dbob0921
Logitech / Saitek Flight Instrument Panel not working FSX Deluxe
Sun Sep 18, 2022 3:02 pm
Hi,
I have recently bought a Logitech / Saitek FIP for my flight simulation setup. The setup consists of the following:
Logitech / Saitek Yoke
Logitech / Saitek Throttle Quadrant
Logitech / Saitek Rudder Pedals
Logitech / Saitek Multi Panel
Logitech / Saitek Switch Panel
A FIP that doesn't work.
I am running FSX Deluxe Edition on Windows 10. I have installed all of the necessary drivers for the panel, but it is not working correctly. Whenever I open FSX, the drivers load up and the FIP displays gauges and instruments. When I create a flight, the panel does not respond to what is happening in FSX; the numbers just stay at 0 and the instruments don't move. The only parts that work as you would expect are the up and down arrows, and the adverts page.
The Logitech drivers didn't work with my Multi or Switch panel either, but I have now working thanks to SPAD (http://fstools.weebly.com/).
I have also tried using alternatives for FIP drivers, like downloading the old saitek drivers from the saitek FTP, which didn't solve my problem. Another alternative I tried was SPAD.next, but that didn't work either. SPAD.next also stopped my Multi and Switch panels from working, so I uninstalled it. The only other possible method I can think of is messing around with the exe.xml file or similar.
If anyone can help me to get these working, I will be eternally grateful.
David Chanter
dbob0921
Re: Logitech / Saitek Flight Instrument Panel not working FSX Deluxe
Sat Oct 01, 2022 3:58 pm
I will no longer be needing answers, as I have returned the product.
Users browsing this forum: No registered users and 16 guests
