kaddyuk
Rejection Critique...
Fri Feb 27, 2004 9:30 pm
I had this photo rejected for having part of the aircraft cut off...
Does this make the photo rejectable? somtimes it good to close up on parts of the aircraft. for instance the nose..
I am putting this photo up for constructive critique to try and help me see it from other peoples point of view...
https://airliners.net/procphotos/rejphoto.main?filename=A6EMT_LHR_27R_773_140204E_efgdfgdfgs.jpg
RE: Rejection Critique...
Fri Feb 27, 2004 9:46 pm
Well... the aircraft is cut off  Laugh out loud
No, seriousely! I think you should crop it tighter. Crop it after the Emirates titles - then It's really close up.
regards, Florian
IL76
Fri Feb 27, 2004 10:31 pm
Personally, I'm not too crazy about these kind of shots...
But technically I think it's a bit soft/unsharp around the nose (the Boeing 777-300 titles) and if you do want a close up of the nose section, make it closer with less sky above and below. Now it's just a stick in the sky.
E
[Edited 2004-02-27 14:31:46]
JeffM
Fri Feb 27, 2004 11:32 pm
It's not a flattering crop, and there is considerable grain as well.
kaddyuk
Sat Feb 28, 2004 1:43 am
Thanx for the advice....
I will see if that is possible with my original picture...
Granite
Sat Feb 28, 2004 1:48 am
Kevin
Tighter crop would be better.
Gary Watt
Woody001
Sat Feb 28, 2004 2:09 am
Be careful if you try a tighter crop, you already have quite a high level of noise in that shot, I can see a 'Bad Scan' rejection looming.
There are also 34 shots of this aircraft in the database, maybe if it wasn't such a photographed aircraft then it would stand a better chance....?  Smile/happy/getting dizzy
A similar photo exists;
Photo © Stephen Fox
Well done 'Agent Fox...'
Ian.
[Edited 2004-02-27 18:15:16]
If I could just get the afterburner working...
707CMF
Sat Feb 28, 2004 2:14 am
I'd say also try to center it vertically. The aircraft is quite low in the shot.
Users browsing this forum: dutchspotter1, gh6912 and 6 guests
