seahawk
Re: Have quality standards changed on here recently?
Thu May 14, 2020 6:55 pm
I see no problem with the quality. They are superb shots.
cpd
Thu May 14, 2020 8:44 pm
PanAm_DC10 wrote:
by members who do not actively upload or in the case of CPD deleted all his images years ago and only posts what is perceived to be popular opinion. More posts than any uploads
Thank you
Are you suggesting I should upload images?
Given the image criteria is obviously changed permanently I won’t say anything further.
StarGrid
Fri May 15, 2020 3:32 am
Front on view with only one side of the plane?
dutchspotter1
Sun May 31, 2020 12:23 pm
Curious why this one wasn't rejected for dirt spots (not only birds): https://www.airliners.net/photo/The-Car ... SF/6027465
NO URLS in signature
JakTrax
Sun May 31, 2020 8:25 pm
Hi dutchspotter1, the rules (used to at least) state that birds in the frame are acceptable if they are easily identifiable as birds (which in this case they are). I would have removed them personally as they are a bit distracting but it's not an issue per the acceptance criteria.
dutchspotter1
Sun May 31, 2020 9:13 pm
Thanks, but there are also dirt spots that are clearly not birds, e.g. in the upper right corner and just above the first lightpole on the right side of the red-white pole.
dutchspotter1
Sun May 31, 2020 9:14 pm
JakTrax
Mon Jun 01, 2020 12:26 am
Yes, I see them now. Sorry, I thought you were referring exclusively to those specks that are obviously birds.
The one above the lightpole is likely a bird but since it can't really be identified as such it should have been scrubbed. The one top-right is either an insect or dust spot on the sensor and should certainly have been addressed.
Runway28L
Sun Jun 14, 2020 10:13 pm
I am not one to really vent about rejections and I try my best to remain reserved as I know it can be hard. But lately, it feels like consistency has gone totally out the window.
For the past two months, I had a high acceptance rate and any rejection I had was understandable as it was usually a minor mistake(s) on my part. But lately, nearly everything I have submitted has been rejected and in my honest opinion, some of them have been flat out ridiculous. National Cargo B744s, for example, are very rare type for KPIT. Yet both images I submitted were rejected partly for "Common". I understand if it is a popular upload, but come on. If it is rare for a certain airport, shouldn't that at least be a consideration? I'll add too that both had additional rejection reasons of which I didn't have much of an issue with.
And then there's this image. Rejected for Blurry/OS. Appealed and upheld.
https://imgproc.airliners.net/photos/ai ... 2ab93b2969
Yet here is the image at full size. I don't see any blur here. :roll:
https://i.imgur.com/6jTpigO.jpg
The Blurry/OS and "not suitable at this size" rejections have gone way up for no visible reason. If I had an image that was blurry at full size, I would never bother to try uploading it. However, it just seems hard to please anyone when I have to go from full size to 1600px wide and I'm basically told to give up on the image when I know there's little or nothing wrong with it. Especially when I have not changed my work flow, equipment or camera settings at all and Blurry/OS rejections were basically nonexistent a few weeks ago.
Anyway, I don't mean to be a whiner. It's just been frustrating to upload here lately. It's also not like I have much time anymore to go back and constantly re-edit images, mainly due to work and personal reasons.
clickhappy
Mon Jun 15, 2020 12:12 am
Common doesn’t mean that an image won’t be accepted, it just means that the subject is well-documented and that only the highest quality shots will make it.
To me the UPS seems blurry around the reg number - possibly from the exhaust but it is noticeable.
jelpee
Head Screener
Mon Jun 15, 2020 12:13 pm
Hi Evan,
I did the initial screening of your UPS MD-11 and unfortunately could not see accepting it as uploaded. The nose area, including the main title is oversharpened. Based on the overall appearance, it looks characteristic of too much sharpening applied to compensate for blur. While a soft image can be improved with sharpening, blurry images cannot. Also the UPS logo on the tail shows blur. Unfortunately, your image at 1600 pixels showed issues. It was upheld by another head screener on appeal. While you have described the rejections as "ridiculous" in your post, I'd say it was more an example of quality standards being kept high, which is indeed the Question raised in the title of this thread.
As for "Common", images are not rejected for that reason alone. As Royal mentioned, it means it is a common registration in the DB, and those images are held to the highest of standards. The threshold for "Common" is >100. It might be good if you plan to upload a "Common" registration, to ensure that there are no visible flaws.
Jehan
dutchspotter1
Mon Jun 15, 2020 2:09 pm
I'm sorry but I really don't see any blur here (at the rejected image). I do agree that the rejected image is oversharped and that the tail area on the original image looks blurry, but I'm curious how you're able to tell that the UPS logo on the rejected image is blurry. Sometimes I also get the feeling that screeners are seeing things that aren't there, so I get Runway28L's sentiment.
Furthermore I find the tree parts quite distracting, so when talking about upholding the high quality standard, why not consider such things as well?
