Wordpress
Polarizing Filter?
Fri Oct 05, 2018 3:42 pm
Hello there.
So I've recently started aviation photography. I've bought the Sigma 150-600mm lens and my father is helping me out. He hasn't done aviation photography but he has done armature photography in the past. He insists on using a polarizing filter, but I'm wondering if that's causing more problems then solutions here. My shutter speed doesn't seem so high when comparing my exif data to others'. When I shoot at f/7.1 and an ISO of 200 on a sunny day, I still get 1/300-1/500 of a second, and I'd like to have more margin so I don't get blur. Is the polarizing filter the culprit or are these limitations to my lens?
Thanks again,
Jacob Singer.
ThePointblank
Re: Polarizing Filter?
Sat Oct 06, 2018 8:39 am
Polarizers are meant to cut glare, manage reflections and darken skies to a more deep blue.
They also cut the amount of light getting to your sensor by about 1-2 stops. That can be both a positive and a negative.
I would pay attention to which direction you are shooting into; if you are shooting towards the sun, a polarizer might be more appropriate. Otherwise, you can drop the polarizer.
The other way to compensate is to increase ISO and lower the f/stop.
airkas1
Head Screener
Sat Oct 06, 2018 10:28 am
According to a tutorial I watched recently, a polarizer works best when shooting at a 90 degree angle regarding the sun's position(?). For dynamic subjects, I wouldn't use a polarizer. For static subject, it could make for a different type of photo, but I haven't tried that myself.
But if anything, try a few photos with and a few without and compare the results.
yerbol
Support
Sun Oct 07, 2018 12:33 pm
For the Sigma with this kind of focal length you have to have a very fast shutter speed but polarizing filter cuts the light and shutter speed comes 1/300 - 1/500.
I personally do not use polarizing filters for aviation photography.
With best regards from Almaty
vikkyvik
Mon Oct 08, 2018 3:31 pm
It can work great for landscape and water shots (although, to be fair, I haven't used mine in years).
But for dynamic aviation shots, as previously noted, you'd have to keep adjusting the polarizer as you move/rotate and the angle of light changes. Plus you lose some incident light.
Overall, not really worth it for dynamic photography.
Wordpress
Tue Oct 09, 2018 5:19 pm
Okay, thank you! Thanks to my father he cross threaded it so we'll have to find a way to remove it. But that's something I can do. Thanks for the opinion guys, maybe my photos will start seeing improvement.
A moderator can close the thread now.
ThePointblank
Sun Oct 14, 2018 11:02 am
Get a lens filter wrench; they are pretty cheap, and makes life easier for removing lens filters, including ones that are stuck.
Wordpress
Mon Oct 15, 2018 3:21 pm
Hehe, I sent away for the right wrench two weeks ago. It's shipping all the way from Shenzen though, but it's in the USA now, shouldn't be too long. Thanks though. :)
bombayduck
Wed Oct 17, 2018 7:31 pm
You could also try using shutter priority, where you can set the shutter speed to say 1/800 of a second. Then the camera will set the f-stop. I tend to use shutter priority on a sunny day with iso at either 100 or 200. As to filters either a sky light or a ultra violet will do to help protect the lens glass, it is much easier and cheaper to replace the filter than to replace the lens.
Users browsing this forum: dutchspotter1 and 10 guests
