DanielK
High ISO Night Panning Editing
Tue Sep 24, 2019 11:58 pm
Hi Airliners.net community,
Recently I have gone out at night to get some night action panning shots. I would love if photographers who are experienced in this area can give me some general tips and a workflow to how to get these shots up to Airliners.net standard.
Daniel
vikkyvik
Re: High ISO Night Panning Editing
Wed Sep 25, 2019 2:37 pm
Hopefully you shot RAW.
Depending on how high the ISO is, I have various presets for RAW noise reduction. At ISOs up around 6400 and higher, this can be pretty significant.
Some pretty good advice in this thread. I posted some of my presets in Reply 12:
viewtopic.php?f=8&t=934497
Ultimately, it's going to take some practice in the editing.
cpd
Sun Sep 29, 2019 8:34 pm
It’s less about workflow and more about technique with the camera and having a good camera and lens combination. :old:
Lenses like the Nikon 70-200mm F/2.8 with an excellent VR system really help with the panning at very slow shutter speeds, while the F2.8 aperture lets you get away with a lower ISO (say 1600).
It’s the lower ISO and resulting less noisy image that helps a lot. Getting the exposure right is also important, and I always set the shutter, aperture and ISO manually. All of that makes editing easier and less about very special noise reduction techniques.
Rest is just steady hands and practice.
I first started doing this stuff when I got hold of a D3S Nikon all those years ago, but I remember Florian Trojer was doing these kinds of shots even long before that. (Some of you youngsters won’t know who he is). I would love to try it again with these modern cameras that are even more capable.
DanielK
Sun Sep 29, 2019 11:50 pm
I shot this image with my Nikon D7200 which is paired with the Sigma 70-200 f2.8 . The combo is very good and managed to snap this last Saturday night. https://imgur.com/TqCXKsz . Some areas are sharp while others aren’t, I’d love to get it on the database here.
vikkyvik
Mon Sep 30, 2019 1:56 pm
Probably not going to happen - the tail area is pretty blurry. That can easily happen at low shutter speeds - one end of the aircraft can be tack sharp, and the other end is a blurry mess.
Have to find a balance - get the middle of the fuse to be sharp, and the ends probably won't be too blurry (there will almost always be some blur at low shutter speeds, it just depends on how noticeable it is). I take a lot of shots of any given aircraft - most of them will be throwaways, but there may be a couple good ones in there.
It can be. But some people aren't going to be able to shoot at 1/4 or 1/8 second and get good results - my hands generally aren't steady enough for that. And my wallet isn't steady enough for good F2.8 telephoto lenses. So I'm left shooting at high ISOs. And with those shots, editing is quite important if you're interested in getting shots on A.net.
cpd
Wed Oct 02, 2019 7:45 pm
That light is good, the plane is very clear, but the angle is tricky with slow shutter speeds and big aperture settings, resulting in areas that are sharp and others that aren’t. Directly side on shots are easier. You will get shots where bits are blurry, that’s how it is, especially if using 1/4 or 1/2sec shutter speeds.
DanielK
Sat Dec 21, 2019 1:02 am
Hi all, shot this with my new D750 at 1/100, F2.8, ISO 6400.
First time editing this sort of thing so would love to know if there's anything that I am able to fix.
https://imgur.com/BSagnmz
Thanks.
Daniel
cpd
Tue Dec 24, 2019 8:55 am
Thanks.
Daniel
I tried copying your large size image into photoshop but even putting it down to 1280 pixels wide, it was a bit too difficult to make it work. It still looked not sharp, and the noise was still there, and the light is very tricky.
I've tried those myself and haven't had good results. Something similar I did in 2012 (and this is without any special editing):
That was on my old D3S with a 24-70mm F/2.8 Zoom Nikkor, ISO20,000 at with F/2.8, lens was at 60mm, shutter was 1/30sec. It's just really hard to get nice light under those conditions. I only tried to get that photo because it was the first photo of VH-OEJ in its normal Qantas corporate colours.
Just keep trying and eventually you'll knock off a shot that really works. Look for conditions where there is some strong light on the ground that will illuminate the plane better, that will give much nicer looking photos.
DanielK
Tue Dec 24, 2019 12:26 pm
Thanks.
Daniel
I'll make sure to keep practicing. The spot has fairly bright lighting on the ground. Probably just bad settings tbh. I think I'll need to find the right balance between ISO and shutter. The D750 should be able to deal with noise well, so I'll o out and give it another crack
DanielK
Tue Dec 24, 2019 12:29 pm
Once I understand how much noise is too much for Anet, then it should make it all much easier
vikkyvik
Tue Dec 24, 2019 3:15 pm
It takes practice, and developing an eye for it.
Your shot looks a bit too blurry (especially toward the nose). Also looks like there's a lot of compression in addition to noise. Not sure if the compression is from Imgur or if it's in the original image.
DanielK
Mon Jun 15, 2020 12:46 am
Hi All, I've gone out and attempted some more night shooting. Could anyone provide assistance on the noise reduction and sharpening stage.
This is the original image: https://bit.ly/2UGJoRe
And this is the edited one: https://bit.ly/3hrcyNV
All help is much appreciated!
Kind regards,
Daniel
cpd
Mon Jun 15, 2020 1:07 pm
Kind regards,
Daniel
This opinion might be controversial, but I like the original image more than the edited one.
The original has noise yes, but it looks more natural to my eyes, while the other has a heavily noise reduced look.
The image does look pretty sharp on my iPhone XR.
