thebunkerparodi
converting a 747 8 into a 747 400?
Sat Sep 05, 2020 8:25 am
Hello, how hard would it be? I'm asking because the revell 400 is verry rare now and when it's on ebay ,it's always too costly for me . I'm also asking for a 747 400F using a 747 8F and both kit are from revell (though I can also use the vezda for a 400).
VSMUT
Re: converting a 747 8 into a 747 400?
Sat Sep 05, 2020 12:58 pm
The wings and engines are completely different.
You can find the Revell 747-400 for decent prices on eBay, just have some patience and search for a bit. But do keep in mind that the Revell 747-400 nose is shaped incorrectly. The best way to fix that would arguably be to graft on the nose from a donor 747-8 kit. You will also have to make some big modifications to the wing-fuselage joint, as it is mounted at an incorrect angle.
thebunkerparodi
Sat Sep 05, 2020 1:09 pm
I know about the nose ,wouldn't it be easier to just use putty?
VSMUT
Sat Sep 05, 2020 1:15 pm
Easier, no. Cheaper, yes. You need to crimp it in, so just applying putty won't solve it. You need to chop, bend and reglue the nose.
thebunkerparodi
Sat Sep 05, 2020 2:56 pm
ok ,I guess I'd better use hasegawa if I want a normal 400 ,although for a 400F ,I'll have to use a 8F for the conversion
Boeing757100
Sat Sep 05, 2020 5:06 pm
and also isn't the 400 slightly shorter than an 8i?
Going to ATL airport in 2019 is like being in 2013
Going to ATL airport in 2010 is like being in 2000
Going to ATL airport in 1998 is like being in 1988
Going to ATL airport in 2035 is like watching paint dry
thebunkerparodi
Sat Sep 05, 2020 6:27 pm
yes ,either way I would have to change the engine and shorten the fuselage
VSMUT
Sun Sep 06, 2020 10:01 am
The 1/144 Hasegawa 747-400 is a rebox of the Revell kit. You can also source the short hump from the Revell or Airfix 747-100/200.
Stretching and shortening the fuselage is easy enough.
thebunkerparodi
Tue Sep 08, 2020 6:40 am
for the hasegawa ,it's the 1/200 kit that I will use
EI202
Fri Oct 30, 2020 11:42 pm
Is there any hope of revell re-releasing the BA 744 kit but in 1997 livery to mark their retirement?
VSMUT
Sat Oct 31, 2020 10:37 pm
You are lucky if they re-release it in any markings.
Lufthansa just retired theirs. With Revell being German, I'd place my bets on a Lufthansa livery more than BA.
EI202
Sun Nov 01, 2020 9:34 pm
To be honest, any livery at all would do for me!
Dadofthree
Sat Apr 03, 2021 5:25 am
This might help
https://www.airlinercafe.com/forums.php ... 3133#73133
Or this
https://www.airlinercafe.com/forums.php?m=posts&q=10468
Stevej's post #68941 has a series of photos that I found very informative.
HTH
Users browsing this forum: Google [Bot] and 5 guests
