Catalin81
Aircraft info.
Sat Sep 16, 2017 5:07 am
I have some picture on the website, but name aircraft appear incomplete, only type model. Im try to edit, but there appear all aircraft data. What is the problem in this case ? This is a picture.Thanks.
https://www.airliners.net/photo/Untitled/NG-5/4521307/L
https://www.airliners.net/photo/Untitled ... /4520439/L
https://www.airliners.net/photo/Aeroclub ... /4410361/L
https://www.airliners.net/photo/Aeroclub ... /4282677/L
airkas1
Head Screener
Re: Aircraft info.
Sat Sep 16, 2017 7:29 am
The problem is that the photographer uploaded the photos with the wrong info. I've corrected all of them now, using the "Correction" button (which anyone can do themselves). Below are what the proper info should've been:
Aircraft Manufacturer Filter Enabled? --> no
Generic Type --> BRM Aero Bristell NG 5
Version --> BRM Aero Bristell NG 5
Generic Type --> IAR IS-29
Version --> IAR IS-29 D2
Generic Type --> Zlin Z-142
Version --> Zlin Z-142
The version should always consist of the manufacturer, generic type and subtype (plus any other designations). If, when uploading, you find out that this is not the case, then select "no" at the aircraft manufacturer filter. You will pretty much guaranteed find the correct entry that way. By putting more care into uploads, it saves us a lot of time correcting incomplete uploads.
Catalin81
Re: Aircraft info.
Sat Sep 16, 2017 7:37 am
Looks like you did not understand. I tried to correct, but when I access all the data is complete. I did not load anything wrong.
airkas1
Head Screener
Re: Aircraft info.
Sat Sep 16, 2017 8:02 am
The autocomplete info is wrong. It happens. That's why everyone should always double check the info and not automatically assume it's correct. If you didn't use the autocomplete function for it, then you made a mistake by listing the info incorrectly. Like I said above:
Catalin81
Re: Aircraft info.
Sat Sep 16, 2017 10:43 am
I did not use the automatic mode, because many picture recently uploaded are for the first time in the database, and have been use manual mode.
Users browsing this forum: No registered users and 4 guests
