romeokc10fe
Dust Spots
Tue Jan 08, 2019 2:04 am
Hello all, what is your workflow for spotting and removing dust spots in Photoshop CC 2019?
Kaphias
Re: Dust Spots
Tue Jan 08, 2019 4:20 am
Duplicate the layer your photo is on, equalize the top layer, select the bottom (original) layer, use heal/clone on the spots.
romeokc10fe
Re: Dust Spots
Tue Jan 08, 2019 8:49 pm
Thanks for the reply!
cpd
Re: Dust Spots
Sat Jan 12, 2019 7:28 am
You can also do this in Camera Raw to remove the dust spots, it has a tool to remove the dust spots.
Pan the image around and the dust spots will be more visible. You can also increase the black setting to 100, this will make them very obvious.
B747Saeed
Re: Dust Spots
Sun Apr 07, 2019 4:38 pm
Use Lightroom.
vikkyvik
Re: Dust Spots
Mon Apr 08, 2019 2:23 pm
Ditto, except I pretty much exclusively use Spot Healing tool. Hardly ever use Clone Stamp anymore.
I also tend to select just the sky before equalizing. That's the area where I'm generally concerned about dust spots, and selecting just the sky makes them stand out even more.
jelpee
Screener
Re: Dust Spots
Tue Apr 23, 2019 5:00 pm
Also, clean your sensor :)
Jehan
flee
Re: Dust Spots
Wed Apr 24, 2019 1:57 pm
Jehan
Sometimes small birds appear to be like spots. Cleaning the sensor won't help there!
jelpee
Screener
Re: Dust Spots
Wed Apr 24, 2019 5:15 pm
flee wrote:
Jehan
I agree that small birds and other items in the actual outside environment require some post processing. However, the OP specifically refers to dust spots which are small/mid size fuzzy looking and hazy spots. My suggestion was meant to solve that problem at the source vs. treating the symptoms.