JakTrax
Mon Jun 15, 2020 2:23 pm
The original file isn't blurry but the tail does look softer than the rest of the aircraft. Generally it looks excessively sharp to me for an original file and I suspect resizing to 1600 pixels is, without any additional sharpening, going to render it oversharp by default.
jelpee
Head Screener
Mon Jun 15, 2020 3:41 pm
Somehow how I sense the expectation that the screening process needs to be perfect, each time, all the time. That is not realistic. As humans, we see, and perceive images differently as exemplified by the comments on this very post. Candidly speaking, if you know of a site similar to this where the screening process is perfect or pretty darn close to it, let me know since I would like to start contributing there myself!
Jehan
Moose135
Mon Jun 15, 2020 4:04 pm
It doesn't need to be "perfect, each time, all the time". It needs to be consistent. I stopped uploading to this site because I got tired of inconsistent screening. Looking at this latest example, I guess I won't be uploading any time soon, because the UPS shot looks good to me, and I would have uploaded it if it were mine. Apparently, I don't know what makes an acceptable A.net photo.
jelpee
Head Screener
Mon Jun 15, 2020 4:23 pm
Moose,
Even to be consistent is unrealistic, IMO unless we adopt robo-screening. As humans there will be variability...that's what defines us as humans. So let me rephrase: If you know of aviation photography site where the screening process has better consistency compared to a.net, do please share.
Jehan
JakTrax
Mon Jun 15, 2020 4:31 pm
I don't think anyone expects perfection — or even 100% consistency — but let me give an example:
https://www.airliners.net/photo/China-E ... nEum5K5DCG
https://www.airliners.net/photo/Southwe ... nEum5K5DCG
The disparity isn't 'just a bit' — it's enormous! Then we see rejections for the same aircraft type (or similar) where the subject in the frame is actually somewhere between those two. And the rejections are upheld on appeal.
The above is not an isolated incident. You only need search the first few pages of 737-600/700s and you'll see that centring is all over the place.
Runway28L
Mon Jun 15, 2020 5:44 pm
Jehan, I really appreciate you chiming in with your view. However, I just have to disagree with the shot being blurry. Looking at the original TIF file (had to share it as a JPEG since Imgur apparently doesn't let you upload whatever size you want anymore), I see no evidence of that. I even made that clear in my appeal, but unfortunately the head screener still didn't see it that way. That's also what bothers me a lot: there is just no way to make a strong case for what I am seeing on my computer screen. I always just have to run on luck and hope that the HS has a different opinion, which is at best a 50/50 chance.
Just want to make it clear that it is nothing against you at all and I don't mean to rub you the wrong way if I have. I'm just frustrated at the entire process as of late and things going one way when I think it should have gone the other way. Also, I agree with you and some of the other posters that the human factor makes perfect screening impossible. But I do think there needs to be a more consistent way to decide on what is acceptable and what isn't. That also goes for the extreme level of nitpicking that I sometimes see.
dutchspotter1
Mon Jun 15, 2020 5:54 pm
Well, if you replace the words "screening process" by the words "photo editing process" , you will get a sense of the photographers' POV ;).
Anyway, in my opinion screening should start with the basics and consistently pick out the obvious/unambiguous flaws. If that is not under control, there will always be confusion and frustration among photographers.
Without consistent (which is not the same as strict) screening, photographers will not be able to properly adjust their workflow and improve their photo quality and thus the quality standards of this website.
Obviously perfection is not possible, but photographers and screeners can at least strive for it by helping each other and giving each other feedback. A.net is obviously the best starting point as the other well-known (aviation) photo websites (and social media) are a lot farther away from perfection.
jelpee
Head Screener
Mon Jun 15, 2020 6:04 pm
Evan,
We can agree to disagree on the blurriness. But the image remains over-sharpened and that itself was a significant issue to warrant a rejection. Regardless of the condition of the original file, we screeners screen based on the final version that is uploaded. Combine that with variations in monitor that screeners use (airliners.net does not provide us all with standard monitors) and variations in visual perceptions, there is likely to be differences in opinions and judgment. If you are running into a streak of rejections, may be worthwhile to reconfirm if something has not changed in your camera settings or your editing settings/workflow. If 2 head screeners (myself and the appeal screener) saw the same thing, it may be worthwhile giving it some credence.
No offense taken on my part--I am open to different points of view; we all get better by listening to feedback.
Jehan
JakTrax
Fri Jun 19, 2020 2:41 pm
Another HKT shot with some serious banding now TOTD. I thought this issue had been 'addressed with the photographer'?
Moose135
Fri Jun 19, 2020 5:56 pm
The banding was the least objectionable thing about that shot, but the staff apparently like them, so here we are.
vikkyvik
Fri Jun 19, 2020 6:27 pm
The first thing I noticed was how distant it was. You could crop away nearly half the photo, and end up with something much more pleasing (in the process, removing the photgrapher's annoying shadow).
Smoketrails
Fri Jun 19, 2020 9:45 pm
It is a rubbish shot and I am starting to get frustrated in why these pictures are being accepted and even placed as significant. I do not know the photographer personally but it seems he has a large influence on the screeners at A.net!
