FLALEFTY wrote:Here is the FAA's special G/A flight requirements for LA Basin airports during the Super Bowl week:
https://www.faa.gov/newsroom/super-bowl ... -ga-pilots
This part is interesting:
"A reservation program to facilitate aircraft parking at the following Los Angeles-area airports will be in effect from Feb. 6 through Feb. 14. Pilots should contact the Fixed Base Operator (FBO) at their airport to obtain reservations and additional information.
Los Angeles International Airport (LAX)
Van Nuys Airport (VNY)
Hollywood Burbank Airport (BUR)
Long Beach Airport (LGB)
Jack Northrup Field / Hawthorne Municipal Airport (HHR)
John Wayne Airport (SNA)
Ontario International Airport (ONT)
San Bernardino International Airport (SBD)"
And here's the link to the FAA's Safety Plan for Super Bowl LVI:
https://www.faa.gov/superbowl
FlyingElvii wrote:Going off of the experience of working a couple of Super Bowls in the past, I think Long Beach is going to be ground zero for the private jet invasion. It is the only place close by that has enough ramp space for the heavy jets, and they can easily close a couple of runways for parking. The visitors will head downtown for the parties, while the pilots stay at the cheaper places around LGB.
Signature and Atlantic at LAX don’t have a lot of ramp, and you can bet the parking fees are going to be OUT OF THIS WORLD… Even a Quick drop is likely in the thousands of dollars. Same for Burbank.
If you want to see the celebs arriving, my suggestion would be to hang out at Hawthorne Jet Center, it is probably going to be “Citation Central”. I imagine that both HHR and LGB will be really busy.
