bimmerkid19
RE: Your Longest FS Flights.
Mon Jun 25, 2007 3:17 pm
Quoting AAden (Reply 92):
lax to sdy 12hr 52minutes
i think you meant LAX to SYD correct?
Last flights: LH 3738 MUC - ZRH , LH 3749 ZRH - MUC . Upcoming: EK 50 MUC - DXB 3-aug. and EK 322 DXB - ICN 7- Aug.
edelag
Tue Jun 26, 2007 8:36 am
"Modified" MX A330
MEX-KUL
8,996 NM
23:56 flying time
Left Mexico City at 5 AM arrived in Kuala Lampur at 4 PM the same day.
It's not just the destination, it's the journey.
Acey
Thu Jun 28, 2007 4:14 am
My longest is LAX-DEL in a 77L which I flew last week; it was about 16 hours. Whenever I get around to it I'll be flying CGK-MCI, which should be just shy of 18 hours and is a couple hundred miles longer than EWR-SIN.
If a man hasn't discovered something that he will die for, he isn't fit to live. -- Martin Luther King, Jr.
EZEIZA
Thu Jun 28, 2007 6:12 am
My longest real time flight was from Pyong Yang to Auckland on a fictional AR 787, something around 11 hours.
Another long one in real time was from EINN to VABB on a 772. Just over 9 hours, including a go around (that really pissed me off by the way  Wink )
Carp aunque ganes o pierdas ...
777-200
Thu Jun 28, 2007 11:47 am
KATL-RJAA in a Delta 777
Another Day, Another Dollar.... Young Jeezy
JAM747
Fri Jun 29, 2007 12:38 am
My two longest were JFK to SIN with a lightly loaded 747-400 and cruising at mach .82 insteas of my usual .85 which saved some fueland gave more range. Also, I did attempt NRT to GRU non-stop but had to make a fuel stop in Georgetown Guyana which was still a very long flight. I forgot how long each flight took but I think they were at least 18hrs.
ANITIX87
Fri Jun 29, 2007 2:48 am
Quoting Edelag (Reply 101):
8,996 NM
23:56 flying time
That's a SLOW flight, man! That's an average ground speed of 360 knots! You must have had quite a headwind!
I recently broke my record.
I flew EBBR-WSSS (BRU-SIN) in a BA772. My landing into SIN was embarassing. I came in too high, had to nose-dive down at like -3000 fpm, flared at the last second, but flared too much, halted my descent completely, so I had to put the nose gear down first, and then the MLG. And when the MLG came down, my nose wheel was turned so the plane skidded, almost off the runway, and blew its tires. I have a video of it. Quite atrocious.
TIS
Acey
Fri Jun 29, 2007 2:50 am
8,996 NM
23:56 flying time
On its record setting flight, the Worldliner flew about 2,000 more nautical miles in less time than that.  Smile
bimmerkid19
Fri Jun 29, 2007 4:02 am
Another to add to the books.. last night i flew :
Aeromexico flight
AM 57
Pushback from gate 65 at 2:55 PM Tokyo time Local..
Departure from NRT at 3:05 PM after a 10 minute taxi
Arrival at TIJ at 8:40 pm at gate 1 from NRT after a flight of 10 hours and 35 minutes.
Aircraft type: Boeing 777-200LR
san747
Fri Jun 29, 2007 5:47 am
I've flown EWR-NRT before... 14:00 logged in a 747-400.
Scotty doesn't know...
elcableguy77
Fri Jun 29, 2007 6:34 am
I think my two longest flights were:
ATL-LHR in a Delta 777
CLT-SNN in a US Airways A330-200
Both flights were flown in real-time, and both in the 7 hour range.
Former ZW F/A | "Wisconsin 72A, contact departure, see ya."
Acey
Fri Jun 29, 2007 1:43 pm
Quoting Acey (Reply 102):
CGK-MCI
Did it today online VATSIM, total flight time was 18 hours and 10 minutes in the 77L. Departed 0015Z, arrived 1825Z.  tired
Indy
Tue Jul 03, 2007 6:06 pm
I tried SEA-NRT on normal speed. After about 3 hours I figured I must be on crack and just closed the flight.
Indy = Indianapolis and not Independence Air
WestJetForLife
Fri Jul 06, 2007 9:25 am
Longest flights:
SEA-SYD Flight time: 14:46
SEA-HKG Flight time: 10:09
SEA-FRA Flight time: 10:10
SEA-MUC Flight time: 10:40
SEA-PPT Flight time: 12:20
All of these flights were completed in the 747-400, naturally, during 1X time, flying as Pacific Airways flights. Flight times were recorded as start-up to shutdown at departure and arrival gates.
I have since "retired" from these long flights, and I am now flying the 737-700/900.
Nik
I need a drink.
aace24
Thu Aug 02, 2007 6:29 am
MIA-MAD AA 763
NRT-DFW AA 777
JFK-FRA LH 744
ATL-CDG DL 777
PHL-ZRH US 762
CDG-ORD UA 763
And now I'm in the middle of SFO-HKG in a UA 744.
