Page 1 of 1
New camera decision - would like some feedback on what others have.
Posted: Tue Dec 10, 2019 3:25 pm
by cjmoeser
Hi all,
My Pentax K3 crapped out on me a few months ago, and the contractor Richo uses wanted about $1,000to fix a $600 camera. Unfortunately, not worth it. I've decided it is time to upgrade my setup to either the Cannon 5D mk. IV with the Cannon 100-400 II, or the Nikon D850 with the Nikon 80-400.
The question I ask you all that use the same equipment is just the general experience from either company what the strengths and weekeness are with either or.
With the ammount of money I will be spending, I want to make sure I make the right decision on what's best for me. Outside of aviation I do sports, other fast moving stuff and urban night. Not so much portrait in that sense.
Thank you all for the help in advance,
Colin
Re: New camera decision - would like some feedback on what others have.
Posted: Tue Dec 10, 2019 4:49 pm
by Bostrom
For sports and aviation, are you sure you need a full frame camera? An APS-C sensor can be useful in those cases (although it depends on your local airport and what sports you shoot).
Posted: Tue Dec 10, 2019 6:48 pm
by jelpee
Either the Canon or Nikon set up you referenced should more than amply meet your needs. If you go the Nikon route, while the 80-400 is an excellent piece of glass, take a look at the 100-500 mm f5.6. For the money, it is an outstanding lens. I use it for most of my aviation photography.
You can't go wrong with either of the set ups that you mentioned.
Jehan
Posted: Tue Dec 10, 2019 7:39 pm
by airkas1
Hi Colin,
I use the 5D4 with 100-400 mk1. Especially love the camera quality and high ISO performance. I would think that with the Mk2 lens, the output quality is even better.
I'm unfamiliar with Nikon to comment on that.
Posted: Tue Dec 10, 2019 9:55 pm
by Miguel1982
Adding to Kas's response, the mk2 version of the 100-400 is noticeably sharper, mostly so on long focal lengths (300 to 400mm) and wide(r) apertures. It works very very nicely with the 5DIV.
Question - just to add fuel to the fire - have you considered going mirrorless? Either with the EOS R or with one of the Nikon Z series.
Posted: Wed Dec 11, 2019 7:14 am
by ReneWendt
Agree with Jehan regarding the Nikon setup, the 200-500 is a very good one for the price. I use it for aviation and wildlife. For me its a D500 instead of the D850, so I can not comment on the D850.
Regarding the mirrorless road: I do own a Z7 and you can buy it with a good discount from me. When using the 24-70 mm kitl lens it is great, but auto focus when using the 200-500 is not very good, too many pics which are slightly out of focus. It has 47 megapixel and gather noise like crazy for me when used in a cloudy weather, even on ISO 100-400 it is very grainy/noisy. I can not recommend this camera at all. However, this could change if Nikon produces a 200mm Z-mount lens.
Posted: Wed Dec 11, 2019 2:47 pm
by 310815
I would go with the 5D MKIV and the 100-400L II. It is a very sharp and fast combo. I do sports, too and it is very suited for that. I shot at an nordic ski event earlier this year and was really satisfied with the results, somehow on my sports shots I feel the fullframe upgrade more than on aviation shots.
Honestly Nikon is surely as fine as it gets, too I just don't have any experience with them. And at least on sports eventy here I see far more canon shooters, though reason for that could be various.
Posted: Wed Dec 11, 2019 6:51 pm
by JakTrax
If you're doing a lot of fast-action photography I hand on heart can't really recommend a mirrorless, at least with my experience of the Canon EOS RP. It's a fantastic camera and has many advantages over a DSLR but the split-second freeze-frame between shots will likely be too distracting for sports or airshows. I've not gotten around to attempting to limit its effects but I'm assured that you can never completely eliminate it. This is the same for the EOS R and, I imagine, Nikon's Z range; I believe only the highest tier Sony cameras (A9, maybe A7III?) negate the issue. To be fair you do get used to it and you can successfully work around it but ultimately it's better to use the right tool for the job (which is a DSLR).
One thing I've learned with the jump to mirrorless is that they complement DSLRs, rather than replace them like-for-like. My RP has way better AF than any DSLR I've ever owned and it produces generally superior images, but that doesn't render my DSLR collection useless by any stretch. If you do go mirrorless there are only really two options at the moment: Canon and Sony. The new 1.4 firmware update for the Canons pulls them from last place and puts them firmly into 2nd (probably 1st if you account for the already impressive range of quality RF glass), with Nikon (as pointed out above), Fuji and Panasonic left way behind in the AF department.
Mirrorless may have come a long way but there are (for the foreseeable future) tasks for which a DSLR is still the go-to option. I shan't be offloading my DSLRs any time soon...
Posted: Fri Dec 13, 2019 3:37 pm
by clickhappy
Given the difference in price, and the huge jump is resolution (and file size) I would buy a D750 over a D850. Spend the rest on good glass. XQD cards are also expensive and difficult to find for sale, in a pinch. The 5D mk IV is D750 performance at D850 prices :thumbsdown:
Posted: Sat Dec 14, 2019 11:43 am
by McG1967
Does anyone you know shoot with the D850 or 5DIV, that could let you have a try to see how you find either system before committing cash to buying one or the other?
