scbriml
Can This Shot Make It?
Mon Feb 18, 2008 12:04 pm
I'd really like to upload this shot, but I'm struggling to cope with the bright highlight on the fuselage. I've tried to tone it down after adjusting levels, but it ends up looking "grey". This crop from the original .JPG (I do shoot RAW, so have some additional flexibility).
Can I get the colours looking right without the highlight completely blowing out? Appreciate any suggestions!
http://i18.photobucket.com/albums/b101/scbriml/saa_a340.jpg
boeingfreak
RE: Can This Shot Make It?
Mon Feb 18, 2008 1:17 pm
Hello Steve,
your picture looks too dark to me.
If you want, send me the original and I'll try my best editing it.
Florian  wave
sovietjet
Mon Feb 18, 2008 1:47 pm
Try using the image-adjust-shadow/highlights tool
clickhappy
Mon Feb 18, 2008 2:55 pm
Quoting Sovietjet (Reply 2):
Fail.
This will result in a Editing rejection.
A properly exposed image should not need this type of manipulation. Learn to use curves.
Steve - your image is lacking contrast. Try adjusting via curves and levels.
scbriml
Mon Feb 18, 2008 5:52 pm
Try adjusting via curves and levels.*
Yes I know, I should have pointed out that .JPG is unedited.
My question is whether the highlight along the fuselage will cause the shot to be rejected? This is about the best I can do:
http://i18.photobucket.com/albums/b101/scbriml/scbriml_zs-sxb.jpg
*for some reason, the "Quote selected text" isn't working from Clickhappy's post.  confused
clickhappy
Mon Feb 18, 2008 5:54 pm
impossible to tell at the size you have provided.
scbriml
Mon Feb 18, 2008 8:51 pm
Sorry!  banghead
Try this:
Big version: Width: 1024 Height: 683 File size: 230kb
Scotland1979
Mon Feb 18, 2008 9:31 pm
I think you should try to avoid sun angle at plane which can make result not great. Try to move somewhere to avoid reflect as a result you may get good result. I had the same problem last Nov in PHL
Jesus said "I am the Way and the Truth and the Life. No one comes to the Father except through Me" - John 14:6
clickhappy
Tue Feb 19, 2008 4:15 pm
Steve -
Ditch the Adobe RGB and switch your camera to sRGB (I use Mode 1 on my D200s).
Shot looks halfway decent, but the color balance shows that shitty green/yellow Nikon color cast, I would use a custom White Balance to blue it up.
I give the shot 6/10, might make it, but the post processing could be improved to help it along.
