[email protected]
Accidentally Removed Default Aircraft.Help Needed!
Sat May 10, 2008 2:57 pm
While I was clearing out some of the less attractive Project AI models, and replacing them with better looking ones, I somehow managed to reinstall the standard AI traffic that comes with FS2004.
I tried using the "remove default commercial traffic" installation I downloaded from Project AI long ago, but for some reason the default AI planes were still there.
So I went straight to the Aircraft folder and started removing the Soars, Landmarks etc from the 737, 777, 747 etc folders. But in the heat of battle I thought it would be easier to just remove the entire folders instead, as the only AI traffic located in them was the default ones I wanted to get rid of in the first place. So I deleted them all, only to realise afterwards that I'd still need the folders to make the default panels and sounds to work. (Most, if not all of my downloaded aircraft need these folders to work properly...)
A real "slap head and see how many swear words I remember" moment, as I have removed the folders from the bin, and can't find the default FS2004 aircraft anywhere to put back in the aircraft folder. I don't want to reinstall FS2004, as it would overwrite all the added traffic and scenery which has taken months to download and get to operate.
So what do I do...?  Sad
I'm pretty sure Project AI had a "reinstall default commercial traffic" installation as well, but I can't find it anymore, and I'm not even sure it would help if I did... as it is the basic aircraft I need.
[email protected]
"If guns don't kill people, people kill people - does that mean toasters don't toast toast, toast toast toast?"
jamesbaldwyn
RE: Accidentally Removed Default Aircraft.Help Needed!
Sat May 10, 2008 4:12 pm
Backup files that you need somewhere else on your computer - EG Desktop and reinstall, then simply copy it over.
Remember to backup (Saying this because I've made this mistake Big grin)
Scenery
Aircraft
Gauges
Sound
Modules
Good Luck  Smile
trekster
Sun May 11, 2008 12:29 am
Instead of using default panels and sound, why not download better ones from avsim??
Have done that for some of my airbus and boeing models.
Where does the time go???
jamesbaldwyn
Sun May 11, 2008 12:45 am
PM Me. I'll upload the files you've lost and send them over if you want.
[email protected]
Wed May 14, 2008 1:04 pm
Ok, I guess I might as well download "proper" panels and sounds for the aircraft I use... But if I ever dicide I want the originals back, I'll let you know James.
Thanks for advice.  Smile
[email protected]
jwenting
Wed May 14, 2008 4:07 pm
Quoting Jamesbaldwyn (Reply 3):
And that's illegal.
The files can be extracted from the cab files on the installation disks.
I wish I were flying
jamesbaldwyn
Wed May 14, 2008 4:30 pm
Quoting Jwenting (Reply 5):
And that's illegal.
How is that illegal? I believe that as we both own the files it shouldn't be a problem.