All in real time.
flymia
Fri Aug 03, 2007 4:07 am
Just did MIA-BOM. Took off at 18:20 and landed at 10:00. Nice long flight, now my longest flight. I will be flying back to MIA later tonight.
n710ps
Fri Aug 03, 2007 7:39 am
I am lame compared to you guys but than again I also do not generally have the time for simming anymore like I used to. I did GLA-PHL in a 757 and than continued to LGA in a DHC8 and than up to MHT in a BE1900. I cheated and used the "autopilot" to fly and went to a bar. My game plan if I came home with someone  Wink which I did not that night was to quick unplug the computer a few paces ahead of my "guest" lol.
There is plenty of room for Gods animals, right next to the mashed potatoes!
Longhornmaniac
Sat Aug 04, 2007 5:53 am
Just did MEL-LHR real time. 18 hours....
Cameron
Cameron
pizzaandplanes
Sat Aug 04, 2007 7:54 am
EWR-JFK - The long way around!  Wink
I can't concentrate on flights over 1.5 hours. Do you guys go to sleep as your flight is on auto-pilot?
A real man lands where he wants to
northstardc4m
Sat Aug 04, 2007 8:29 am
Quoting Pizzaandplanes (Reply 118):
yup... thats about it... sleep, watch TV, do stuff... come back and land it.
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
FighterPilot
Sun Aug 05, 2007 7:24 am
Quoting NorthStarDC4M (Reply 119):
What about when ATC tells you to switch freq?
Cal  airplane
*Insert Sound Of GE90 Spooling Up Here*
northstardc4m
Sun Aug 05, 2007 8:38 am
time to explain the "how to ignore ATC" trick:
1> wait until you are at cruising alt
2> wait for center handoff
3> confirm handoff
4> swtich freqs
5> DO NOT CONTACT NEW CENTER
now just let the autopilot take you there...
when you are say 150nm from destination, contact the currently available center, and if it start telling you to turn around 180*... just keep confirming until it calms down and tells you "resume own navigation". Once in a long while it will get stuck and keep telling you to fly to a point 3000nm behind you. Just cancle IFR in that situation.
Enjoy...
edelag
Tue Aug 14, 2007 2:13 pm
Just completed one of the world's most long possible direct nonstop routes.
SYD-SMA
10,553 nm
22:55 flying time.
Here's a pic of the flight report.
Big version: Width: 1280 Height: 1024 File size: 368kb
Saludos
EZEIZA
Wed Aug 15, 2007 2:58 am
Quoting NorthStarDC4M (Reply 121):
Never thought of that, thanx! I would always just let it fly and start descending to destination by myself and then just get landing clereance.
I'll try a long flight tonight and try your method  Wink
regards  Smile
jamesbuk
Wed Aug 15, 2007 4:09 am
Quoting Edelag (Reply 122):
Cheat did ya? :p How could you have flown for close to 24 hours... yet still have 99.000lbs of fuel left?
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
edelag
Sat Aug 18, 2007 3:08 pm
To tell you the truth the only "cheat" that I did was that in aircraft.cdg I lowered the empty aircraft weight about 60000 lbs.
EZEIZA
Sat Aug 18, 2007 3:30 pm
After using the ATC cheat I just finished MAD-NRT, 12hr03min total Big grin
regards  Smile
steve110340
Tue Aug 21, 2007 2:13 am
Mine was
IAH to Frankfurt Germany Continental DC-10-30 10 hours real time
Steve
Eirjet
Wed Aug 22, 2007 8:21 am
My longest flight was/is DUB - DUB (around the world trip non-stop) flying a Cessna 172, it was 34 days 6 hrs and 11 minutes.
Aviation has a 100% record, we've never left one up there......
vhqpa
Thu Aug 23, 2007 7:14 pm
Longest nonstop using increased time rate was TLS-NOU 9306nm in a Posky 342
Longest realtime was MEL-SIN 3253nm in a Meljet 744
J
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
aviator1990
Sat Sep 29, 2007 12:37 pm
My longest flight was from Los Angeles (KLAX) to Narita Int. (RJAA). It was real time and it took 10 hrs. I left my PC over night and was flying with my friend in multiplayer in FSX. It was sort of fun. well not really.
extspotter
Fri Oct 05, 2007 1:14 pm
Mine isn't that long (but I am still new to FS) BOS - DUB in a fully loaded 738.
I ended up gliding all the way from RANAR because I ran out of fuel!
AF BE BY FR MV PD SZ U2 VZ DHC6, 8-3/4Q, 732/8, 763ER, A319, A380
Longhornmaniac
Tue Oct 16, 2007 3:50 am
Well, over the last little more than two days I've done:
SQ 21- EWR-SIN A345 blocked at 18 hours 22 minutes (longest commercial flight in the world)
SQ 954/3- SIN-CGK-SIN A345 (not long at all...lol)
SQ 326- SIN-FRA 773 (about 13 hours)
AA 71- FRA-DFW 772 (about 10 hours)
All real time.
Cameron
Cameron
Jetsa
Thu Oct 18, 2007 4:16 am
My longest flight was YSSY-KLAX with a QF 747-400. 14 hours. I did it with my friend whos dad works for QF.
mdodd
Sat Oct 20, 2007 12:31 am
Quoting JamieD (Reply 2):
My longest was SIN-EWR, SQ A340-500. 18 hours, not sped up either!
Yay for EWR and long-flight-ness!
I give you 'madd props' (yo) for that duration of flying!
OlegShv
Thu Oct 25, 2007 10:55 pm
SVO-JFK, DAL31, almost 11 hours on VATSIM, no time acceleration.
