tpk
Vignetting Problem
Fri Sep 29, 2000 5:42 am
I have been photographing aircraft for about 12 years. Up until 4 months ago, I was using an old manual focus Canon AE-1. Recently, I purchased an EOS with a new autofocus zoom lens and circular polarizer. I have been experiencing a lot of problems with vignetting that have ruined otherwise perfect shots. The thing that confuses me is I can have two shots in sequence (same subject and light conditions) and one will have it while the other doesn't. I suspect that it has something to do with the polarizer, but I am not sure. Because of the pale sky that often occurs without the polarizer, I am not ready to give up using it if I don't have to. If anyone has any suggestions, I would appreciate the help.
I use a 80-300mm zoom lens, a circular polarizer, and Kodachrome 64 slide film.
Thanks.
rindt
RE: Vignetting Problem
Fri Sep 29, 2000 8:50 am
I've got a solution for you! Come up here to Canada, and experience blue skies, without having the need for a polarizer to make the sky blue.
I used a cheap $250US 28-300mm lense, and quite often I'd get the vignetting, which only seemed to appear on the right hand side of the slide... since then I have purchased a $1500US lense, and the vignetting is completely gone. Now, I'm not saying you need to buy the best lense, I'm just saying that the reason why I had vignetting on otherwise perfect shots is because of the lense, not the polarizer, camera, etc. It's only too bad I didn't have my new lense many moons ago.
However, while I had the cheap lense, I learned to adapt to it's level. While the lense was always slow (F4/5.6), I could usually manage to get little or no vignetting when I used F5.6 or F8, albeit I'd be shooting at slower speeds, so for me it was a constant uphill battle. Even if I managed to get a perfectly exposed shot, full-framed, etc, the edges were always a little blurry. My advice to you is save up for the better equipment, and you won't look back, I can reassure you of that.
Here is one of my worst shots, almost ruined by vignetting and lack of sharpness altogether.
Click for large version
Photo © Rob Rindt
A shot with the new lense :
Photo © Rob Rindt
Hope this helps in some way.
Rob
What other people think of you is none of your business!
ckw
Fri Sep 29, 2000 4:55 pm
Does vignetting occur at all focal lengths? Are you using a lens hood?
Colin
Colin K. Work, Pixstel
tpk
Sat Sep 30, 2000 2:44 am
I apprecicate your help, Rob. I will give your suggestion a a try while saving up for a better lens.
Take care.
Tim
PrinceAir
Sat Sep 30, 2000 5:32 am
Tpk: Don't run out and buy a $1500 lens just yet!! I have a similar Canon USM lens (not using a polariser though) and I haven't had a problem...
tpk
Sat Sep 30, 2000 10:29 am
No, I am not using a lens hood or anything additional. The thing that I find unusual is that when I had the AE-1, the lens I had was not a particularly good one. I had assumed that the Canon lens that I bought for it would be at least as good.
