FlyingBlueKLM
Can Aerosoft Bonaire Flamingo Airport X also be used on P3D v4?
Mon Apr 06, 2020 10:44 am
I’m running P3D v4.5, and this is the only good Flamingo Airport scenery I could find, but does it work with P3D v4? It doesn’t say so in the link, and I have seen P3D v4 video’s with Aerosoft TNCB, but is that another version designed for v4, or can I use this v3 version on v4.5?
Link: https://www.aerosoft.com/en/flight-simu ... -airport-x
KJFK - EGLL:
Concorde: 2 hours, 52 minutes, and 59 seconds
Boeing 747: 4 hours and 56 minutes
ryan78
Re: Can Aerosoft Bonaire Flamingo Airport X also be used on P3D v4?
Mon Apr 06, 2020 6:51 pm
Yes it does. I recently switched over to P3D v4.5 from FSX and swapped everything I could over to P3D v4. A lot of scenery's had their own installers for P3D so it was a breeze, but a few, like AS Bonaire, were for FSX only so it was a matter of trial and error. I haven't spent a ton of time flying around Bonaire, when I installed it I loaded it up and did a quick circuit and everything looked and operated as normal. Actually there are a lot of FSX payware scenery's that I currently run in P3D v4 with little to no issues at all. The only major problems I've had are with Taxi2Gate Cuban Airports and a few older releases for FSX.
FlyingBlueKLM
Tue Apr 07, 2020 9:05 am
I installed AS Bonaire today, but after the installation, I still only had the default airport. When Setup asked me which sim I was using, I clicked on P3D v3 because v4 wasn’t an option, and I don’t have v3 installed:
https://imgur.com/a/limdbMX
Then I selected my v4 directory:
https://imgur.com/a/mIpA0o7
And then I got this window:
https://imgur.com/a/VEbnWyV
It wanted to install some things into a nonexistent v3 directory. When I was done with the installation, Setup did not create v3 directories. The only sims on my PC are FSX Steam and P3D v4.
KJFK - EGLL:
ryan78
Tue Apr 07, 2020 11:55 am
What I did was install it manually into P3Dv4. When you get to the screen to select a folder to install the scenery to I set it to my desktop. It will then extract a few folders to your desktop, not sure exactly which ones as I am not on my pc, but it'll be something along the lines of an Aerosoft folder, a Texture folder, a Scenery folder etc. All you have to do is manually add the folders to P3Dv4 and it should work.
Also don't forget to manually add the scenery to your sim. It might be in the sim folder but wont show up unless you add it to your scenery list in P3Dv4.
FlyingBlueKLM
Tue Apr 07, 2020 12:09 pm
What I did was install it manually into P3Dv4. When you get to the screen to select a folder to install the scenery to I set it to my desktop. It will extract a few folders, not sure exactly which ones as I am not on my pc, but it'll be something along the lines of and Aerosoft folder, Texture folder, Scenery folder etc. All you have to do is manually add the folders to P3Dv4 and it should work. It worked for me and I have had no issues with it.
Shortly after I made that post I found the solution: when it asks which sim you’re playing, select P3D v3, and when you need to select your installation directory select your P3D v4 root directory. When the installation is completed, start P3D, open the scenery tab, and add the scenery. You need to browse to your P3D root directory, and then you need to browse to Aerosoft\Bonaire X\Bonaire_Bravo. Then click on OK and make sure you have selected “use this scenery”. Then just apply the scenery. And then you’re done! For me, this works perfectly.
KJFK - EGLL:
ryan78
Tue Apr 07, 2020 12:14 pm
Excellent. Enjoy the scenery. I might do some flying there later tonight after talking about it. It's a great scenery and a place that I would like to visit in the future, it looks like a beautiful island.
Users browsing this forum: No registered users and 21 guests
