johnclipper
Is It Really A 777-200ER?
Fri Mar 04, 2016 11:00 pm
According to the FAA type certificate and all FAA paperwork there is no such thing as a Boeing 777-200ER (or a 767-300ER as well). The FAA Type Certificate for the 777 references five types:
B777-200
B777-200LR
B777-300
B777-300ER
B777F
Boeing uses the 777-200ER for marketing but if you do an N search on the FAA, all 777-200ERs are shown as 777-200s.
Can anyone confirm?
"Flown every aircraft since the Wright Flyer" (guys, if you take this literally, then you need to get a life...)
Stitch
RE: Is It Really A 777-200ER?
Fri Mar 04, 2016 11:52 pm
"ER" airframes have higher operating weights and you can purchase a 777-200ER with the same operating weights as a 777-200, so I could see why the FAA considers them functionally the same because they effectively are.
The 777-200LR and 777-300ER do have structural differences to the 777-200(ER) and 777-300, so I expect that is why they are listed as separate models.
BravoOne
Sat Mar 05, 2016 1:32 am
Sort of like no such thing as a 757-200ER?
Francoflier
Sat Mar 05, 2016 4:18 am
As Stitch said, there are essentially no structural or systems differences between the -200 and -200ER, save for a larger center tank on the latter.
I didn't know the FAA considered it as a single type either, but I guess it makes sense.
FlyCaledonian
Wed Mar 23, 2016 11:56 pm
Isn't this related to the fact that Boeing originally didn't want to offer a 777-200ER? The aim of the 777 programme was to have ETOPS from the get-go, which was achieved. Designating aircraft as 'ER' was seen as implying that there had been some sort of big improvement.
The first aircraft were 'A' models, what we today just reference as a 777-200 (e.g. BA's first 777-236, G-ZZZA).
The 'B' model was to offer higher MTOW and thus was able to offer more range. This was marketed as the 777-200IGW (Increased Gross Weight). After taking its first five 777s as 'A' models, BA took the next batch as 'B; models (e.g. G-VIIA). I recall BA initially referring to these as 777-236IGWs.
The 'ER' label crept in at some point over IGW to the extent that by the time BA took RR powered 777-236s (e.g. G-YMMA) they were known as 777-236ERs.
I believe BA internally refers to the RR powered birds as 777-236ERs (they have overhead crew rest and are used on some on BA's longest flights, e.g. LHR-EZE) whilst the GE birds are 777-236s. This was how many interpreted a recent IAG investor day presenetation where BA said the 777-236ERs were going to lose First. Many thought that meant the G-VIIx and G-YMMx birds, although I believe a consensus from BA insiders was that it was just the RR birds (well the 9 with First).
The 777-300ER makes sense, because there is a big improvement on the 777-300 (including structual changes). The 777-200LR is I guess because the 777-200ER designation had come in unofficially as 777-200 weights increased, so Boeing needed a way to distinguish that the 77L was an aircraft with sufficient changes. Maybe it should have been 777-300LR as well!
Let's Go British Caledonian!
Thu Mar 24, 2016 1:06 am
Quoting johnclipper (Thread starter):
Can anyone confirm?
That is correct, the operational differences between 777-200s are covered in the approved flight manual (AFM) level, not type certificate level. Operators can pay for additions to the base airframe which will be reflected in the AFM, this costs extra money. Note the 777-200, 777-200LR, and 777F are different variants.
johnclipper
Thu Mar 24, 2016 12:32 pm
So then, is there actually a 777-200ER or are they all just 777-200s at different MTOWs?
Stitch
Thu Mar 24, 2016 8:00 pm
Quoting FlyCaledonian (Reply 4):
Boeing always intended to offer the 777 with higher operating weights - it's one of the reasons the 777-200(A) is so heavy as it was designed and engineered to support those future weights.
As you noted, the early designation was IGW (at least internally). However, I believe Boeing has always used ER for their longer-ranged variants (the earliest ER model I know of was 1984's 767-200ER) so when it came time to formally enter service, it became the 777-200ER.
Quoting johnclipper (Reply 6):
For purposes of certification, there is not a 777-200ER model.
For purposes of marketing, there is a 777-200ER model.
pygmalion
Thu Mar 24, 2016 9:54 pm
Boeing renamed the 777-200IGW to the 777-200ER when it developed and sold the 777-200LR and 777-300ER programs in the 2002ish time frame. The 200IGW and the now called 200ER are one and the same structural airframe with some additional common changes that were slotted in when the 200LR/300ER went into production.
7BOEING7
Fri Mar 25, 2016 4:57 am
Quoting Stitch (Reply 7):
When the first Malaysian 777 flew it's round the world record flight in April of 1997 all the record paperwork designates it has a 777-200-IGW so it was a little more than internally.
Sun Mar 27, 2016 9:11 am
They are 777-200s with different AFM limits, e.g. fuel volume, fuel distribution, loading&balance, thrust, performance, and weight limits.
mmo
Sun Mar 27, 2016 2:10 pm
Sorry but this is the best I could do.
This is the listing of all B777 types from the FAA Type Certificate Data Sheet.
777-200 Series T00001SE Rev. 38
777-200LR Series T00001SE Rev. 38
777-300 Series T00001SE Rev. 38
777-300ER Series T00001SE Rev. 38
777F Series T00001SE Rev. 38
http://rgl.faa.gov/Regulatory_and_Gu...keModel.nsf/MainFrame?OpenFrameSet
Can we please stop beating this dead horse!!!
Sun Mar 27, 2016 4:59 pm
Quoting mmo (Reply 11):
He already posted that in the OP.
BravoOne
Sun Mar 27, 2016 9:22 pm
Quoting zeke (Reply 12):
Zeke...I bet you are fun to fly with on a six day trip
mmo
Sun Mar 27, 2016 9:28 pm
Then why is the same question being repeated over and over and over and over and over and over and over and over and over and over and over.......get my point????
It may be posted but apparently not comprehended!!!
johnclipper
Mon Mar 28, 2016 2:07 am
Dude, you don't have to be an a$$ about it. It's comprehended but apparently from the number of posts there is no consensus. And for the record, I only reiterated the question once.
mmo
Mon Mar 28, 2016 11:02 am
Quoting johnclipper (Reply 15):
B777-200
B777-200LR
B777-300
B777-300ER
B777F
Can anyone confirm
I have to ask since you opened the door........Why????? It's pretty clear from the FAA TCDS. I really don't care if there is a consensus on this forum or not. The simple answer is they are all 777-200 aircraft. The FAA decides that, not this forum!!! So I guess you can stop being an ***!
AMF!!!
Users browsing this forum: No registered users and 16 guests