If not, your sort or stuck with trying out in a local camera store or a Best Buys.
Posted: Sun Dec 22, 2019 12:25 pm
by seahawk
That depends on your needs, the AF module of the D850 runs circles around the D750, if you need it. (for small birds it is in a different league, for airliners, not so much) It is also a big difference in resolution, which can be a negative (large files) or a positive still plenty of resolution even in APS-C mode.
Posted: Mon Jan 06, 2020 6:25 am
by cjmoeser
Hi all,
Sorry it took me longer to you all. I appreciate all the feedback on either bodies and what not. I'm close to making a decision soon, I will need the new body here soon for some sports gigs I'll be doing.
Colin
Posted: Wed Jan 08, 2020 11:16 pm
by planespot
I'm a bit late, but as someone who used both the 1D Mark IV and 5D Mark IV, with the 70-200 2.8 IS II and 100-400 IS II, and just switched over to the Nikon D500 and D850, with the 70-200 2.8 FL VR and 200-500, I have some unique perspective. I don't have the Nikon 80-400, but I've watched enough videos and looked at enough reviews, posts, and samples to conclude that the 80-400 isn't as sharp as the Canon 100-400 IS II. The Canon was tack sharp at 400mm (the V1 not so much). It has a closer focusing distance, is metal vs. plastic, and is still cheaper. The strange thing is Nikon's 200-500 seems to be sharper than their 80-400, if you can get a good copy. I say strange, because it's value priced (got mine new for $1200). Of course, it's slower to focus than the 80-400, very heavy, requires a lot of turning to zoom through the full range, and you miss 100mm at the wide end. Based on your needs, I'd probably lean toward the Canon setup, mostly due to the advantage of the 100-400 II over the Nikon 80-400. I'm really hoping Nikon comes out with an improved version of the 80-400 (or a 100-400), but they tend to release new lenses a lot slower than Canon.
Posted: Mon Jan 20, 2020 4:54 pm
by NIKV69
Jehan
I have the Z6 and D500. I just got the 200-500 5.6 in good light it behaves nice actually.
Posted: Mon Jan 20, 2020 6:59 pm
by cpd
airkas1 wrote:
Hi Colin,
I think both options would be good. Nikon is what I’m experienced with (long term NPS member).
For me having used both brands I find the Nikon cameras easier to use, excluding the lower end ones where all the features you might want to adjust are buried deep in menus.
For the purposes of this kind of photography here, the longer range lens will be better. Though I’ve survived for a long time with a 200-400 F/4.0 on FX cameras. Some distant photos weren’t possible with that combination unless I used a TC 1.4x.
For sports, go for the camera with the best autofocus and low light ISO performance.
Posted: Wed Jan 22, 2020 1:23 am
by Starfuryt
Nikon route is a bit of a rock and a hard place situation right now. Personally I used D750 with 70-200 f/2.8 or 200-500 f/5.6
With the imminent release of the D780 the D750 has dropped in price significantly and is still a great camera.
However the new Z mount lenses are simply better so there might be some logic in waiting for a 2nd gen mirrorless platform, which is likely what I'm going to do.
-Mikhail
Posted: Wed Jan 22, 2020 1:42 am
by JakTrax
I think the advice re mirrorless in the last post is sound. Mirrorless lenses are inherently better due to the reduced flange distance but, in the case of Nikon and Canon (particularly), the camera bodies are at the moment way behind the lenses. Nikon are kinda stuck in last place with the Z mount due to lousy AF (something Canon fixed in an October firmware update) and poor lens selection. Definitely worth waiting to see what develops as I'm sure Nikon will eventually iron out any issues and gain more confidence in its mirrorless system. That said, I think Canon has definitely taken a lead over it's old rival and will go all out on its RF mount to hunt down Sony.
Posted: Wed Feb 05, 2020 2:58 am
by cjmoeser
Hi all,
Sorry to resurrect this post from grave, but I thought I would inform everyone on my decision. Today, I pulled the trigger on the 5D Mk. IV. I think as an all-arounder it'll be better in the long run. It'll be a month and a half before I'll be able to do spotting with it, as I'll need to wait after I do some events to get the money for the 100-400 II.
Thank you all for your feedback, I took it very seriously and considered everyones responce!
Colin
Posted: Sat Feb 08, 2020 10:23 am
by ThePointblank
I would hold onto your receipt for now, because Canon is expected to make a major camera announcement in the coming weeks related to the launch of two new mirrorless cameras.
One of the rumours going around is a new EOS R5, which would be a 5D Mark IV replacement camera, and would have about 45MP, IBIS, and would be capable of shooting 12fps. The other is a rumoured EOS R6, which would have about 20MP, IBIS, and would be capable of shooting 12fps.
It should get interesting in the coming weeks from Canon based upon what is being said about these two cameras.
