badgervor
Does Payload Include Container Tare Weight?
Wed Apr 27, 2016 5:00 pm
Was wondering when an airplane is container loaded, is the tare weight of the container figured into the payload weight? For example, if it says an aircraft can carry 110,000lbs payload, does this include the empty container weight?
CrimsonNL
RE: Does Payload Include Container Tare Weight?
Wed Apr 27, 2016 8:11 pm
It's up to the airline really. I work with +20 airlines and the only ones that used to have the container weight included into the aircraft Dry Operating Weight were IB and VY. They changed this a few years ago. It's now part of the payload, which makes much more sense because not all ULD types weigh the same, so you were dealing with a lot of DOW tables. Pretty much all airlines just include it in the payload.
Martijn
77west
Thu Apr 28, 2016 5:35 am
How much does the average can weigh empty, 200kg, 400kg?
77West - AW109S - BE90 - JS31 - B1900 - Q300 - ATR72 - DC9-30 - MD80 - B733 - A320 - B738 - A300-B4 - B773 - B77W
CrimsonNL
Thu Apr 28, 2016 5:39 am
Quoting 77west (Reply 2):
The average LD3, say an AKE used in anything bigger then a 767 is usually around 85-90kg. An AKH used on Airbus narrow bodies are somewhere between 70-85kg depending on wether they are metal or fiberglass.
Martijn
QFA380
Thu Apr 28, 2016 8:18 am
All the AKE cans I work with weigh 65kg, fitting ~40 bags and up to 1200kg of weight. Pretty impressive. They get beaten around quite a bit. In the scheme of loading the can weight is pretty insignificant. Each one weighs as much as one person or 3 bags. A transpac 77W only needs 8-10 cans typically leaving a lot of room for cargo, the capacity is 44 so you can see why cargo filling that empty space is so important if weight permits.
I cannot see why it would be included in the aircraft weight and we certainly count it as payload. Some airlines will always carry x number of cans to ensure outstations have enough particularly with short turn times where offload/reload would cause delays which may be the only instance it could make sense.
Shuttle12T
Thu Apr 28, 2016 10:37 am
ULD Tare weight makes up part of the payload, to include it as the DOW then you would have to be carrying a set number of them on each sector. As has been mentioned above dependant on type they generally weigh around 80kg or so each, so a full fit on an A321 (10 positions) would equal almost a ton, on something like a 77W then your talking about potentially 2 tons. It's not unheard of for people to forget the Tare weight when doing manual load sheets, thankfully all of my airlines that use containers use system generated load sheets so the weight is automatically included.
Don't miss a trip report: https://voyagereport.wordpress.com
CXfirst
Thu Apr 28, 2016 1:46 pm
Airline I work for has them in the payload. They have a database for their AKE's (rather the two first numbers indicate AKE type, ie fibreglass or metal). These get automatically entered into loadsheets when AKE numbers are put in.
As for other ULD's, freight would send weights, which included both the actual cargo weights and the gross weights including the ULD itself. The gross weights get onto the load sheet.
Didn't actually think anyone would have them as part of the Dry Operating Weight. Especially with all the different combinations of ULD types that are possible.
-CXfirst
Thu Apr 28, 2016 2:00 pm
Quoting CXfirst (Reply 6):
Can't positions be filled by pallets whose load is secured by a cargo net? So it's not always a container.
[Edited 2016-04-28 07:02:18]
CrimsonNL
Thu Apr 28, 2016 4:56 pm
Quoting Starlionblue (Reply 7):
That's something we encountered from time to time when the crew of IB said the loadsheet was incorrect. They'd say the DOW was off by 45kg when we had a PKC pallet of 35kg loaded instead of an 80kg AKH which they were expecting. I'm really glad they did away with ULD's in the DOW!
Martijn
badgervor
Thu Apr 28, 2016 5:05 pm
Thanks everyone for the info!
113312
Wed May 04, 2016 4:52 pm
Of course, the weight of the containers or pallets plus tie down equipment, are part of the "payload" weight being carried. Depending upon the operator, the means of weighing a completed unit varies. Of course, a large aircraft with lots of containers carries a substantial load that is tare and is not generating revenue. So it's up to the marketing department to figure what the potential revenue load is for their operation and price the tariff accordingly.
An operator could opt to include the tare weight of loading equipment into their Basic Operating Weight for the aircraft, but that would mean that they would have to carry that stuff on every flight regardless of revenue load.
It comes down to terms. An aircraft seller likes to quote the largest "payload" number it can. To do that, they usually subtract the empty weight from the maximum gross takeoff weight. But a practical revenue payload figure must factor the fuel load required for the flight segment, the performance limited gross takeoff weight, and the tare weight of any containers or cargo restraint equipment carried.
Users browsing this forum: estorilm, plinth857, thepinkmachine and 19 guests
