2) According to my knowledge TCAS antenna is used to detect proximate traffic vicinity to the aircraft in collaboration with the transponder . Am I correct? Is it the one transmits the 1090 MHZ signal?
thanks a lot!!
Skywalker92
Quoting skywalker92 (Thread starter): 1) Can any one explain me what is the purpose of yellow color ATC antennas located at forward lower fuselage of the aircraft. Although VHF antennas are the ones use for ATC communication why they are called ATC antennas? As highlighted in the attached diagram what are the 2 ATC mode s antennas? Are they performing the same function as lower fuselage yellow ATC antennas? |
Quoting skywalker92 (Thread starter): 2) According to my knowledge TCAS antenna is used to detect proximate traffic vicinity to the aircraft in collaboration with the transponder . Am I correct? Is it the one transmits the 1090 MHZ signal? |
Quoting Starlionblue (Reply 1): VHF can be used to communicate with other stations than ATC, for example other aircraft or company ops. |
Quoting Starlionblue (Reply 1): TCAS antenna would receive on 1090, while the ATC antenna would transmit on 1030. |
Quoting skywalker92 (Reply 2): I do not get an answer for this.. What is the purpose of ATC antennas? |
Quoting boeingfixer (Reply 3): Quoting skywalker92 (Reply 2): I do not get an answer for this.. What is the purpose of ATC antennas? Don't think of the term ATC as in communications. The ATC antennas are transponder use antennas only. |
Quoting Starlionblue (Reply 1): In AirbusLand, the "ATC" system refers to the transponders |
Quoting skywalker92 (Reply 8): Do any one explain me about the frequency used in those antennas ... |
Quoting Starlionblue (Reply 1): As I understand it, the TCAS antenna would receive on 1090, while the ATC antenna would transmit on 1030. |
Quoting skywalker92 (Reply 2): Quoting Starlionblue (Reply 1): TCAS antenna would receive on 1090, while the ATC antenna would transmit on 1030. you are correct, I have made a mistake... |
