Quoting L.1011 (Thread starter): I'm thinking of the places where runway length or hot and high biases airlines toward the 752, 73G, 319, and 346, and away from the 739, 321, or 343. |
Quoting L.1011 (Thread starter): |
Quoting Mcoov (Reply 1): There's FNC, who's runway was so short, they needed to build a runway on top of a pier in order to extend the old runway. |
Quoting Web500sjc (Reply 3): SNA |
Quoting Pyrex (Reply 5): Surprised nobody has said SDU and LCY yet. Those runways are so challenging the planes themselves need to be specially modified / certified for them. |
Quoting Woodreau (Reply 6): For ASE although the runway has been extended from 7000ft to 8000ft for toda and lda are still listed as 7,000ft and that is what is used for planning takeoff and landing performance there. |
Quoting FlyASAGuy2005 (Reply 7): For American/B6, the 320 is a pig. There's usually a heavy passenger cap set. |
Quoting L.1011 (Reply 8): I seem to recall reading that SA has kept/is keeping the 346 around because it can handle JNB better than most. Is that true? |
Quoting LAX772LR (Reply 2): 2) ....you don't seem to realize that the A343 actually has shockingly GOOD takeoff performance from a short runway, when you throttle it to its full capability. |
Quoting mandala499 (Reply 10): Quoting LAX772LR (Reply 2): 2) ....you don't seem to realize that the A343 actually has shockingly GOOD takeoff performance from a short runway, when you throttle it to its full capability. A343 has good take off performance, yes, true and factual, but it is considered blasphemy here! |
Quoting L.1011 (Reply 8): I know it's still a challenging airport for pilots, but I see the runway is 9100 ft now. Is it a challenging airport for aircraft anymore? |
Quoting L.1011 (Reply 8): SDU is the airport which spurred Boeing to offer the short field performance package for 737NGs, is it not? |
Quoting L.1011 (Reply 8): AFAIK, 7000 ft is plenty for your average mainline narrowbody not stretching its range, and hot obviously isn't at play during ski season, so it's just the extreme altitude at play, correct? Does increased runway altitude (holding all other variables equal) increase takeoff distance in a linear way for all types more or less or is this the kind of thing that a specific type's performance chart needs to be consulted for? |
Quoting Woodreau (Reply 6): Well none of the aircraft you listed: 752, 73G, 319, and 346, and 739, 321, or 343 are capable of flying into ASE. |
Quoting flyboy80 (Reply 14): I did see a Hawaiian A332 depart Maui the other day. It left from the runway nearest the water with a lot of help from the wind. The mains left the ground at the 3K marker and it floated up non-aggressively; still I was in awe. |
Quoting Woodreau (Reply 13): Aircraft are limited to a maximum 95ft wingspan and Max takeoff weight of 100,000lbs or less to operate into ASE so you are not going to see any narrow body airliners flying in and out of ASE. |
Quoting seabosdca (Reply 15): Worth noting that this is not because of the runway length, altitude, or terrain but because of the wingspan and MLW limitations imposed by airport rules. Lift those limitations and 73G, 319, and 752 would all do just fine. |
Quoting L.1011 (Reply 16): I see OGG is only 7,000 ft. Are widebodies able to get out of there only because of relatively light fuel loads for the West Coast? |
Quoting BoeingGuy (Reply 18): and DL previously did a 767-300 OGG-ATL. |
Quoting LAX772LR (Reply 19): Pretty sure the furthest inland nonstop scheduled from OGG has been OGG-ORD. |
Quoting LAX772LR (Reply 19): IINM, DL's routing was ATL-OGG-DFW-ATL with the L10s, and later ATL-OGG-LAX-ATL with the 767s. Pretty sure the furthest inland nonstop scheduled from OGG has been OGG-ORD. |
Quoting L.1011 (Thread starter): airports with short runways where little demand leads to small aircraft |
Quoting L.1011 (Thread starter): 752, 73G, 319, and 346, and away from the 739, 321, or 343. |
Quoting L.1011 (Reply 8): Do the special modifications to the BA A318s for LCY extend beyond software programming? Any hard changes to the airframe? |
Quoting LH707330 (Reply 24): Quito is another one, but I heard they're opening a new airport at lower altitude with a longer runway. |
