cloudboy
What Does Shortened Mean?
Wed Apr 13, 2016 7:28 pm
I have been listening to a few youtube JFK ground conversations, and they often say runway 13right shortened. What does the shortened mean?
"Six becoming three doesn't create more Americans that want to fly." -Adam Pilarski
futureualpilot
RE: What Does Shortened Mean?
Wed Apr 13, 2016 8:03 pm
It means that runway temporarily has a shorter useful length for arriving and departing aircraft than it normally does. We see this most often as a result of construction that closes a portion of the runway.
Life is better when you surf.
nws2002
Wed Apr 13, 2016 8:07 pm
Here's a pretty good description of what it means from the FAA:
http://www.faasafety.gov/SPANS/noticeView.aspx?nid=3380
I'm not sure why 13R at JFK is currently shortened, but it is commonly used when one end is under construction, I know this was the case over the summer at JFK last year.
Wed Apr 13, 2016 11:48 pm
Shortened runways are NOTAMed, so pilots should know about any such things, but ATC will tell you because it's a bad day for everyone if it has been missed.
AAR90
Thu Apr 14, 2016 3:07 am
Quoting Starlionblue (Reply 3):
The word "shortened" as used by USA ATC is to inform the crew the runway has been "shortened" from its full length and the details (exactly how much runway is available) are in a published NOTAM. This greatly simplifies radio traffic making radio communications significantly easier. JFK ATC was using the term for a few months PRIOR to it becoming a published part of the "official" ATC vocabulary. Now that the term has been published, it should not be a surprise to pilots (anymore).
cloudboy
Thu Apr 14, 2016 3:59 pm
Ah, thank you. I thought that might be it, but wasn't sure.
Users browsing this forum: Francoflier, Mytola and 24 guests
