Brendan03
Q: AIRAC's, ILS And Other Changes (FS)
Wed Sep 28, 2011 2:27 pm
Hi all.
I had a thought earlier and I asked a friend who also didn't know but we both thought it was a good question.
With the Real World constantly changing, New Airports and what not, and Flight Simulator being stuck to a static scenery library with very little in the way of updates from Microsoft... I came to wondering.
If an Airport which when FlightSimulator was released, doesn't have an ILS on a certain runway, then later, It's installed and enabled in the real world... Naturally, It's not going to be in Flightsim.
However, If you're using... (We'll use the PMDG 747 as an example) an aircraft and you update the AIRACs for that Aircraft's FMC and you're doing an arrival for that specific runway with the new ILS, Will that AIRAC update enable the ILS on the Aircraft? or do you have to do some sort of update to the Airport on FlightSim side as well?
I'm just curious and I'm wondering if anyone could shed any light on this.
I hope my question isn't worded to confusingly.
Thanks.
Brendan.
Coolier than thou.
Fabo
RE: Q: AIRAC's, ILS And Other Changes (FS)
Wed Sep 28, 2011 9:29 pm
well,
Most sceneries do a good job of rendering these changes, and many developers, freeware or payware, will offer updates throughout the scenery life cycle for significant NAVAID changes.
Enroute is a different animal, not much you can do in there. But as you correctly stated, this is generally upgradeable.
The light at the end of tunnel turned out to be a lighted sing saying NO EXIT
Fly2HMO
Thu Sep 29, 2011 7:44 pm
Quoting Brendan03 (Thread starter):
The ILS is always enabled on the aircraft. The AIRAC is just going to put it into the FMS and make it selectable assuming it wasn't there before. That's it. When you tune the ILS frequency in a scenery that has not been updated with that new ILS you wont get a signal. So, no, you won't be able to use it, though you may select it and it will be displayed on the MFD.
You can use AFCAD to update things like ILSs and navaids at airports but there's no such thing as global navaid updates for the base FS scenery unfortunately.
Fabo
Thu Sep 29, 2011 8:26 pm
Quoting Fly2HMO (Reply 2):
You can use AFCAD
I'd suggest ADE. AFCAD is great and basivally it gave a name to this type of scenery work, nevertheless, it is obsolete nowadays.
Fly2HMO
Thu Sep 29, 2011 8:52 pm
Quoting Fabo (Reply 3):
I'd suggest ADE.
...Which doesn't work with FS9, only FSX
CPH-R
Fri Sep 30, 2011 4:57 am
Quoting Fly2HMO (Reply 4):
It works just fine with FS9. I've been using it over AFCAD for ages now.
http://www.airportdesigneditor.co.uk/ade_003.htm
Brendan03
Fri Sep 30, 2011 5:17 am
That's what I'd figured but I wasn't sure -- It makes sense for it to behave that way. Much like the Real World operations (Given FlightSim behaves entirely differently to the real world in some situations, It's not unusual, but sometimes you do have to wonder about these things)
I just wondered if modern FMC Software (On FlightSim) may have overcome that by picking up/making the ILS work in the Aircraft even if the ILS isn't enabled at the Airport.
The reason I actually wondered this is because I believe YMML/MEL (I could be wrong) recently got an ILS on Runway 34*, which wasn't/isn't there in FlightSim, but I keep my AIRAC's updated so I was just curious if I was doing a flight into Runway 34 at MEL with an ILS Arrival enabled, If it'd automatically pick up the ILS Frequency and display the ILS stuff on the Primary Flight Display.
Given the information I've been presented with here, I now see that's not the case.
*I'm actually not sure if YMML 34 has an ILS, I just saw the ATIS reporting "Expect Instrument Approach" on the ATIS for it recently.
Anyway, Thanks for your help guys. Much Appreciated.
Coolier than thou.
Fabo
Fri Sep 30, 2011 9:00 am
It does - I should know. I designed couple af data packs with it. For one that is built from scratch and was released, look up LYNK Niksic on avsim. 99% done in ADE - 1% is flatten written by hand.
Quoting Brendan03 (Reply 6):
Instrument approach does not mean ILS - could be VOR/NDB (DME), possibly RNAV/GPS approach. I'd expect "Expect ILS approach" if ILS was in use.
Brendan03
Fri Sep 30, 2011 2:27 pm
Quoting Fabo (Reply 7):
My grasp of terminology isn't that fantastic, I only learned what LAHSO is the otherday!
I do believe YMML34 has VORDME, If that means anything.
Coolier than thou.
Fabo
Fri Sep 30, 2011 9:26 pm
Quoting Brendan03 (Reply 8):
That is, indeed, a kind of instrument approach.
Fly2HMO
Fri Sep 30, 2011 9:40 pm
Quoting CPH-R (Reply 5):
I stand duly corrected. I just remembered trying to download it a long time ago when it first came out and it didn't work with FS9 initially, or I'm confusing it with another program.
I have some homework for you:
1 http://www.youtube.com/watch?v=4icjBYwQthM
2 http://www.youtube.com/watch?v=jmikmTy5KkI
3 http://www.youtube.com/watch?v=2pzF1uQ_tuo
4 http://www.youtube.com/watch?v=iMT7DRSyybI
(watch in that order)
You're welcome
[Edited 2011-09-30 14:54:32]
Brendan03
Sat Oct 01, 2011 5:29 am
Quoting Fly2HMO (Reply 10):
You're welcome
I'll have a look later, Had a quick look just now. The guy is cute enough to keep me watching so I'll definitely go through those later.
Thanks.
Coolier than thou.
Users browsing this forum: No registered users and 22 guests
