DashTrash
Need FS9 Help
Mon Sep 14, 2009 10:57 pm
I recently re-loaded FS9 after having a computer crash. I put all my downloaded aircraft, sounds and panels back in, but when I boot it up with the add on aircraft selected, FS crashes. They function OK if I use a default airplane first, then switch.
The other problem is anytime I change something with the aircraft, be it sound, panel, air file, etc, those changes get kicked out later. I can use them when I make the changes, but sometime later the computer loses them. It has also lost gauges that it previously had.
Any idea what's going on here? Thanks!
aerdingus
RE: Need FS9 Help
Thu Sep 17, 2009 3:56 pm
I don't know, maybe you can try restoration?
Good luck, horrible business altogether re-loading FS9
DashTrash
RE: Need FS9 Help
Fri Sep 18, 2009 2:12 am
I think that might be needed.
Thank you!
Burkhard
RE: Need FS9 Help
Fri Sep 18, 2009 11:10 am
When you make a new installation of FS, you better install all the addons new from scratchm, and start FS after each addon you added. While it may work in other cases, you pile up too many troubles when FS is confronted with more than one addon at a time.
CDreier
RE: Need FS9 Help
Fri Sep 18, 2009 10:52 pm
Agreed! I'm afraid you'll need to do a reinstall of each add-on one by one. Many of the aircraft have files that go into Gauges, Sounds, etc..
[Edited 2009-09-18 15:54:18]
DashTrash
RE: Need FS9 Help
Sat Sep 19, 2009 3:49 am
Thanks guys. I'll start giving it a try tomorrow.
Users browsing this forum: No registered users and 19 guests
