boeingfreak
Seems I Can't Get The Centering Right...
Thu Feb 14, 2008 7:08 pm
Hi all,
I just had the following photo rejected for uncenentered:
https://www.airliners.net/addphotos/rejections/big/20080214_3B-NAV_landing_FLO_anet.jpg
Problem is: I can't see what's wrong with it... (I'm thinking about appealing but I didn't want to waste the headscreeners time with an obviously uncentered picture)
Your opinions are greatly appreciated!
Florian  wave
dvincent
RE: Seems I Can't Get The Centering Right...
Thu Feb 14, 2008 7:14 pm
Florian,
Move it up in the frame about... oh, little under half an inch (or about 1.5cm). Just looks a bit low in the frame. At least, that's how I see it.  Wink
From the Mind of Minolta
boeingfreak
Thu Feb 14, 2008 9:23 pm
Hello Dan,
thanks for your post, but it made me even more confused...  Smile
I've just submitted the appeal, let's see what happens.
Florian
KLM772ER
Thu Feb 14, 2008 9:30 pm
Quoting Boeingfreak (Reply 2):
Sorry for joining in a little late, but thats what I would have suggested to you  Wink
The centering looks ok to me!
Nice shot as always Florian!
Björn
dvincent
Thu Feb 14, 2008 9:40 pm
Hello Dan,
I just meant that, to me, it looked like the plane could be moved up in the frame slightly, by like half an inch or so.
raoulr
Thu Feb 14, 2008 9:50 pm
Hi Florian,
I'm no expert, but I'll give it a try.
All though the picture is centered correctly, if you take quick glance, it looks like the aircraft is a bit low in the frame.
I think this misleading view is caused by the trees in the bottom part of the picture. More sky above the aircraft then below.
Raoul
ptrjong
Thu Feb 14, 2008 11:21 pm
Yes, I agree the aircraft is a bit too low in the frame.
Peter Smile
eadster
Fri Feb 15, 2008 2:44 am
Looks a tad oversharpened too. Few jaggies showing here and there.
cpd
Fri Feb 15, 2008 11:02 am
I have a rule that I use.
In Photoshop, set ruler guides to the centre of the image (horizontal and vertical). This will mark the absolute centre point of the image, and help you to crop it properly. It doesn't work all the time, but it is a little bit useful. I generally try to line up the fuselage with the centre where possible.
boeingfreak
Fri Feb 15, 2008 12:08 pm
Hi all,
thank you very much for your posts!  Smile
Quoting Raoulr (Reply 5):
Raoul, that was exactly the statement I wrote to the headscreeners, the dark bottom kind of fools your eyes and makes the aircraft appear lower in the frame than it actually is.
Let's wait and see, if the appeal gets rejected as well I'll rework it and put it a bit higher in the frame.  Smile
Florian  wave
boeingfreak
Thu Feb 21, 2008 7:15 pm
Ok, appeal was accepted, thanks again for your posts!  Smile
Florian
