, fat route? If you could manage to get 200 seats into a turboprop, and still see some noticeable increases in efficiency (vs. jets), could you use something like that on a EWR - DCA route or something similar?
rj968
Sun Feb 07, 2016 4:32 pm
Quoting zanl188 (Reply 27):
Thanks for the link on that, that was new to me. I spent lots of time in a C-130 "module" only we called them Capsules at the time. Quiet inside too. Note the galley, an lav at the back
opticalilyushin
Sun Feb 07, 2016 4:36 pm
In the early 1960s there was an idea to turn the Shorts Belfast (still on the drawing board) into a double deck passenger widebody aircraft. I have the pics at home, though i imagine range would not have been great. It could well have been the A380 of it's day..
stlgph
Sun Feb 07, 2016 4:58 pm
and you left out the invention of the jet engine.
zanl188
Sun Feb 07, 2016 5:21 pm
Quoting rj968 (Reply 33):
Pushed an ABCCC off/on a k-loader a time or two.
Wish I had a pic of the L-100 combi setup. It was pretty sweet, from pax side anyway. They were new at the time I worked them, ~1996.
WIederling
Sun Feb 07, 2016 6:15 pm
Tu-114 ( Bear with a Cabin   is said to take 4.2t fuel in cruise.
ref:
http://www.rikoooo.com/images/addon-...14_126_fsx_p3d/manual/history.html
second last para short of "military service"
JETnyc
Sun Feb 07, 2016 6:29 pm
Hence the C-130 a perfect wide body & turbo prop...
peanuts
Sun Feb 07, 2016 6:30 pm
Those windows look very similar like the ones on the L-1011.
Aircellist
Sun Feb 07, 2016 7:40 pm
… ah, a Lockheed Starliner, with turboprops…
MHG
Sun Feb 07, 2016 8:44 pm
Well, there were only two passenger frames ever ...
And IIRC these were not delivered by Lockheed ex works but mil frames converted by IPTN in Indonesia into 100 pax config. including airliner windows and airliner interior. (when inside you wouldn´t know it´s a Hercules unles you looked at the wings ...)
MERPATI was the sole operator these two aircraft. When MERPATI folded both frames were taken over by Indonesian Air Force.
One of them crashed in 2009.
https://en.wikipedia.org/wiki/2009_Indonesian_Air_Force_L-100-30%28P%29_crash
So, only one remains with the Indonesian Air Force and is still in service to date.
(it still has it´s airline style windows visible - don´t know if it´s still in pax config, though)
Ty134A
Sun Feb 07, 2016 8:55 pm
Quoting WIederling (Reply 37):
ref:
the TU-114 was a plane of its time, when passenger air travel was still developing. soviet airliners of this time were very overdesigned, resulting in airframes that could take max fuel and max payload, there were literally no range shortfalls due to MTOW. even with the overdesigned structures, MZFW levels were rather low and went up over the years. the best example for such an airliner is the IL-18. many IL-18 pilots i have talked to refer to this airliner as the best they have ever flown, since it knew no limitations. many told me that they would fly them overloaded by many tons, and still the aircraft would perform overwhelming (they do not say this about the AN-12!). the TU-114 was such an airliner as well, with an astonishing performance.
the maximum fuel onload for this airliner is at just above 60 to. depending on the onload and thrust settings, the burn off will be anything between 4,2 up to 7 to. even though being the fastest, biggest and most capable turboprop in the world, it's economical speed was at about 700 to 750 km/h, bringing it closer to the DH4 than to a TU-154B. also the shortfalls were greater with increasing onloads, and not nearly linear. at the time it entered service, due to it being a low wing design and thus very tall, there were no stairs available for it, and it was too monstrous for many airports, especially in the SU.
the BIGGEST disadvantage was it's noise level. at the time the soviet union's ideology focussed very much on developing mankind, and the TU-114 seemed a step back under these aspects. it in fact was so loud that the noise insulation was even greater than with the TU-144! this was the main reason it got removed from SU's route network and replaced by the IL-62 NK-8 classic versions. the "new" ilyushins could more or less match the performance of the TU-114, even though burning off nearly double on the same payload... but what was fuel at the time??? with the IL-62M D-30 versions, the leap forward was so great, that the counter rotating high speed turboprops were no topic any more in the soviet union. not so much because they were inefficient, but because they were "unsuitable" for airliner use. the NK-12 found it's way onto other projects, such as the AN-22, some ekranoplans and if i am not mistaken even onto some hovercrafts.
from an aeronautical point of view, the NK-12 is one of the most interesting and astonishing engines ever designed! the next thing that comes close to the NK-12 engine in concept is actually the western GE-36 and the PW-578-DX (as well as the D-27). they all have one major disadvantage: they shake you fillings loose during flight!
and from my flight in the IL-62 in the back rows i can only imagine the noise from the TU-114, if the IL-62 was considered silent. i actually also know a person that flew the TU-144, and with this airliner, noise was not so much the impression, rather than the heat... but that is a different story.
Ty134A
Sun Feb 07, 2016 9:01 pm
oooooh... and i forgot to sum it up: a GE90-115 kind-of-innovative counter rotating turboprop would most probably outperform any other propulsion system based on the turbofan, including the GTF. the issue will be NOISE....
but i am sure that a 180-240 seat single aisle aircraft would sell and outperform existing A320/B737s on missions up to 3 hours - and it all depends on fuel prices as well. when every gallon burned counts, it would make sense, and passengers will choose price over engine choice.... they up until now still fly ATRs, don't they???
but for a 60ies design the TU-114/95's NK-12 is a miracle!
Devilfish
Sun Feb 07, 2016 9:19 pm
Quoting Ty134A (Reply 43):
No problem with that. Just have to pick up development of the Progress D-27 engine.....
http://cdn.airplane-pictures.net/images/uploaded-images/2013/1/17/262764.jpg
http://cdn.airplane-pictures.net/ima...loaded-images/2013/1/17/262764.jpg
Better yet, get the whole shebang...    ...
Photo © Stephan Franke - Fighter-Wings
[Edited 2016-02-07 14:20:11]
Burkhard
Sun Feb 07, 2016 9:41 pm
Widebody Turboprops are possible, no question. They are an unexplored technology, so would require some learning curve for the OEM, so the first of its kind is a 10 Bio$ investement.
Turnoprops are slower than jets, and let us assume they use less fuel. So they are all about reducing production cost per seat mile. This limits the potential sales price - they have to be cheap. So I cannot consider a margin per aircrafdt above 5Mio $ - so the question is: Is there a market for far more than 2000 widebody turboprops?
I do not think so. A few hundred sure for short hops like Brussels to London or Rome to Palerrmo, but not thousands.
citationjet
Sun Feb 07, 2016 10:08 pm
Like many others have said, why have twin aisles for 6 across seating? Just do 3-3 seating with a single aisle.
Quoting incitatus (Reply 31):
bennett123
Sun Feb 07, 2016 10:13 pm
Why are so many of these types military.
mjoelnir
I am of the opinion that we will not see a twin aisle turboprop frame or not even a big single aisle one in the near future.
But here is some talk about limitations in speed and service ceiling that do not apply to a turboprop as a rule. If we have a look at the newest big turboprop frame, the A400M, than cruising speed is 422 knots and service ceiling 12,200 m, just about 40,000 feet, not that bad numbers.
[Edited 2016-02-07 14:58:32]
Burkhard
Sun Feb 07, 2016 11:14 pm
The next logical step is a stretch of the ATR72 by about 20 seat - if this succeeds let us see further.
