jfklganyc wrote:Just curious.
I assume a lot more VFR traffic thru SoCal Approach?
It just seems that there are way more LAX overhead shots on a.net than any other commercial airport.
Thoughts?
jetskipper wrote:LAX has a VFR Cooridor directly over the airport at 2500 feet. If it’s clear, you can fly a GA aircraft north or south over the midfield of the 25s or 26s without a clearance from tower, all you require is a Class Bravo clearance. Any other major airport in the country this would be unfathomable.
Varsity1 wrote:jetskipper wrote:LAX has a VFR Cooridor directly over the airport at 2500 feet. If it’s clear, you can fly a GA aircraft north or south over the midfield of the 25s or 26s without a clearance from tower, all you require is a Class Bravo clearance. Any other major airport in the country this would be unfathomable.
PHX has one as well, though 4000msl I believe.
mast2407 wrote:What really irritate me about these photos is that they’re classed under the “air to air” category.
Correct me if I’m wrong, but that’s “air to ground”. AmIRight.
atcsundevil wrote:Pretty much every Class Bravo airport has one of these. It's called a Class Bravo Transition.
timz wrote:atcsundevil wrote:Pretty much every Class Bravo airport has one of these. It's called a Class Bravo Transition.
Does any other Class B airport show a Transition on the chart, as at LAX and PHX?
cpd wrote:mast2407 wrote:What really irritate me about these photos is that they’re classed under the “air to air” category.
I think you are right, and I've done photos like these from Sydney. I don't classify them as air-to-air. Real air to air is photographing a plane flying in formation with you.
vikkyvik wrote:cpd wrote:mast2407 wrote:What really irritate me about these photos is that they’re classed under the “air to air” category.
Let's not get into that argument. As far as A.net is concerned, Air-to-Air is flying-aircraft-to-flying-aircraft. Doesn't matter whether it's an organized photo shoot in formation or not.
mast2407 wrote:Taking photos of aircraft parked up at TBIT is not air-to-air.
cpd wrote:Real air to air is photographing a plane flying in formation with you.
32andBelow wrote:It’s a super busy airport next to the ocean and the second largest city in America? And it’s always sunny.
dutchspotter1 wrote:Hi Jehan,
What are the helicopter vibrations like? Have you rented a gyro (as mentioned on the Star Helicopters website) and would you recommend it? Or should you use VR/IS or nothing at all?
andrew50 wrote:32andBelow wrote:It’s a super busy airport next to the ocean and the second largest city in America? And it’s always sunny.
Don't ever believe LAX is always sunny! I used to think that until I started going out there about 12 years ago. The marine layer has ruined quite a few of my trips, plus a lot of times when it is sunny the haze is awful. When you do hit the weather right LAX is amazing.
dutchspotter1 wrote:So what time of year do you usually go to LA? I went a few times in November and I've always had great weather, mostly clear blue skies and little (heat)haze.
airkas1 wrote:Never seen photos of PHX overhead either, but MIA and LHR have been done, so why not PHX? Worth a shot I'd say. Does PHX have a VFR corridor running overhead/next to the airport?
