zachary165
gopro photography/videography for aircraft
Fri Aug 26, 2016 2:20 am
I recently purchased a gopro hero 4 with the intent of using it attached to the side of an aircraft at my flight school (cessna 172). What mounts would be best to attach a gopro to the exterior of the aircraft? I'm debating between a suction cup or a strut mount. Any suggestions?
"Keep true to the dreams of thy youth." - Schiller
steveinbc
Re: gopro photography/videography for aircraft
Fri Aug 26, 2016 4:45 am
I have just used a suction cup on a Turbo Otter float plane. It worked perfectly.
A319 320 321 330 340 380 B707 727 737 747 757 767 777 787 BAe1-11 Trident 1, 2, 3B Viscount Lancaster VC10 HS748, ATP DHC-1, 3 Dash-8 Dash-400 Shorts 330 360 Embraer Banderiante Brasileria 175 190 BAe146 Saab 200 DC-3 -8 -9 -10 MD-11 ATR42-72
airkas1
Fri Aug 26, 2016 7:02 am
I would suggest an adhesive mount when possible. If the flight school allows a GoPro on the outside of the aircraft, perhaps they will allow you to place a semi-permanent adhesive mount as well. Worth a try at least.
zachary165
Fri Aug 26, 2016 12:55 pm
Did you use the mount that gopro makes or a third party mount?
lensupthere
Sat Aug 27, 2016 3:57 am
Would like to hear your feedback on whatever mount you use.
We're working on a new mount - pursuing an STC for a strut mount. We have two other STC's for camera mounts on Cessna/Cirrus.
Here's what it looks like on a strut (172)... The strut clamp is already a PMA'd part. We start flight tests in a week.
seabiscuit
Sun Aug 28, 2016 5:22 pm
Let us know how the test flights go.
Seabiscuit
lensupthere
Tue Aug 30, 2016 3:09 am
I'll keep this forum updated on our progress.
zachary165
Tue Aug 30, 2016 3:03 pm
How much are those mounts going to cost?
lensupthere
Fri Sep 02, 2016 4:42 am
We do not have a price point at the moment due to the FAA's feedback on design changes (received today 9/1/16).
Our goal is to keep it under $500.00 and have our STC cover multiple installations on one aircraft (e.g. one right strut, one left strut).
Feedback appreciated.
CaptainKramer
Sun Sep 04, 2016 1:05 pm
I'm curious about the use of suction mounts with regards to changes in altitude, i.e thinner air and lower temperatures at higher altitudes, can this affect the quality of the seal and it's ability to remain attached to the aircraft.
I would have thought hard mounts would be an absolute must to guarantee the Gopro remains attached to the Aircraft at all speeds, altitudes and environmental changes, without threatening the aircraft superstructure or people on the ground.
Users browsing this forum: No registered users and 35 guests
