propilot83
Air Intake Ducts On 777 & 787 Dreamliner?
Thu Feb 25, 2016 6:01 am
Does anyone know what those air intake ducts are for on the underbelly of the Boeing 777 and 787? Is it for keeping the avionics and landing gear cool from overheating? Thanks.
propilot83
RE: Air Intake Ducts On 777 & 787 Dreamliner?
Thu Feb 25, 2016 11:48 am
Anyone there? hello? Any Boeing engineer?
EMBQA
Thu Feb 25, 2016 12:08 pm
Quoting propilot83 (Reply 1):
Without seeing a photo I'm sure its just part of the ACM System...
Dalmd88
Thu Feb 25, 2016 1:38 pm
The two large ducts near the wing root are for the air conditioning packs. The air coming in through them, called ram air, blows across the heat exchangers and cools the bleed air before it enters the cabin. The outlets for the ram air are just forward of the gear wells. The system is very similar on all Boeing aircraft.
OldAeroGuy
Fri Feb 26, 2016 12:29 am
But no bleed air on the 787.
Instead, air intakes on the 787 supply the electrically driven compressors that provide compressed air to the pressurized cabin.
AA737-823
Fri Feb 26, 2016 12:53 am
Wow. Really?
Try helping us by posting a photo, or by being more specific with your question.
Fri Feb 26, 2016 3:04 am
Quoting Dalmd88 (Reply 3):
And Airbus for that matter.
Quoting propilot83 (Thread starter):
The landing gear doesn't need cooling per se. Sometimes the brakes need cooling, in which case the gear is left out (in the air) or actively cooled (on the ground) or you just wait (on the ground).
The avionics bay tends to be further forward, and has another (though related) cooling system.
yeelep
Fri Feb 26, 2016 3:57 am
Quoting OldAeroGuy (Reply 4):
Though they still have heat exchangers, that are fed by a ram air system.
In the picture. below the leading edge wing root you have the ram air/heat exchanger inlet, below that is the compressor intake and just forward of the gear well are the ram air/heat exchanger exhaust doors.
Photo © Yari Strban
propilot83
Sat Feb 27, 2016 6:05 am
Makes sense, thank you, no wonder why TWA-800 exploded in mid-air, center fuel tank explosion.
propilot83
Sun Feb 28, 2016 4:22 am
Quoting AA737-823 (Reply 5):
Wow. Really?
Stop being so sarcastic, if you've knew the answer, you would have known better than the guy I praised Dalmd88.
Users browsing this forum: ArdWar and 33 guests
