ThatOneFish
Any way to avoid heat haze at LAX?
Mon Aug 12, 2019 1:00 am
Hello,
I went to Imperial Hill yesterday for some shots, after taking a few months break. It was completely sunny, but temps were around 70-72 F.
All my shots had heat haze, and I compared them to my shots from Feb/Nov, which were taken at Imperial, and they had no heat haze at all (about same temp)
Does time play a factor? Yesterday I went around 12-3, and in Feb/Nov I was there from 3-5.
Thanks.
vikkyvik
Re: Any way to avoid heat haze at LAX?
Mon Aug 12, 2019 3:00 pm
Absolutely. 12-3 is a horrible time to shoot at Imperial Hill, especially during the summer.
3-5 is a great time to shoot during February or November. Won't be good during the summer though - best to wait until after 5.
JakTrax
Mon Aug 12, 2019 9:53 pm
I've never been (to the spot) but I've seen how distant it is. Outside of late-afternoon mid-winter I doubt you'll ever see no haze — you just can't shoot across that kind of distance and expect perfectly clear, undisturbed air. Live with it or choose a spot closer to the action.
JKPhotos
Screener
Thu Aug 15, 2019 12:07 pm
I would generally not recommend to shoot from 1-3 in summer, even if you could avoid heat haze by choosing some closer spots (if possible), but light is as ugly as it can get that with sun being ultra-high.
As Karl said, the only way to avoid heat haze on distant spots is a clear winterday, otherwise forget it (in terms of quality results).
I have access to a rather distant spot here in Frankfurt that I can only use in December in January as otherwise it will be more or less heat hazed, even starting february.
vikkyvik
Thu Aug 15, 2019 1:22 pm
For Imperial Hill, times I would go are:
Summer: before 9:30 AM and after 4:30 PM
Winter: before 11 AM and after 2:30 PM
Sometimes in the winter you can shoot in the middle of the day with not-too-bad haze. But don't count on it.
